      10-15-2022, 04:14 PM   #1
TXSTYLE
"Salud"
TXSTYLE's Avatar
Question Has Anyone Successfully Repaired Their AGM Using NORCO 5
Greetings my F0 peeps!
I've probably had 3 batteries total in my beloved 750i. I don't drive often (4-5k annually). My battery is discharging lately. I've been able to use either my trickle charger or the Norco 5 to fully charge it. Then I get low battery warnings again.
I'm wondering has anyone successfully "Repaired" their AGM using a Norco device?
Currently, I have disconnected my battery from the car and it's charging fully. Then I plan to use the Repair Mode.
Any feedback is appreciated...
Marcus
https://i.imgur.com/QAMZNzQ.jpg
      11-04-2022, 04:00 PM   #2
KJEEP
Drives: 2013 BMW 750i X Drive M Sport
I don't think you issue is your trickle charger. And repair mode just conditions your battery. If you are encountering low voltage warnings, my best guess is a component in your vehicle is working overtime.
While it can be anything, I have seen a few instances when a leak in the air suspension cause the compressor to drain the battery. Or maybe an auxiliary item in your car is the culprit.
Just my thoughts.
