11-28-2022, 06:17 PM | #1 |
Rep 604
2015 750i AC question
Afternoon, I have a buddy looking at a 2015 750i, the vehicle AC blows strong but only warm air. I know this is likely a compressor issue or a refrigerant leak; however, will this cause the ventilated seats to be completely inoperable? I'm not sure if BMW programmed the seats to stop functioning if the AC system is not cooling. Any insight would be greatly appreciated by both him and I.
11-29-2022, 03:08 AM | #2 |
Rep 5,098
To the best of my knowledge the seats are just blowing ambient air from within the cabin, nothing to do with the air conditioning
The air condition issue may be as simple as a re-gas. It may be potentially more expensive if other parts at fault. ( whilst the gas leaks out over time, it should be empty which suggests something a bit more serious |
11-30-2022, 11:15 AM | #3 |
Rep 7,489
Check to make sure the stratified air dials (located around the center dash vent) is in the neutral or blue area (if you want cooled air)...if that dial is turned into the red area...then only warmed/heated air will blow from the dash vents.
The stratified air dial is known to confound many owners that don't understand its function and usage. Stratification
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 11-30-2022 at 11:26 AM.. |
