      01-13-2023, 03:22 AM   #1
nitin100
Drives: G12
G12 Aux battery - cannot replace due to access issues
Hello
Can you guys please help me in changing th Aux battery in G12.
I have ordered the correct battery - But i am unable to remove the old battery.
The access seems to be blocked by the sway bar. I have atatched the photo. I have loosened the battery lock nut (which is not visible in the photo)
Can you please check the TIS and guide me in this process.
Thank you
      01-13-2023, 07:52 AM   #2
finestbm@gmail.com
Drives: BMW X5 F15 750 G12 i4 G26
2023 BMW I4  [0.00]
2016 BMW 750  [0.00]
Hi
This is a screenshot from newtis
Let me know if you need anything else
Patryk chmielewski
      01-13-2023, 08:03 AM   #3
nitin100
Drives: G12
Thank you.
I am reading from phone - so may be I am not understanding-
1. I have to remove strut.
2. I have to remove both vipers (is this necessary?)
And to change battery its a LOT of work. I am surprised.
      01-13-2023, 09:17 AM   #4
finestbm@gmail.com
2023 BMW I4  [0.00]
2016 BMW 750  [0.00]
Yes - you have to 😉
I did it on my g12 while ago
Patryk chmielewski
      01-13-2023, 12:57 PM   #5
nitin100
Drives: G12
Ok - Its quite different from Version1 or Version2 as above.
My strut seems to go from left to right without any connection to the body.
Its a 750Li.
Also - The strut nuts seem to be special nuts. They seem to be hex nuts.
To remove the wipers - is to remove the rubber flap? This seems to be attached(bonded to glass).
Confused.
      01-13-2023, 01:03 PM   #6
nitin100
Drives: G12
Zooming in version 1 - I may have misjudged. The screeenshot from your phone isnt clear - But If i discount the arrows, mine one looks like version 1.
So, I will try version 1 method.
Any special tools needed(it mentions special tool to remove wipers) and this hex nut seems to stump me.
      01-13-2023, 05:25 PM   #7
finestbm@gmail.com
2023 BMW I4  [0.00]
2016 BMW 750  [0.00]
You don't need any special tool for wiper blade, you have just to pulling out, it look complicated but it's easy to replace this battery and it's gonna take up to 30 minutes
Patryk chmielewski
      01-13-2023, 05:28 PM   #8
finestbm@gmail.com
2023 BMW I4  [0.00]
2016 BMW 750  [0.00]
I have 750 and I think it's version 2
But when you will remove cowl panel cover then you will see what to do😉
Patryk chmielewski
      02-26-2024, 03:30 PM   #9
GeorgeA
GeorgeA's Avatar
Drives: E92 M3
Which battery did you end up buying as the replacement? I can't find anything online that's an identical replacement.
      02-27-2024, 01:40 AM   #10
MineralWhiteG12
Drives: Maybach 57
This does not relate to any access issues you are having, but I notice in your picture, you have the Neg/Pos terminals already disconnected. I would recommend you wrap the negative terminal in a shop rag and secure with a rubber band to prevent any arcing during the rest of the procedure.
