      02-24-2018, 11:31 AM   #89
FastLaneJB
United Kingdom
76
Drives: 2018 BMW M760Li
Originally Posted by Almaretto View Post
Originally Posted by FastLaneJB View Post
Almaretto,
Do you know about coding out the limiter or M Drivers Package within the 10 hour run time window? They don't sell it as an option in the UK.
From what I've read that module is unlocked and then after 10 hours of run time it locks and cannot be changed (Without BMW's private key).
Thanks
Yes. It is VO or FDL option in DME/DDE.
Is this possible on the 7 series? If it just a case of changing the limiter or another option to add to make it think it has the M Drivers Package?
      02-25-2018, 01:41 AM   #90
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Possible on all series. Specific function for top speed.
      02-25-2018, 05:58 AM   #91
FastLaneJB
United Kingdom
76
Thanks for the info, I'll have to research this a bit more then. If I feel confident I'll get myself the software and cable needed.
      03-09-2018, 04:37 PM   #92
emulajavi
emulajavi's Avatar
Spain
422
Drives: MINI JCW F56
You can code Carplay if you have updated firmware and third party FSC.
You can also toggle ID6.
PM Sent.
I have an early G11 with WiFi and ID5.
Can I have ID6 and CarPlay? ConnectedDrive website doesn’t offer CarPlay although my car has the necessary hardware. How can I make the website to offer it? Or how can I enable it?
Thanks.
      03-09-2018, 11:50 PM   #93
Almaretto
Almaretto's Avatar
2374
Can I have ID6 and CarPlay. ConnectedDrive website doesn’t offer CarPlay although my cars has the necessary hardware. How can I make the website to offer it? Or how can I enable it?
Thanks.
Any vehicle with ID5 or ID6 with Nov '17 or later software can have. PM me for details.
      03-11-2018, 01:33 PM   #94
325_bucks
Drives: F90 M5 Competition
Almaretto had a look at the coding today, using latest 4.10.13 psdzdata and launcher 2.8.0 and I could only see 8 ecus. BDC_Body has the cheat code for ASS but it said NA Only and didn't show any FDL in it.
Is ASS memory in BDC_BODY2 or something else? I can't see any DME type ECUs. The only coding I was able to do was add tyre temperatures, I did this to make sure it worked and as I had it before, but it was the only semi useful thing I wanted that I could code.
All I want now is ASS memory, chose the drive mode if possible and auto high beam on as standard.
Thanks for your help or PM me if necessary, please!
      03-11-2018, 03:58 PM   #95
Almaretto
Almaretto's Avatar
2374
You need to update Cheat Codes.
ASS is not done in BDC_Body.
Launcher Pro has updated mapping to be able to code more ECU's.
Drive mode and ASS memory are possible. Auto-HBA is not.
      03-28-2018, 10:36 AM   #96
325_bucks
Seems like TM has updated LP and is responding again? I hope he responds soon, I'd love to get coding
      03-28-2018, 10:00 PM   #97
Almaretto
Almaretto's Avatar
2374
His emails were landing in SPAM, but, yes, new update and he is responding.
      03-29-2018, 09:34 AM   #98
325_bucks
ok thanks, nothing yet but will keep waiting I guess
      03-29-2018, 06:51 PM   #99
paul.j.ghosh
Drives: 2019 M760i xDrive
Almaretto - do you know if support for i-Step 17-11 is coming?
      03-29-2018, 10:25 PM   #100
Almaretto
Almaretto's Avatar
2374
If more than a week or two passes, send follow-up message.
Yes, and 18-520.
      04-02-2018, 09:46 AM   #101
325_bucks
Almaretto,
Managed to get LP 3.1.0. So far only managed to code ASS memory which I thought was in BDC until I remembered that’s not the case anymore.
But I can’t code drive mode as BDC is not showing any information, just . for module 3221 which I think is where the drive mode settings are.
My I step is 18.03.05 (I think). Is this the reason why the data is still trimmed and I can’t see your cheat codes?
      04-02-2018, 11:50 AM   #102
325_bucks
...looking around online it seems (you've said elsewhere) that BDC_BODY2 is actually mapped in the latest Launcher Pro. But I don't see it. Any ideas?
      04-02-2018, 12:58 PM   #103
Almaretto
Almaretto's Avatar
2374
Almaretto,
Install 64-bit Java. Copy contents over to E-sys directly in jre_x64 created folder. Then up memory. Also use launcher settings to remove kiswb that you do not need. Then, BDC_Body should display correctly.
      04-03-2018, 09:40 AM   #104
325_bucks
Thanks, this worked well, and I can read BDC_BODY2 now, however i'm still unsure what to code as i'm aware you don't have cheat codes for drive mode. In the list attached, which module should be coded to change the default startup mode?
Thanks
      04-03-2018, 07:30 PM   #105
Almaretto
Almaretto's Avatar
2374
Fespiadefaultlastusermode
      04-04-2018, 02:28 AM   #106
325_bucks
Yes that's what I thought it would be too but in there I only get the option of Comfort, EcoPro or another option that's in German, I guess it's not yet mapped correctly?
      04-04-2018, 02:32 AM   #107
Almaretto
Almaretto's Avatar
2374
Use werte values to chose desired start option.
      04-04-2018, 02:33 AM   #108
325_bucks
ah I see, well my next question is obvious, do you know if there is a list of werte values that correspond to the drive modes? Thanks for all your help, it's been very useful
      04-04-2018, 02:35 AM   #109
325_bucks
also does setting FesLastFunctionInterval to FF just remember the last mode instead of setting Fespiadefaultlastusermode to default to a specific mode?
      04-04-2018, 02:40 AM   #110
Almaretto
Almaretto's Avatar
2374
Yes, they are listed in other FDL's.
No.
