      03-02-2024, 06:26 AM   #1
77777
Drives: Bmw 750li
Ride height messed up after lift
Hey guys my 2016 750xi g12 was leaking from the front right suspension, had work done on it and obviously the car was lifted during the process. Now I notice during driving the left side goes higher up and the right side stays on default height. When the car is parked overnight both sides are equal. Should I reset the air suspension and how?
      03-02-2024, 10:01 AM   #2
M_Bimmer
M_Bimmer's Avatar
584
While it is highly recommended to run the air suspension ride height calibration using ISTA when replacing air suspension components, you could try and cycle through the manual ride height adjustment several times on your center console, but if that doesn't work, you'll need to perform the height calibration in ISTA.
      03-04-2024, 03:13 PM   #3
g11hoonigan
Drives: BMW 740i
Perhaps you can try resetting by disabling it (hold down the ride height button for at least 7 sec) then re-enable by just driving off. If not, either ISTA or a specific OBDII device with BMW programming, like Foxwell, to calibrate the height.
      03-19-2024, 03:40 AM   #4
77777
Drives: Bmw 750li
I tried resetting but the lights just blink the height doesnt drop like it should after a while error message comes up saying chasis function restricted
