09-17-2014, 03:23 PM | #67 | |
Rep 161
CURRENT: '15 Macan Turbo, '14 Viper TA (#8 of 33 in White)
PAST: '07 Porsche 997TT 1054whp, '14 C7 Stingray Coupe - 7-MT, '13 GT-R 1137whp, '13 Porsche Cayenne GTS, '14 Porsche 991 GT3 (sold back to Porsche), '12 GT-R 900whp, '10 GT-R 1250whp, '10 GT-R 600hp, '03 Porsche 996 GT2 800whp, '01 Porsche 996TT 900whp, '06 Z06 722whp, '98 Supra 711whp, '01 M5, '05 M3, '03 M3 416whp |
09-17-2014, 07:22 PM | #68 | ||
Rep 2,176
09-17-2014, 07:44 PM | #69 | |
Rep 161
The real bottom line is that a N/A Viper TA on street tires and steel brakes beat a S/C ZR1 on R-compounds and carbon brakes. Top Viper vs top Corvette (which was not out of production at the time), Viper won. The same TA, on a similar tire the Z/28 runs, was 2.8 seconds faster than the production car record time it just set at Laguna Seca, so no comparison to a Z/28 at all. Without those tires, the Z/28's times wouldn't even be talked about. Also, the post-production base Viper is only .8 seconds slower than the T/A on the SRT test track on the same street tires. Vipers are simply faster around a track than Corvettes are, even with inferior tires and brakes. I also own a C7 Z/51 Stingray and have no problem admitting that fact. The new Z06 only makes 10 more HP the the ZR1 did, yet weighs almost 200 lbs more. The only Z06 that will have a chance beating the Viper will be the Z06 with Z07 package (cup tires, carbon brakes and a lot of aero), but even then, the new TA 2.0 is already available to order with much better aero, and if they decide to slap a set of the same cup tires that the Z06 runs on the TA, it's game over for the Corvette. Can't wait!
PAST: '07 Porsche 997TT 1054whp, '14 C7 Stingray Coupe - 7-MT, '13 GT-R 1137whp, '13 Porsche Cayenne GTS, '14 Porsche 991 GT3 (sold back to Porsche), '12 GT-R 900whp, '10 GT-R 1250whp, '10 GT-R 600hp, '03 Porsche 996 GT2 800whp, '01 Porsche 996TT 900whp, '06 Z06 722whp, '98 Supra 711whp, '01 M5, '05 M3, '03 M3 416whp Last edited by Divexxtreme; 09-17-2014 at 08:03 PM.. |
09-17-2014, 08:06 PM | #70 | |
///M Powered for Life
11490
Rep 10,329
They don't specify which 'slicks' they used though. The base z51 was already compared vs the regular viper and it lost by a ton of time even though they didn't have the skill to push the viper |
09-17-2014, 08:19 PM | #71 | |
Rep 161
However, at 10:20 in this different video, SRT themselves explains that they tested Michelin Pilot Sport Cups on the Viper TA and were 2.5 seconds faster with them on the TA than the standard Corsa street tires the cars come with. Even Pobst says in the video that Cups are essentially as fast as racing slicks when he states they are "almost a pure race tire". The technology of R-compounds has really come a long way, which explains why the Z/28 runs the times it does. https://www.youtube.com/watch?featur...&v=k-ItYO0LoMU
09-17-2014, 08:32 PM | #72 | ||
Rep 2,176
09-17-2014, 08:52 PM | #74 | |
Rep 2,176
09-17-2014, 09:08 PM | #75 |
Rep 161
I can see that you're trying very hard, so I'll help you out a little. The Viper TA runs Pirelli P-Zero Corsa System tires. They are very good tires (outstanding), but they are not true R-compounds. The next stickiest tire Pirelli makes is the P-Zero Trofeo, and the stickiest one they produce is called the P-Zero Trofeo Rs, which are true R-compounds. Trofeo Rs are the tires that the Z/28 comes with. Michelin's comparable tire to the Trofeo R is called the Michelin Pilot Sport Cup or Cup ZP (the run-flat version). These are also true R-compounds. These are ZR1 OEM tires and are of course what the ZR1 used in the test against the Viper TA. Not only did the Viper TA on non R-compounds beat the ZR1 running true R-compounds, but SRT also tested the ZR1's Cup tires on their TA, and they ran 2.5 seconds faster lap than they did with the OEM Corsa Systems, so obviously the ZR1's Cup tires are MUCH faster track tire than the Corsa Systems are. So you can call the Viper's tires whatever you want, point out treadwear ratings, size, whatever....but the fact is they are 2.5 seconds slower on the same car than the Cup tires the ZR1 uses, which is why tens of thousands of track rats around the US use Cups on their track cars every weekend instead of Corsa Systems. The C7 Z06 (Z07 package) will be running the exact same tires the ZR1 ran, Cup ZPs. The non Z07 version will run the Pilot Super Sport 2 ZPs (non R-compounds). Hope this helps.
PAST: '07 Porsche 997TT 1054whp, '14 C7 Stingray Coupe - 7-MT, '13 GT-R 1137whp, '13 Porsche Cayenne GTS, '14 Porsche 991 GT3 (sold back to Porsche), '12 GT-R 900whp, '10 GT-R 1250whp, '10 GT-R 600hp, '03 Porsche 996 GT2 800whp, '01 Porsche 996TT 900whp, '06 Z06 722whp, '98 Supra 711whp, '01 M5, '05 M3, '03 M3 416whp Last edited by Divexxtreme; 09-17-2014 at 09:26 PM.. |
09-17-2014, 09:47 PM | #76 | |
Rep 1,997
once again, i'm definitely not knocking your choice … i'm playing it REALLY safe by getting a white M3, not even any funky colors… talk about pedestrian! and if there were a viper and a vette side by side and i were to rent one for a weekend, i'd definitely choose the Viper. |
09-18-2014, 04:38 AM | #77 | |
11490
Rep 10,329
All of its competition will be using the PSC2, no reason a 'time attack' Viper shouldn't have them as well. I hope to own a Viper one day! |
09-18-2014, 05:13 AM | #78 | |
Rep 2,176
09-18-2014, 10:23 AM | #79 | |
Rep 161
In the first comparo, the pre-production Viper had problems with suspension alignment and the brakes weren't bedded in yet. Once they used an actual production Viper, the Viper won, and Pbost was raving about it in two different videos. Everything I'm saying is in the videos posted in this thread. The Cup discussion starts at 10:20 in the round-table video that I posted. The Viper currently holds 9 production car lap records on tracks throughout the US because it's simply a faster track car than the ZR1 is, even though it has inferior track tires. Corvette better do wonders with the Z06, because it has almost 3 seconds to make up again the TA on the same tire.
PAST: '07 Porsche 997TT 1054whp, '14 C7 Stingray Coupe - 7-MT, '13 GT-R 1137whp, '13 Porsche Cayenne GTS, '14 Porsche 991 GT3 (sold back to Porsche), '12 GT-R 900whp, '10 GT-R 1250whp, '10 GT-R 600hp, '03 Porsche 996 GT2 800whp, '01 Porsche 996TT 900whp, '06 Z06 722whp, '98 Supra 711whp, '01 M5, '05 M3, '03 M3 416whp Last edited by Divexxtreme; 09-18-2014 at 10:30 AM.. |
09-18-2014, 10:28 AM | #80 | |
Rep 161
09-18-2014, 10:30 AM | #81 | |
Rep 2,176
09-18-2014, 10:33 AM | #82 | |
Rep 161
I think they 'might' do a comparison between the C7 Z06 and the TA 2.0 with the TA on the stock Corsas first, and then with a set of Cups on it, because of the massive amount of controversy that surrounded the first test when different tires were used. We'll see.
09-18-2014, 10:42 AM | #83 | |
Rep 161
Negative. The Viper GTS they used in the test was NOT a production car. It was a pre-production car that should have never been used, but SRT fell behind on time (their own fault) and had no other options. You are only half-right on your second point. Yes, MT ran the TA on R7s after the test and picked up 2.8 seconds on Laguna Seca. However, in addition to that, SRT themselves ran their TA on Michelin Cups and picked up 2.5 seconds on their test track over the OEM Corsas. So the Cups were almost as fast as the R7s were, and even Pobst admits it on video (again, all of this information is available elsewhere in this thread). You have been wrong over and over again, and you're making yourself look more and more clueless with every post. I was #1 on the Z06 list and removed myself because GM is killing innocent people with faulty ignition switches (19 so far, could be upwards of 125 people killed), they can't seem to stop having cars recalled (Gen V Viper has had zero recalls), the Z06 will be overweight and its cachet diluted by offering auto and convertible options, and it's just another Corvette in a sea of Corvettes with no exclusivity at all. The Viper being the better performance car (and a lot better looking to boot), is just icing on the cake for me. The funniest part about this argument is that you aren't even a Corvette owner or a Viper owner like I am. Nut-swing much?
PAST: '07 Porsche 997TT 1054whp, '14 C7 Stingray Coupe - 7-MT, '13 GT-R 1137whp, '13 Porsche Cayenne GTS, '14 Porsche 991 GT3 (sold back to Porsche), '12 GT-R 900whp, '10 GT-R 1250whp, '10 GT-R 600hp, '03 Porsche 996 GT2 800whp, '01 Porsche 996TT 900whp, '06 Z06 722whp, '98 Supra 711whp, '01 M5, '05 M3, '03 M3 416whp Last edited by Divexxtreme; 09-18-2014 at 11:17 AM.. |
09-18-2014, 10:47 AM | #84 |
11490
Rep 10,329
Divv, I do think the new Z06 with Z07 will be faster than the new Viper, even if the tires are the same.
I still prefer the Viper as it is the only american supercar. |
09-18-2014, 10:53 AM | #85 | |
Rep 161
But, we'll have to wait to see. You might be right. If so, if a TA on Cups loses to the Z07, I'll eat crow
PAST: '07 Porsche 997TT 1054whp, '14 C7 Stingray Coupe - 7-MT, '13 GT-R 1137whp, '13 Porsche Cayenne GTS, '14 Porsche 991 GT3 (sold back to Porsche), '12 GT-R 900whp, '10 GT-R 1250whp, '10 GT-R 600hp, '03 Porsche 996 GT2 800whp, '01 Porsche 996TT 900whp, '06 Z06 722whp, '98 Supra 711whp, '01 M5, '05 M3, '03 M3 416whp Last edited by Divexxtreme; 09-18-2014 at 11:01 AM.. |
09-18-2014, 11:19 AM | #86 | ||
Rep 2,176
09-18-2014, 11:32 AM | #87 | |
Rep 161
I will admit that I also think the C7 is a fantastic car. I really can't complain about it at all (except the shift-feel, not a fan). If they had kept the C7 Z06 close to the weight of the C7, I'd be thrilled. But it's damn near 250 lbs heavier than the C7 is. Then they add convertible and auto options? I'll pass. I know why GM is doing it, for more sales, but it takes away from the Z06 brand IMO. Anyway, let's just see how things play out between the Viper TA 2.0 and the Z07 package C7 Z06. It'll be interesting to say the least. Have a good one.
09-18-2014, 11:55 AM | #88 | |
11490
Rep 10,329
