      02-03-2017, 11:14 AM   #23
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Originally Posted by Celesabc View Post
What version of Esys and PZData are you guys using? Used G12 and S15A as connecting parameters but when try to Read SVT throws error, need to use Read ECU then Edit FDL code also throw some more exception.
I am using:
ESys 2.6.2.124
PZData 60.2
Thanks
Cel
Read (ECU, ≠ SVT): All BDC_BODY vehicles [X1 (F048), X5 & X6 (F15/F16/F85/F86), I3 & I8 (I001/I012), & new Gxx]
E-sys 3.27.1 or 3.28.1...it does not matter. Launcher Pro 2.6.3.
You have to use Psdzdata >= vehicle I-Step. If you are using 60.2, there is no point in updating to 60.3 for G12.
You would have to be more specific on Errors.
      02-08-2017, 05:48 PM   #24
Mybimmerbrain
Mybimmerbrain's Avatar
Drives: 2014 BMW X1
Originally Posted by Almaretto View Post
***New Coding Options***
Removal of Trunk open or close initiation delay
Option to set single touch or hold keyFOB &/or rockerswitch to open & close trunk
Default driving mode
Remember last driving mode based on designated interval (time between shutdown & start)
Triple Blinker set to one (1), three (3), or five (5)
I did the truck close with remote but had to hold the button to get it to close..
What was the 5 click blinkers? Could not find that. And the Bideo in motion not at all speeds is annoying. 😤
      02-08-2017, 08:04 PM   #25
Almaretto
Almaretto's Avatar
2374
The new HKFM2 ECU module, used in G012, G030, '17 F015, and a few others, has more options with which to play. And, separate FDL's for each of these:
  • Rockerswitch vs KeyFOB vs Smart vs Exterior button, etc
  • Open vs Close
Some of the possibilities include adjusting, adding, or removing the following:
  • Delays
  • Auditory Sounds
  • Interior Lighting
  • Exterior Lighting
  • Holding vs One Touch action
You mean this blinker?
View post on imgur.com
Various speedlocked functions can still be removed. But, some publicly available (& free) solutions only raise thresholds (eg, VIM up to 63 kph); while other paid solutions require either developer-signed CAFD's, script activation, or additional hardware.
I keep adding new option codes for G-series on a weekly basis, including those for various Driver Assist Features, interior lighting, and cold weather packages. I probably have 200+ choices.
      03-16-2017, 07:49 PM   #26
padrino
Alpina!
363
Drives: Alpina XB7
Have a 16 750 and the cable, picked it up originally to code my F10 M5 but ended up having someone do it for me.. Thinking it's time to jump in and make it happen, thanks for the details on this thread, seems the resources on the G* are a bit spotty, haven't found more than a couple dozen codes so far but it looks like things are out there..
2021 Alpina XB7 - Alpina Blue
2022 M5 CS - Frozen Gray
      03-16-2017, 08:56 PM   #27
Almaretto
Almaretto's Avatar
2374
I have over 200 codes for the G-series. It a slightly different architecture; but plenty of options once you understand it.
      03-19-2017, 02:49 PM   #28
speedracerlo
Drives: 2015 M6 Gran Coupe
Anyone figure out how to code the Light Carpet to stay on permanently?
      03-19-2017, 03:49 PM   #29
Almaretto
Almaretto's Avatar
2374
You want the cabin light that turns on when you open door to say on full bright?
      03-20-2017, 01:54 PM   #30
speedracerlo
No, light carpet has nothing to do with interior light.
It's the exterior welcome light you see on the floor below the side skirt.
I want that beam of light constantly on (at least at night) so they look like wings
      03-20-2017, 02:22 PM   #31
Almaretto
Almaretto's Avatar
2374
And then you drive with doors open?
      03-20-2017, 11:05 PM   #32
Herofmine
Herofmine's Avatar
Drives: E92M3, F10535i, 15 M5,340i,X5M
2015 X5M  [10.00]
Contact Instagram IG @richcodedmycar
He does coding and he can come to you or remotely. He coded my cars and let the professional do it for peace of mind
      03-21-2017, 09:59 AM   #33
speedracerlo
the light is not projected from the door, it's from behind the front wheels, under the side skirt.
Thanks I've heard of Rich
      03-21-2017, 01:47 PM   #34
Almaretto
Almaretto's Avatar
2374
I am local to you if you want car coded as well.
I would have to look into desired function.
      04-02-2017, 01:35 AM   #35
solo118
Drives: '11 335i Coupe
Does anyone know if there is a code to lower the speed for lane change assist? All of my other cars that had this feature worked at all speeds, and it only works at 35mph on the 750i which is vey annoying, as I barely get over 35mph in NYC traffic.
      04-02-2017, 11:01 AM   #36
Almaretto
Almaretto's Avatar
2374
There is code for Blind Spot detection at lower speed.
      04-14-2017, 09:43 AM   #37
Yellowtag
Drives: 2017 BMW 750
The light carpet on all the time might look cool going down the road at night. Id have to see it in person first.
      04-14-2017, 10:44 PM   #38
paul.j.ghosh
Drives: 2019 M760i xDrive
so, if you long press and turn off interior lights such that they don't turn on when the door is opened you lose the welcome carpet lights as well... I want carpet lights while interior lights are off - can that be done?
      04-14-2017, 11:44 PM   #39
Almaretto
Almaretto's Avatar
2374
Long press what?
Do you want the bright white cabin lights when door opens or the colored ambient lights?
      04-15-2017, 09:44 AM   #40
paul.j.ghosh
I discovered this by accident - long press the middle switch by the sunroof to turn on/off interior lights and they turn off permanently - as in the bright lights do not come on when you open the door. The side effect is that the welcome carpet lights that look like wings outside the car also turn off - no welcome lights when you unlock the car.
      04-23-2017, 04:19 PM   #41
Almaretto
Almaretto's Avatar
2374
Do you get to keep the interior colored ambient lighting without switching to bright white cabin lights?
      04-29-2017, 01:34 AM   #42
paul.j.ghosh
Yes.
Almaretto2374.00
      05-08-2017, 09:53 AM   #43
Dash52
Drives: 2017 740i Xdrive
Coding
Any Coders in the NY/ Long Island area?
      05-08-2017, 03:31 PM   #44
Almaretto
Almaretto's Avatar
2374
There is also the remote option if you cannot find someone local.
