02-03-2023, 08:39 PM | #1 |
Rep 25
Will it fit?
Does anyone know- will 2022 X3 M40i 21" wheels fit on a 2022 740i?
Front: 8.5Jx21 ET30 (P/N 36108043670), 5x112 mm, 66.6 hub Rear: 9.5Jx21 ET43 (P/N 36108043671), 5x112 mm, 66.6 hub I don't think so because the offset is wrong- but just wanted to double check. |
02-05-2023, 04:03 PM | #2 |
Rep 7,519
Run your existing wheel/tire specs through this calculator with the new wheel/tire specs to see how much poke or inset you’ll have vs the original. Compare the old vs new front axle, then the old vs new rear axle: www.willtheyfit.com
