07-10-2023, 04:12 AM | #1 |
Rep 18
2010 F01 washer hose clip
Hello everyone,
I am currently experiencing a leak from my windscreen washer reservoir, and upon inspection, I have discovered that the black clip securing the washer hose to the windscreen pump has worn out and is no longer tight. I am hesitant to purchase an entire hose for just the clip. However, I am having trouble finding a part number. It's the hose marked "13" in the parts diagram. Would anyone be able to assist me in this matter? Any help would be greatly appreciated. Thank you. |
07-12-2023, 03:41 PM | #2 |
Rep 7,489
If you look up the hose (#13) you'll see that the clip you're referring to comes with it. It apparently is not sold separately.
So if you go back to the diagram you posted...scroll down to the #13 that you need...there's two numbers listed and it depends on if you are LHD or RHD...select accordingly...then shop using the 11 digit BMW part nbr that is correct for your car. These images below are #13 for LHD:
