Go Back   7Post - 7 Series Forum > BMW 7-Series Forums > Classifieds: For Sale / Trade / Wanted
      08-28-2013, 10:25 PM   #1
thehank
Drives: e90
Fs: Dinan Bbk
BIMMERPOST / Classifieds
Asking Price:
USD 3,700.00
Or Best Offer
Item Interest
I have a DINAN Front Big Brake Kit for sale P/N D290-0011-BD
It was used for approx 3500 miles. There is plenty of pad material left that you can see in the picture. There is a couple little scratches on the caliper on the top where you cant see, but Im being pretty picky. The rotors have a little bit of parallelism that could probly be turned out on a brake lathe. As shown in the pictures there is plenty of rotor material left as well. They currently measure 1.341" and the minimum thickness is 1.259". I am looking for $3700
Here is the tech specs from DINAN's website which retails this kit at $4895.00
Product Description
The Dinan by Brembo brake conversion offers the ultimate in stopping power for the most demanding driving enthusiast. Extensive testing on the street and at the track has enabled us to develop custom systems that have been tuned for optimum performance while avoiding the foibles of typical "big brake kits", such as unbalanced proportioning, poor pedal feel and unacceptable noise levels, just to name a few. The brake calipers are available in either red or black and you have a choice of slotted or drilled rotors as well (slotted rotors recommended).
Brakes are available with either slotted or drilled rotors and finished in either black or red. Custom colors may be an additional cost.
Features & Benefits:
+ 405mm Drilled 2-piece Rear Rotor (vs. 374mm stock)
+ Dinan-spec brake pads
+ 6-piston aluminum calipers
+ Dinan approved front/rear brake balance
+ Painted calipers with white “DINAN by brembo” lettering
+ Includes mounting brackets & assembly hardware
+ Includes DOT/TUV approved Goodridge stainless steel brake lines
Note:
In most cases, the large rotors and calipers will require the use of aftermarket wheels for adequate brake clearance. Be sure to check with the manufacturer or distributor of the wheels you are considering in order to verify that they offer the necessary clearance, citing the Brembo ''Gran Turismo'' brakes as a reference.
      07-09-2015, 04:15 PM   #2
GT5
Drives: 2010 BMW 550i GT
Still for sale? PM me if so...
