      03-13-2015, 03:07 PM   #1
waterborn0
waterborn0
Drives: 2012 750Li xDrive
Differences between N63 and N63tu
Does anyone know the specific differences between the N63 and N63tu engines used in the 750 F01/02?
I wonder if it the changes are merely simple upgrades such as higher performance fuel injectors, coils, and plugs..
I would like to increase my MPG and think fuel efficiency may be the simple path.
      03-13-2015, 05:14 PM   #2
Mike_L
Drives: 2015 335xi GT M-Sport MPPK
Its way more than that. Virtually the whole motor was overhauled, from the bottom up.
The economy difference has nothing to do with the motor itself. When the TU was introduced, so was the 8 speed, and thats where any economy difference comes from.
      03-13-2015, 06:00 PM   #3
waterborn0
waterborn0
Do you know the specific changes? Overhauling top to bottom is a bit vague.
      03-13-2015, 06:22 PM   #4
Mike_L
They share very few part numbers. The most important things are the addition of Valvetronic variable lift, new heads, and new turbos
      03-13-2015, 08:27 PM   #5
waterborn0
waterborn0
Not sharing the same part numbers is exactly the info that I am seeking, although I need the specifics. It doesn't sound like you have that info.
I was hoping someone had already done the analysis but I guess not. Time to do some work.
      03-13-2015, 08:34 PM   #6
Mike_L
I have all the info, because I have ETK access. I'm not about to go through the motor part by part though.
      03-13-2015, 08:41 PM   #7
waterborn0
waterborn0
Okay. Good for you which does nothing for me or anyone else seeking to improve fuel efficiency. As I said, I was hoping that someone had performed the analysis for the differences and what the impact might be be.
      03-13-2015, 08:42 PM   #8
Mike_L
There is no efficiency to be had. You're driving a $100k car. It is what it is.
      03-13-2015, 08:45 PM   #9
waterborn0
waterborn0
that is your unbridled opinion. I feel there always room for improvement.
      03-15-2015, 08:38 AM   #10
E90Fleet
South Africa
1312
Drives: BMW
N63TU differences
Engine mechanical
• New cylinder head due to use of the Turbo Valvetronic Direct Injection (TVDI) procedure
• 3rd generation Valvetronic
• New valvetrain with modified timing
• Adoption of VANOS from the N55 engine
• New cylinder head cover with adapted crankcase ventilation
• Pistons with modified piston crown geometry
• New connecting rod with even pitch and adaptation of the crankcase due to modified connecting rod shape
• Adapted crankshaft
• Chain drive with modified guide rails and an extruded chain with 142 elements.
Oil supply
• Pendulum slide cell pump with small overall width
• Eight individual oil spray nozzles for piston crown cooling.
Cooling
• Integration of the two engine control units in the low-temperature circuit and cooling over the back panel with cooling pipe
• Expansion tank under the left side wall with separate filling hopper.
Intake and exhaust emission systems
• Adaptation of the manifold for the air intake duct due to new geometry of the cylinder head cover
• Use of the hot film air mass meter 7
• Adoption of the charge air temperature and intake-manifold pressure sensor from the N20 engine
• Exhaust turbocharger with new compressor and modified wastegate valves
• Discontinuation of the blow-off valves.
Vacuum system
• Two-stage vacuum pump with new arrangement of the bolt connection
• Vacuum reservoir for the wastegate valves in the V-area of the engine.
Fuel preparation
• Use of the known high-pressure injection with injectors and high pressure pump HDP5
• Discontinuation of fuel low-pressure sensor
Engine management system
• New dual control unit concept with one control unit per bank
• Oil level sensor with an additional temperature sensor in the main oil duct behind the starter motor.
BMW if you are reading, I need a job, Please.
k335d80.00
      03-15-2015, 04:52 PM   #11
waterborn0
waterborn0
Thanks, that was helpful...
      03-16-2015, 03:26 PM   #12
E90Fleet
South Africa
1312
Drives: BMW
      11-14-2015, 03:44 PM   #13
damascus
gear head
damascus's Avatar
Drives: 2008 E92 M3 6M Interlagos Blue
Originally Posted by E90Fleet View Post
N63TU differences
http://www.topspeed.com/cars/car-new...6918.html#main
The N63TU is rated at 445 hp and 480 lb-ft of torque.
The N63T is rated at 400 hp and 450 lb-ft of torque.
F01 and F02 (7 Series Sedan) BMW equipped with the earlier N63(T) engines were produced from 3/2009 to 6/2012.
BMWCCA Member Since 1997
E30 M3 | E36 M3 Sedan | E46 330Ci | E39 540i M-Sport 6M | E92 335i M-Sport 6M | E90 335d M-Sport | 2013 E70 X5 50i M-Sport w/ Performance Package | E92 M3 6M | F30 340i M-sport
      11-16-2015, 12:40 AM   #14
TXSTYLE
"Salud"
TXSTYLE's Avatar
When exactly was this N63(TU) implemented? And was the 8 speed tyranny included?
Tags
n63 n63tu differences
