09-30-2022, 08:08 PM | #1 |
Rep 38
Recoding My BMW
The BMW dealership reset my car and I lost all my coded functions - ID6, car play e.t.c.
Is anyone available to re-code my car. Things I need are: 1. Carplay full screen 2. VIM 3. Default ACC to 1 block 4. Disable legal disclaimer 5. ID6 interface 6. British voice 7. Decrease WIndows and mirror initiation delay 8. Disable horn honk when locking car with engine running Thanks. |
10-16-2022, 11:29 AM | #3 | |
Rep 8,094
If you have the software or app…why not just reprogram what was lost? If don’t have the software…Bimmercode is an easy way to redo it. The app doesn’t cost much…and there are multiple adapters you can purchase to connect to your car (they don’t cost that much either)…and this way you can could what you want when you want to…and if for some reason you want to undo it, you can simply hook up and put the parameters back to original. And if for some reason the coding gets wiped out by the dealership again…you will have the software and adapter to redo the coding. And if you are not a “keeper” and trade-in for a newer or different BMW…you will have the app to personalize another BMW in your possession. Here’s a link to the Bimmercode.app website that lists all the coding parameters for the g11 7 series…they are listed alphabetically…just click on the topic heading for description of that coding parameter and the control module it will be found: https://www.bimmercode.app/cars/g11/ And if you fear doing it yourself…there are probably hundreds (or close to it) of videos on youtube that shows how simple and easy the app is to use.
Tags |
carplay fullscreen, coding, iphone, vim |
