05-19-2016, 12:05 PM | #2 |
Rep 834
Most people use 255/30/22 front and 295/25/22 rear
'23 B8, '84 Monte Carlo SS, '23 Escalade, '21 S 580, '20 AMG GT 53 , '18 LS 500, '18 X6, '16 Corvette, '12 750Li, '14 GS 350, '13 ES 350, '10 Maxima, '09 Challenger |
05-19-2016, 02:36 PM | #3 |
Rep 31
Totally depends on the driving too man..
If you're driving hard, making quick turns... 22s might not be the ticket for you.. I was gonna go that route... but with all the potholes around me, kept it on 20s. Here's some measurements for you when I was doing research: STOCK rear: 275/35/20; 254mm width; 27.6" height 22 rims rear: 285/30/22; 267mm width; 28.8" height STOCK front: 245/40/20; 216mm width; 27.7" height 22 rims front: 245/35/22; 229mm width; 28.8" height I want as much as rubber as possible without sacrificing space, and notice the 22" rim/tire setup will make you equal in height in the front and the rear, as opposed to stock. Hope it helps. FYI. these were measurements for my car, and its dropped 2in all around. |
05-26-2016, 10:45 AM | #6 |
Rep 834
I doubt it.
06-13-2016, 10:41 AM | #8 |
Rep 834
With aftermarket low profile tires and terrible Los Angeles streets, I always run the max pressure listed on the sidewall.
I've hit a few small pot holes with no damage.
06-14-2016, 06:47 PM | #9 |
Rep 5
I have 22s on my 7-Series and I'm running 255/30/22 and 295/25/22.
You may want to look into some spacers because my set up is +28 front and +42 rear and I'm considering 5mm spacers in the front. I am also on H & R Springs with no rubbing issues at all. Last edited by B3B27B6; 06-14-2016 at 06:48 PM.. Reason: Left something out |
