BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > DME - 3100 Code 2007 335i
Reply
      04-30-2024, 03:54 AM   #1
Cam 335i
Cam 335i's Avatar
Drives: BMW E92 335i
My 2007 335i has upgraded Intercooler, vacuum lines, CP, Cone Intakes and BOV.
I was Doing some Logs and Testing my Anti Lag
I pulled 16.1 PSI.
Then my Car began to run without any boost pressure, I initially thought my intercooler piping may have blown off but when checking everything was secure.
The Pressure On my gauge would make it all the way out of the negatives but never over 0 PSI and my car sounded N/A. I attempted to clear the codes but they would instantly reappear.
I turned the car off left it for about 40 mins
hopped in and cleared codes then started it up and drove it. To my surprise my gauges were reading Positive Boost Pressure and my turbos where Spooling Again.
Is there anyway that the wastegates could have been stuck open allowing all air spinning the exhaust side to bypass thus making no boost.
First Pull:
Boost Target: 16.5 PSI
Boost: 16.1 PSI
Second Pull:
Boost Target: 8 PSI
Boost: 0 PSI
I will do a smoke test for any vacuum Leaks when my smoke tester arrives.
But After clearing codes my car seems to be running good again.
Has anyone ever experienced this?
The only code was 3100 - DME: Boost-Pressure Control, Deactivation.
      05-14-2024, 04:18 AM   #2
noidex
Drives: BMW 335i e93 N54 6MT
3100 means that the engine detected a malfunction and to protect it and the turbos it keeps the wastegates wide open with no boost target. That's it. I don't know why the ECU decided to shut off the turbos but no boost is what should happen in that case. I guess it's fine if it doesn't happen again.
Edit: I am a bit late since I am just trying to answer all recent unanswered questions but you can just reply and I should get back at you
BRG_N54311.50
      05-14-2024, 07:07 AM   #3
oVeRdOsE.
oVeRdOsE.'s Avatar
2820
Drives: F25 E91 Audi Avnt E90 Cayenne
3100 code appears without any other code?
do not clear codes, drive it (if it does not make funny noise) , rescan.
Reply
