      01-19-2011, 03:11 PM   #1
spera23
Drives: 335i
e65 Heated Steering Wheel Problem
My heated steering wheel button does not work. I press it and it stays lit for 2 seconds and then just goes off.
The car was purchased used, so no idea if it ever worked. Running the codes with a BT scanner i get the following:
Switch Centre steering column (SZL)
94F4
Steering Wheel Heating (LHZ) Temperature sensor interrupted
Error will not cause a warning light
Error is currently present
Any ideas????
      01-23-2011, 09:49 PM   #2
apw2607
Drives: 2024 X5 50e M-Sport
94F4
Any ideas????
I have exactly the same issue ... But on me e70 ! The dealer has being trying to fix the issue for months. They just ordered a brand new steering wheel and will replace it this coming week ... We'll see. Good luck with fixing your heater !
      01-23-2011, 11:44 PM   #3
xDrive50i
xDrive50i's Avatar
Drives: '09 750i individual
Sounds like the temp sensor in the steering wheel is either defective or the wiring between the controller and temp sensor is interrupted (disconnected) somewhere. I'm just guessing that's what the error message means.
I would assume that the controller uses a closed loop type of heat control mechanism meaning that it maintains/controls the temperature of the steering wheel via a temp sensor mounted within the steering wheel (most likely right under the leather close to where you have your hands) for feedback information. It could be as simple as a disconnected wire or harness somewhere or it could also mean that the actual sensor if defective. Have you looked to see if there are any connectors that might be disconnected within the steering column?
      02-13-2011, 09:49 AM   #4
GMWNashville
Drives: 19 G05, 16 F80, 10 E70x5D
yep-replace the steering wheel
