      06-28-2014, 02:15 AM   #1
etc123
Drives: 2014 750Li
Oil change every 3k or 15k miles?
I just got my new 2014 750Li two weeks ago so I'm pretty new to the forum and BMW in general. In all my previous cars, I used to change the oil every 2,500-3,000 miles. It seems that oil change for the Bimmer is between 10k-15k miles depending on the driving style. Even though the newer cars have a lot of electronics, mechanical parts do exist and are responsible for the physical movement of the car. I just cannot make peace and allow myself to destroy the engine by changing the oil every 10k+ miles. I know i'm paranoic about this and usually do end up changing the oil sooner than most people but I just cannot accept changing it at more than 10k miles regardless of what synthetic oil they put in.
Does anyone have any comments on this topic?
      06-28-2014, 11:56 AM   #2
markymarc1979
Drives: 16 G12 + 15 F06 + 17 F15
2009 BMW E93  [0.00]
2012 BMW 750xi  [0.00]
If you love your BMW and plan to keep it for a long time, ignore BMW's crappy oil change intervals and change the oil as often as your wallet can bear.
      06-30-2014, 03:45 AM   #3
etc123
Drives: 2014 750Li
I don't want to throw money away but, at the same time I'm interested in other opinions on this matter. Would anyone disagree that changing the oil every 10k miles will potentially have a life-shortening effect for the engine and other mechanical parts? And yes, I do intend on keeping the car for a long time.
      06-30-2014, 06:30 AM   #4
335ifanatic
335ifanatic's Avatar
51
Drives: Revuelto, Urus Performante, X5
I would personally change the oil every 5000 miles if you're keeping the car. I never liked the long oil intervals BMW has set out because every car is driven in different conditions.
For example,my car sits in the garage for a good 3-4 months during the winter plus I barely drive 5000 miles in a year so I can't imagine getting a oil change every 2 years. Also over time the oil's viscosity drops as dirt and gas get mixed so again imagine the condition of your oil after 10k.
      07-03-2014, 12:51 PM   #5
TXSTYLE
"Salud"
TXSTYLE's Avatar
Every 4k miles for me with Royal Purple.
https://i.imgur.com/QAMZNzQ.jpg
      07-03-2014, 08:59 PM   #6
etc123
Drives: 2014 750Li
Wow, so not too many of you are following the BMW guidelines. That's encouraging! I was thinking 3k-4k miles and probably will end up doing just that. Thanks everybody for the feedback and please continue to chime in if you have an opinion on this.
      07-03-2014, 09:29 PM   #7
markymarc1979
2009 BMW E93  [0.00]
Its the blood of your car. Keep it pure and clean!
      07-04-2014, 09:29 AM   #8
BMWOO7
BMW CCA #505303
BMWOO7's Avatar
Drives: 2015 X5M / 2013 SVT Raptor
I'm in agreement with the others here. On my 2011 X5 with the N55 engine I changed it once a year at about 7500-10000 miles. It was a lease but it still bothered me to no end as I've always been one to change the oil every 5K with full synthetic (sooner than that I think is a waste unless your really driving it hard).
On my wife's new 2013 X5 I'm changing it every 5000-7500 MAX, as I too don't put that many miles on our cars.
My 2015 650 I plan to change the oil every 3000-5000 miles as well as it probably won't be driven that many miles each year anyway (Chicago weather).
As others have mentioned, if your planning on keeping the car and want to keep it running it's best, every 5000 miles is a good average for the new synthetic oils that they put in them.
In the end, it's kind of cheap insurance.
2015 BMW X5M F85 ///M
      08-05-2014, 12:16 AM   #9
etc123
Drives: 2014 750Li
Thanks for everybody's feedback. I've decided to change it every 5k miles.
      08-24-2014, 09:09 PM   #10
Whateva
Whateva's Avatar
27
Drives: 335i
2008 335i  [10.00]
If the recommendation is 15k and you're a spirited driver just cut that recommendation in half.
      08-27-2014, 05:12 PM   #11
listerone
Drives: 2018 BMW 540d
My "d" requirement is every 10K or every year.I plan to keep it a long time so i'll be doing 5K miles and 6 months.Gassers are different so maybe wisdom would require a different strategy for you.
Current : 2018 540d
Formerly: 2014 328d
Formerly: 2011 MB E350 Bluetec
Formerly: 2009 335d
      10-24-2014, 12:37 AM   #12
etc123
Drives: 2014 750Li
I found out that BMW's recommendation of 10k-15k miles oil change interval is based on some calculations given average speed and other factors and not on the oil quality. It's basically a counter which is advertised as intelligent by BMW. I'm very disappointed and am now questioning their other recommended maintenance intervals (brakes, other fluids, etc).
Since everything is electronic, how can you tell if the mechanic/dealer is actually changing the oil? With no oil dip, how would I check to see if I have new oil put in?
      10-24-2014, 02:57 PM   #13
frieseke
Drives: BMW 750li
I've used the recommended settings on my car. While my current 750 only has 88000 km on it, a couple cars back I had a 540i that was able to do about 430,000 km with oil changes about every 22000 km or so. I'd have no problem continuing doing what the car recommends.
      10-31-2014, 09:47 PM   #14
BMWrules7
If you really drive your 750li hard enough to require an oil change every 5000 miles---you won't need to change it because you [in some cases] won't have any oil in your car to change.
Yes, if you run your engine at top speed for long durations, you will consume 1 quart every 1000 miles. If you baby your engine like most drivers, changing the oil is like changing the air in your tires---it has no effect.
Now, bmw recently lowered its intervals, but you can still go the distance and not worry.
      10-31-2014, 11:23 PM   #15
Mike_L
Drives: 2015 335xi GT M-Sport MPPK
Thats not always true. I beat the crap out of the car, yet it doesn't use a drop of oil. The dealer keeps telling me that the N63 has weak valve seals and that its gonna destroy them and need new seals or heads, but I don't buy it. If I can't break it, its not weak. I break everything.
The chassis is proof of that. It's squeaking and creaking and rattling like crazy. It couldn't handle hard driving and poor roads.
      01-15-2015, 07:23 AM   #16
fazman
Drives: 335 e90
The rule of thumb is, since BMW gives you a free oil change @ 1yr/15k miles... I would do a mid service oil change at 7500 miles but NOT reset the CBS so that when u reach 1yr/15k miles they will do the free oil change.
generally you are not using dino oil, you are using synthetics... The only true way to know when is a good time to change is by doing a used oil analysis. My other rule of thumb for my using Mobil1 0-40 euro LL-01 5qt jugs from walmart, your car can drive 1000 miles per liter of oil you store in the motor. So if your car holds 7qts of motor oil... Then i would be comfortable going 7000 miles before changing the oil.
I have done 10k intervals on my 335xi with no issues
      01-15-2015, 10:20 AM   #17
TheBry
TheBry's Avatar
Drives: 2016 G12 750i xDrive
+1 Same here.
For each BMW I've ever owned, I've always followed BMW's guidance for oil changes using the condition-based prompts the cars give me and have had no oil / lubricant related problems with any of the cars whatsoever. I've put well in excess of 100K miles on each of them (and am now approaching 90K on my 2012 F02 7 Series). I drive a LOT of highway miles.
Past: 2008 M3 (E93) naturally aspirated V8 realness!
Past: 2012 740Li (F02) M-Sport (European Delivery)
Present: 2016 750i (G12) M-Sport
      01-15-2015, 10:54 AM   #18
TXSTYLE
"Salud"
TXSTYLE's Avatar
Lightbulb
You will see once you take your car in under this "N63 Customer Care Pkg" as I already have, that BMW is now stating oil change to be every 10k.
But I myself change it every 5k. This engine is an INCINERATOR and puts mucho stress on ALL components of this engine.
      01-16-2015, 09:05 PM   #19
bake
bake's Avatar
Drives: 2011 F10, 2013 E93
5K intervals for me as well.
Bake
2011 Alpine White on Black 535i M-Sport
2013 Space Gray on Fox Red M3 Vert
      02-28-2015, 12:29 AM   #20
etc123
Drives: 2014 750Li
Good insight, thanks everybody! I'm changing mine every 6k miles.
      03-01-2015, 12:29 PM   #21
paprmkr
BMW Enthusiast
paprmkr's Avatar
119
Drives: 2024 i5 M60 w/M-Performance ki
I would do it at half the suggested and before I take long trips. I drive a lot. Not locally since work only 2 miles away. I like to take trips like Colorado mountains Utah etc
But I do my own work. So lot cheaper than taking to get serviced. Myself doing it cost like <$90 dealer >$150 some areas like $200
      03-16-2015, 11:04 PM   #22
SoCal Pete
Drives: 2010 750i & 2015 X5M
Every 7500 miles for me.
