12-01-2015, 06:31 PM | #1 |
Rep 2,246
Run Flat to Conventional Tire Difficulty at Dealer
Anyone ever have difficulty with your dealer when going from run flats to conventional tires?
Service advisor states not able to install conventional tires because car came with run flats. Parts department, however, states able to obtain and sell any tire that fits. I'm trying to get wheel and tire insurance to replace bubbled run flats with conventional tires, but if I can’t get same now, I'll go through Tire Rack when wheel and tire insurance ends in a month. Guess I'm wondering if there's any specific rule (BMW's own or otherwise) against dealers installing conventional tires on cars that came with run flats? Thanks! Last edited by dbs600; 12-01-2015 at 06:36 PM.. |
12-02-2015, 02:58 AM | #2 | |
Rep 621
Drives: E93 M3 LCI DCT & F01 730d SE
I actively seek to change the tyres to non run flats given that the comfort is much better and the handling is not much worse. The decision to move was made when I had a tyre delaminate on the motorway at 65mph and because there were lots of loose parts to the wheel if I drove any further then it would destroy or damage the surrounding areas of the car! I couldn't drive any further on the tyre for obvious reasons which brought me to look at non run flats. |
12-02-2015, 10:18 AM | #3 | |
Rep 2,246
Run flats are so bad, I hope they allow the switch. |
12-04-2015, 11:25 PM | #6 |
Rep 2,246
After TREMENDOUS back and forth, got approval.
Insurance agreed to substitute Continental ExtremeContact DWS 06 conventional tires for my Goodyear Excellence run flats, and dealer FINALLY agreed to order and install same. Can't wait to experience the handling, comfort and winter performance (with xDrive) I should've had for the past 5 years. Picking car up tomorrow. Will report back. |
12-05-2015, 09:19 PM | #7 |
Rep 2,246
DAY AND NIGHT DIFFERENCE! FAR quieter, FAR smoother; immediately noticeable.
Known road imperfections and minor manholes now unnoticeable. Car absorbs all the way a full-sized luxury sedan should. I've driven in Comfort since new, which almost seems too soft now. That said, not sure if it's the tires or because I returned a loaded 435i M Sport loaner [that I drove in Sport], but steering now seems a bit less precise. Not numb, not spongy, but less precise. Not wandering, but not sure how else to describe. Could this be because the tires aren't broken in yet? Can anyone confirm if this improves in a couple hundred miles? In sum, happy for now! Two more points: Run flats are almost double the weight of conventional tires(!); upon new tire drop off, recouped one undamaged run flat, and the weight was surprising! AND, saw a 435i Individual in the showroom and thought the leather weave on the doors was awesome; very Bottega Veneta! Last edited by dbs600; 12-10-2015 at 01:23 AM.. |
12-06-2015, 12:55 AM | #8 |
Rep 2,246
Also the new tires stick out past the wheels a bit more instead of wrapping them like a rubber band.
Should help protect against some cosmetic wheel damage. After driving more, feel like my car is saying thanks after what was abuse by the run flats. Last edited by dbs600; 12-07-2015 at 05:36 PM.. |
12-06-2015, 01:41 AM | #9 | |
Rep 621
I have changed the tyres on my last 3 bmw's to non run flats and I will do so when the tyres on my (new to me 730d) have finished their serviceable life. All that you have described is how I've felt when changing them. The car seems to have a little more sideways movement when cornering, almost as if the tyre wall has a bit of play in it because of the reduced rigidity. It makes complete sense on a 7 series to do this but on a 3/4 series unless you have low profile tyres I've found that the fun of driving this type of car is taken away a bit due to the rolling described above. |
12-06-2015, 09:16 AM | #10 | |
Rep 2,246
Have to take her out again today to see. Also going to adjust air pressures in the coming week. |
02-19-2016, 07:41 AM | #11 |
Rep 1
Fellas i really thank you guys for this informative post. Im will be new to bmw world shortly. Since i have friends that had issues with runflats now i know it is an option im more inclined to purchasing a set of conventional tires.
03-30-2016, 07:18 AM | #12 |
Rep 154
What do you guys do with the runflats that came with the car? Save it? Just curious. I am seriously thinking of giving this a try but don't have space to store any more tires in my garage.
03-30-2016, 09:53 AM | #13 |
Rep 2,246
Three of my run flats had bubbles, so those were trashed. So, I put the fourth in a large black garbage bag and it's in my garage. The difference in [unsprung] weight between conventional and run flats is astonishing!
