      05-20-2017, 04:40 AM   #45
mscalissi
Brazil
Drives: BMW 320i GP
Hello,
For G series, 01 and 10, which chassi code on Esys I need to select?
I mean, for old 5 series, F10...I thought that on my Esys and Psdzdata (61.4) will appear G series, but no...something wrong or I need to select any specific chassi on it?
Tks
      05-20-2017, 11:14 AM   #46
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Originally Posted by mscalissi View Post
Hello,
Tks
S15A psdzdata covers F090/G001/G002/G011/G012/G030/G031/G032/RR11/RR12/RR31
      05-24-2017, 07:24 PM   #47
mscalissi
Brazil
Drives: BMW 320i GP
Tks
I tried to code Accoustical Locking, showed on iDrive but can't confirm/enable it...any tip?
Bdc only appears as dot, this mean that I need Esys Pro? Psdzdata is 61.4
Tks again
      05-24-2017, 07:27 PM   #48
Almaretto
Almaretto's Avatar
2374
Tks
Tks again
Install 302 Alarm System and acoustic lock will work.
You need to update Launcher. PSdZ is unmapped and update will make no difference as long as you can "Read Coding Data" without error.
      07-13-2017, 11:28 PM   #49
audiogolf
audiogolf's Avatar
40
Drives: 2023 X7 40i
retrofit apple play?
anyway to get this coded, i have 16 750xi g12.
      07-14-2017, 12:43 AM   #50
Almaretto
Almaretto's Avatar
2374
Yes. You need at least Nov '16 software on vehicle; though, latest for best performance. Then, it can be coded and add FSC for full functionality.
      07-14-2017, 07:03 AM   #51
audiogolf
audiogolf's Avatar
40
Drives: 2023 X7 40i
That is great.
if you can please share the details on coding and where do i get the FSC code from?
Also do you have a cheat sheet for G12 as you have done quite a few code mods? if so please share that as well.
Thx.
      07-14-2017, 02:20 PM   #52
Almaretto
Almaretto's Avatar
2374
That is great.
Thx.
PM Sent.
No Cheat Sheet. I use Launcher Cheat Codes.
      10-09-2017, 01:34 PM   #53
solo118
Drives: '11 335i Coupe
Hi All,
Can anybody link me, or attach a list of codes with their function?
Not sure if they are the same as E-Sys cheat codes. I am currently using "Bimmercode" App, and there are many easy codes built in, but I want to get into expert mode and see what I can really do. The problem is that everything more or less is gibberish, so need to understand what everything means.
Thank you in advance!
      10-09-2017, 02:33 PM   #54
Almaretto
Almaretto's Avatar
2374
Originally Posted by solo118 View Post
Hi All,
There are no Cheat Sheets for G-series. Launcher Cheat Codes are written in HTML; they could be used, but not sure if Bimmercode provides storage info.
      10-17-2017, 08:12 PM   #55
2006bmw750li
Drives: 2007 997tt
You guys are very technical being able to do it yourself, I ended up using CodeMyCar, extremely pleased with them.
Glad to be able to turn off DRL on Canadian cars.
      10-18-2017, 10:45 AM   #56
speedracerlo
Drives: 2015 M6 Gran Coupe
I'm still waiting to hear back on how to keep on the Light Carpet on at all times when headlights are on.
      02-19-2018, 07:16 AM   #57
Rowdogz
Drives: G12 740li
Retrfoti 8TH speed limit information
Hi, does anyone know if the 8TH can be retrofitted a 2016 740?
      02-19-2018, 08:14 AM   #58
325_bucks
Drives: F90 M5 Competition
I don't believe 8TH was an independent option on the 7 like it is on the 5, so not sure if it can be retrofitted on it's own or if it needs to part of the driving assistance options
      02-19-2018, 08:22 AM   #59
325_bucks
having said that, if you have the relevant equipment already in the car, I don't know if adding 8TH to the VO would enable it but I very much doubt it would be that simple
      02-19-2018, 10:30 AM   #60
Almaretto
Almaretto's Avatar
2374
Yes. It requires KAFAS3 camera and FSC code plus coding. Alternative is emulator to pull info from maps.
      02-19-2018, 01:07 PM   #61
FastLaneJB
United Kingdom
75
Drives: 2018 BMW M760Li
Are you going to code your new 730d when you get it?
      02-19-2018, 01:43 PM   #62
325_bucks
I probably will be coding a few things yes but it depends on what is enabled as standard or what annoys me etc
      02-19-2018, 05:13 PM   #63
FastLaneJB
United Kingdom
75
Never tried it. Probably nothing much I feel I might want to code though I know you can remove the limiter if you catch the car before it's been running for 10 hours... Might be good for an autobahn run
      02-19-2018, 05:32 PM   #64
325_bucks
There’s only one thing I want to code I think, which is to keep auto start stop off when I turn it off and restart the car. I hate having to turn it off every time I start the car so I coded that out on my 6
      02-23-2018, 06:27 AM   #65
Pelo Cat
United Kingdom
93
Out of curiosity, is it possible to code a June 2016 model 7?
So, for example could one add apple car play and exec drive pro via coding or are there hardware bits needed to achieve this?
What can one code on an earlier model? (point me to a relevant list if there is one and I'll educate myself, not lazy just don't know where to start as it where!)
Is it possible to bring the iDrive system up to the latest version yet? (so 5 to 6)
Thanks for any comments / pointers / advice.
Safe travels.
      02-23-2018, 06:30 AM   #66
325_bucks
Safe travels.
I haven't got myself up to date with what's able to be coded on the 7 yet fully but CarPlay won't be able to be coded, you need to buy it through the connected drive store.
On the 6, iDrive id 5 was able to be coded up to 6, there were hardware differences but I believe it should still work fine. Once I get my 7 I'll be able to give you more information on what's available. I'll see if I can find a list but the lists I saw before were based on US cars which have different things enabled or disabled by default so I'll se what I can find.
