      02-23-2021, 03:42 PM   #1
shakmonster
Drives: 2013 BMW 328i xDrive
Misfiring F02
Hello all, I serviced my 2010 750LI myself about 4 months ago with new sparks and PCV valves as well as adding a quart of oil every 1k miles or so. A month after my spark plug change the car misfired so I replaced the ignition coil of that bad cylinder but it seems like every week or so the problem has been jumping around first it was the third cylinder that kept misfiring even after I got used OEM ignition coils from an engine with only 30k miles. Now I have been through almost all cylinders misfiring at different times. Today I got 5 and 6 so I changed the coil packs again but it's still missing. I'm thinking to redo sparks and coil packs with brand new ones straight from FCP Euro. Does anyone have any tips or help in servicing the engine I might also get some fuel additives to help clean the cylinders. Thank you in Advance!
Note: sometimes it misfires when I go fast around 60-80 mph especially in the sport mode.
      04-14-2021, 07:05 PM   #2
7sportplus
Drives: 2011 7 series 750 LI
I'm having similar issue but mine only varies between #1 and #5. I haven't figured out what it is but I'm banking on it's my low and high fuel pumps. Low pump holding around 22psi when it should be around 45 to 50. My high preasure pump is sitting at 0 to 1 psi. I'm pretty sure that's my issue.
I just haven't gotten around to confirm yet. Both of
which can cause missfireing. My plugs and coils are fairly new but I also have a tune on my car as well which can cause missfireing. I wouldn't go back and change those parts again.
