01-22-2024, 05:57 AM | #331 |
///M driver
16392
Rep 500
Drives: 2022 M3 6-speed
I think the small device in front of the bridge windows and behind the gun mounts is supposed to represent the future laser weapon. Death ray for the win!
'22 G80 M3 6-sp Portimao Blue/Tartufo
01-22-2024, 09:47 AM | #332 |
Rep 19,777
01-22-2024, 10:22 AM | #333 | |
Track Rat
1760
Rep 403
IOMG // Full Tartufo Leather // MP HAS // Vorshlag Camber Plates // SS Brake Lines
Llarry16391.50 |
01-22-2024, 11:19 AM | #334 |
Track Rat
1760
Rep 403
I would think that you would want your Death Ray mounted where it has a full 360 deg. rotation ability. If you suddenly found out that you need it, it would be a bummer to have to bring the ship about.
Llarry16391.50 |
01-22-2024, 12:39 PM | #335 |
Rep 19,777
^ Problem with that is it would have to be too high up to avoid radar/aerial tower and other things. A quick slight turn and the ship would give it a large angle of strike without anything in the way of the laser being in the bow end of the ship if it wasn't already heading directly in that way.
01-22-2024, 01:30 PM | #337 |
///M driver
16392
Rep 500
If you had two mounts, it would certainly help.
01-22-2024, 05:36 PM | #338 |
Track Rat
1760
Rep 403
Maybe a Death Ray isn't as nimble and quick to use as something like Sea Wiz. In which case from the time of detection to the time of employment allows for maneuvering. ??
Llarry16391.50 |
01-23-2024, 08:20 AM | #339 |
///M driver
16392
Rep 500
Over in the airplane thread I featured the Martin P5M (P-5), the last U.S. Navy flying boat.
The flying boat depended on seaplane tenders for support: fuel, maintenance and berthing if at remote locations. In World War II the USN bought a number of large (15,000+ tons) seaplane tenders (AV) and a larger number of small (2,500 tons or so) seaplane tenders (AVP). Since the Navy operated the P-5 until 1967, including during the Vietnam War, they kept seaplane tenders active for the same timeframe. I believe the last AVP served until 1973, although it was no longer being used as a seaplane tender; the USS Valcour (AVP 55) was instead repurposed as a flagship (AGF 1) for Commander, Middle East Force. In those days, Middle East Force was a small command with a couple of destroyers deployed at any given time -- a far cry from today. The Valcour was painted white instead of gray in recognition of the hot temps encountered. Anyway, here are the tender photos. While I don't know the lift capacity of the seaplane cranes, the P-5 weighed about 55,000 lbs empty.
01-25-2024, 10:12 AM | #340 |
///M driver
16392
Rep 500
In the early days, U.S. Navy carriers had generous height in the hangar deck, and spare aircraft could be stored overhead. By the time, World War II started, this practice largely came to an end.
Here's a photo of a couple of SBD Dauntless dive bombers, with outer wings removed, stored overhead in the hangar bay of the USS Enterprise (CV 6), just before the practice was discontinued. By contrast, the UK's Royal Navy carriers had less overhead height -- so much so that when the RN Fleet Air Arm obtained U.S.-built F4U Corsairs, they had to clip the wings slightly in order to fit into RN carriers. (Photo of British Corsair model attached; note clipped wings.)
JJ 911SC22624.00 Boomer 20191759.50 |
01-26-2024, 05:41 AM | #341 |
///M driver
16392
Rep 500
Imperial Japanese Navy battleships seemed to have an awful lot of height to their superstructure -- likely for better fire control for the guns -- giving rise to the term "pagoda". Here's the battleship Fuso.
Here's another, better quality photo of Fuso from 1933. She was modernized 1937-1941 so would've looked different in WWII. She was sunk by the U.S. Navy in the Battle of Surigao Strait, October 25, 1944. Fuso was originally commissioned in 1915 and was armed with twelve 14-inch guns in six turrets.
01-26-2024, 06:08 AM | #342 |
Cailín gan eagla.
71460
Rep 1,007
01-26-2024, 06:43 AM | #343 |
///M driver
16392
Rep 500
If you were a fire control sailor up at the top of that in a heavy sea from abeam, I can imagine that being up that high would be difficult. Down at main deck level, the ship is rolling but up that high you are being slammed from side to side.
02-08-2024, 08:10 AM | #344 |
///M driver
16392
Rep 500
Another look at the forthcoming U.S. Navy missile frigates (FFGs) of the Constellation class: These ships will be about 70% as large as a missile destroyer and are projected to cost a billion dollars each, which is about half the cost of a DDG. They are based on an Italian/French design with some modifications and the first ship, the Constellation (FFG 62) has already begun construction. Fincantieri/Marinette Marine of Wisconsin has a contract to build the initial 10 ships of the class; a total of 20 FFGs is planned. There is some potential for further purchases.
The Navy plans to homeport the first 12 ships of the class in Everett, Washington as part of the Pacific Fleet. Interesting... Austal USA, a U.S. subsidiary of an Australian company, has recently completed a new assembly building at their Alabama yard. Austal is known for their aluminum-hulled ships, such as littoral combat ships and expeditionary fast transports, but their Alabama yard is now capable of building steel-hulled ships as well. Whether a second shipyard might be needed is an open question, but Austal USA is clearly hoping for some more business. The attached Congressional Research Service report on the new FFGs is a bit of a slog but raises some interesting points. For instance, the FFGs will be half the price of a DDG but have 33% of the vertical-launch missile tubes; how much would it cost to slightly lengthen the design and install 48 launch tubes? I also note that the speed of the FFG is slightly less than optimum when operating with a carrier strike group but fixing that would likely be a bit too expensive.
02-16-2024, 06:16 AM | #345 |
///M driver
16392
Rep 500
An interesting visual comparison of three Enterprises.
02-16-2024, 07:37 AM | #346 |
///M driver
16392
Rep 500
I'm puzzled by this photo. I was aware that CVN 80, the future USS Enterprise, was in the water, but Wikipedia says she is not to commission until 2028. Perhaps this is a photo of the lead ship of the class; I don't see an "80" anywhere.
02-16-2024, 09:19 AM | #347 |
Cailín gan eagla.
71460
Rep 1,007
Isn't that the USS Gerald Ford CVN-78...?
02-16-2024, 09:22 AM | #348 |
///M driver
16392
Rep 500
It may be; I googled the Enterprise, but we all know how reliable that technique is. Now that you mention it, I know the Kennedy is in the water (but still under construction) and the Enterprise is not. Oops!
02-16-2024, 09:28 AM | #349 |
///M driver
16392
Rep 500
Here is a photo of what will become the Enterprise -- this one dates to fall of 2022. I don't think it would float very well...
JJ 911SC22624.00 |
02-16-2024, 10:02 AM | #350 |
Rep 418
I'm a retired Air Force MSgt, but my son is the NFO Wizzo in the back of an EA-18G at initial training at Whidbey Island NAS, WA. He is now fully qualified and stationed at Fallon NAS, NV. Bonus points if you noticed his front seater was not US Navy on that flight!
02-16-2024, 10:19 AM | #351 | |
///M driver
16392
Rep 500
(I think your son is an EWO, not an WSO; does he call himself a Wizzo?)
