      05-25-2020, 02:46 PM   #1
RaptorStrike
Drives: 320i Sport Touring
Sky Lounge Panoramic roof query.
My 740 has the sky lounge piano roof.
When I lock the car the rear cover closes. But the front one stays open. I have to hold the lock button or keep my finger on the door handle to get the front to close.
Is there something I'm doing wrong? I want the front to also close as soon as the rear one does. It helps keep the heat down in the car during sunny days.
I'm sure it did it previously and I haven't changed anything on the car.
Any ideas?
      05-25-2020, 06:53 PM   #2
13M5F10
Hide! My wife's coming!
13M5F10's Avatar
Any ideas?
It's functioning as designed. When you lock the car, the rear shade closes, if the front is opened, it stays opened. You could hold the lock button on the remote to close the front shade.
Not sure if it can be coded. Maybe someone can chime in or mrgicm might know.
      05-26-2020, 02:20 AM   #3
mrgicm
mrgicm's Avatar
441
Drives: BMW M
The front is part is acting then as a normal sunroof, you can either:
1. Hold the key fob to close it. ( code the delay needed to hold the key fob, or by holding your finger on the keyless go door handle.
2. Select the option in the Idrive Menu that the sunroof closes automaticly in 6-8 hours. If you dont have that option it can be coded. Not sure if the time frame can be changed. I have to check.
3. Code it that closes if it detects rain, but I found that option doesnt work properly and gave me trouble so I coded it out.
      05-26-2020, 07:24 AM   #4
RaptorStrike
Thank you for the replies.
I must have dreamt it closed itself before.
I was reading through the owners manual again last night and found it said it just closes the rear sunshade.
Bit annoying for my OCD that you can't have it close straight away. But I suppose BMW know best.
Thanks
Carl
      05-09-2023, 07:42 AM   #5
tonydt1g3r
Drives: F83
I have question about the rear. Every time I get in the car the rear pano opens. I then close it and drive away. When I park the car and the car turns off the rear pano opens again. When I lock the car it then closes. How do I prevent the rear from auto magically opening
      10-19-2023, 06:55 AM   #6
nav792
Drives: 2021 BMW M4, 2022 BMW x7
2021 m4  [9.00]
Did you ever figure this out?
      10-29-2023, 03:41 AM   #7
Atavus
United Kingdom
75
Drives: BMW M760Li
If you close it once you are in the car, that becomes the norm.
