      10-26-2012, 10:43 AM   #1
"Long Ignition Crank"
My car is 2 years old, has 18,000 miles and I’ve been experiencing a “long crank” more and more often, where after I press the start button it takes the car more than 1 or 2 ignition cranks to get the engine going. Unfortunately, the problem is intermittent and presents itself, if at all, once or twice a day; usually in the morning. The dealer states they are unable to duplicate the complaint. How do I get them to reproduce or acknowledge the problem? Is any data saved on the car’s computer systems? Thanks!
      10-27-2012, 12:09 AM   #2
filmoreslim
Drives: 2010 535i xDrive Sports Wagon
Originally Posted by dbs600
My car is 2 years old, has 18,000 miles and Ive been experiencing a long crank more and more often, where after I press the start button it takes the car more than 1 or 2 ignition cranks to get the engine going. Unfortunately, the problem is intermittent and presents itself, if at all, once or twice a day; usually in the morning. The dealer states they are unable to duplicate the complaint. How do I get them to reproduce or acknowledge the problem? Is any data saved on the cars computer systems? Thanks!
Somebody posted on another blog that BMW service techs at a dealership in Las Vegas identified this as a fuel pressure issue where the fuel line loses pressure when idle...I think you posted there...fuel pressure regulator needs to be replaced.
      10-27-2012, 12:20 AM   #3
Thanks, but any thoughts on how to reproduce it?
      10-27-2012, 12:38 PM   #4
BMWrules7
Take a video that shows the tach and the start button in the same frame.
Then count aloud on the recording:
3..2..1...start.
Then keep focused on the tach.
When you encounter the problem, show the normal video and then the video with the long start.
Typically, the tach will become stabilized when the engine has started. If you have the ability to display a timestamp on the video then that would be best.
      10-27-2012, 02:23 PM   #5
filmoreslim
Leave it overnight...if its a common occurrence the fuel pressure should drop if it sits10-12 hours.
      10-27-2012, 05:06 PM   #6
freshwhite335
freshwhite335's Avatar
Drives: 991/RR Sport AB
2011 BMW 135i  [0.00]
Had the same problem on our 09. Found it to be fuel pump issue.
2014 Range Rover Sport Autobiography
2012.5 991 C2S
1978 Corvette
