      11-22-2023, 11:00 PM   #1
Michael83
Drives: X7
740Li F02 - Error codes
Hi there,
hooked it up to ISTA+ and found these errors:
what are the unknown errors? serious or irrelevant?
Control Unit Tree = a lot of yellow...:
Bimmerlink gave 0 permanent errors, but the error memory quite a lot, but mostly old errors, not currently present, those that are currently present:
800FCB - Left Headlight (TMS) defective
9307B7: DAYS passenger door / rear side (BFTH): plausibility check unlock line against DATA line (error present and stored)
Reported as "Unkown" seems to be errors stored, does not mention currently active:
E21407
D70DA2 -> Timeout, but message ENGINE_1
D3543A
Only on Bimmerlink:
801C15: Failed to fall asleep at 30B = error stored
When loading ISTA got this Warning: Battery Voltage (terminal 30) above threshold value (14.85v) -> Reduce voltage
any feedback would be appreciated, need to decide coming days if I buy this car...
Many thanks,
Cheers,
M
      11-23-2023, 03:15 AM   #2
Michael83
Drives: X7
was hoping this car has KAFAS, because options:
524 Adaptive Headlights (pre-LCI, so Xenon)
5AH Decoding Dynamic Brake Light
8S1 Daytime Running Lights Decoding
8S4 Decoding Variable Light Distribution
8TD Decodierung Speed Limit Info
looking VCM / ECU, there's no KAFAS mentioned anywhere... was it called differently in 2009 models?
or does it mean the car doesn't have KAFAS? even FLA is not mentioned... strange since all these F02 in Thailand have Adaptive Headlights, which can't be adaptive if there's no camera like FLA nor KAFAS?
attached the full ECU list out of ISTA+:
File Type: pdf 20231123_155135_EcuList_VIN7-C242515.pdf (990.1 KB, 31 views)
      11-25-2023, 08:55 AM   #3
TheNine90
Drives: bmw
Clear all faults and check what remains.
