      09-29-2015, 09:04 AM   #1
dbs600
Problems After N63 CCP Covered Under Warranty + Batteries for Life?
I had the N63 Customer Care Package Recall performed after my factory warranty expired, but if I have a related drivetrain problem going forward (injectors, etc.), will it be covered under ‘warranty’, as the CCP was? I recall reading it would be, but haven’t been able to get a clear answer. So, anyone experience continuing difficulties outside of warranty coverage that was resolved for free after CCP?
Also, will batteries be covered for life since there’s an acknowledged issue with the car’s design eating through them?
Thanks.
      10-12-2015, 09:44 PM   #2
Rick335i
Drives: 2008 335i / 2014 328i / 2017 X
Thanks.
CCP only covers the following items:
Vent hoses for crank case
Intercooler hose clamps
Both turbo inlet o ring gaskets
Programming software for oil service interval
Battery replacement depending on Ah
Injectors with an index # less than 11
Vacuum pump with an index # other than 1
Fuel feed line with sensor (only if it has the old bronze sensor)
Timing chains and guides (only if they fail the timing chain test)
Batteries are not covered once regular warranty is expired not even if CCP was done. Once CCP has been performed, any drivetrain failure from parts replaced during CCP should be covered but anything that is not related to the repair will not be covered.
      10-13-2015, 10:40 AM   #3
dbs600
Thanks!
      10-13-2015, 07:37 PM   #4
Rick335i
Thanks!
Welcome
