      03-09-2019, 01:37 AM   #1
cowboy750
cowboy750's Avatar
Drives: bmw F02 750LI,E84 X1
Torque specs for the attached??
I'm trying to install a racechip unfortunately the do not have vehicle specific instructions fir the F02.
So in attempting I think the best way is to remove the bars in the attached picture. I don't know the proper name for the bars but I believe it gives the car more stiffness. Anyway I don't know if I I should just tighten pretty snug or if there is a specific torque they should bet tightened any help would be appreciated!!!
      03-09-2019, 12:24 PM   #2
beach48
Drives: 2013 F02 760LI
https://www.newtis.info/tisv2/a/en/
Put details in here to get what your after
      03-09-2019, 01:49 PM   #3
cowboy750
cowboy750's Avatar
Thanks for that link but I need the the actual name to the part and that I'm not sure of...
      03-10-2019, 11:02 AM   #4
beach48
newTIS.infobeta
Home / BMW F02 760Li Sedan / Repair Manuals and Technical Data / 64 Heating and air conditioning / 64 53 Condenser and dryer with lines /
51 61 Reinforcement, body
Tightening Torques
Type Thread Tightening specifications Torque
1AZ
Suspension cross-brace in engine compartment, rear
F01 / F02 / F03 / F04 / F06 / F07 / F10 / F11 / F12 / F13 / F18 M10x47 Renew screws
Jointing torque 30 Nm
Angle of rotation 90 °
F15 / F16 Renew screws
Jointing torque 25 Nm
F25 / F26 M10x25 Renew screws
Jointing torque 56 Nm
2AZ
Suspension cross-brace in engine compartment, front
F01 / F02 / F03 / F04 / F06 / F07 / F10 / F11 / F12 / F13 / F18 M10x25 56 Nm
3AZ
Connection, rear, to carrier support
F01 / F02 / F03 / F04 / F06 / F07 / F10 / F11 / F12 / F13 / F18 28 Nm
4AZ
Connection, front, to connection, rear
F01 / F02 / F03 / F04 / F06 / F07 / F10 / F11 / F12 / F13 / F18 19 Nm
5AZ
Engine compartment lid catch
F01 / F02 / F03 / F04 / F06 / F07 / F10 / F11 / F12 / F13 / F18 M8x20 11,8 Nm
6AZ
V-support to connection, front
7AZ
Air duct, lower, to vertical strut
8AZ
Air duct, lower, to carrier
F01 / F02 / F03 / F04 / F06 / F07 / F10 / F11 / F12 / F13 / F18 M8 8 Nm
9AZ
Air duct, upper, on lock support
10AZ
Trailing link/V-strut on side member
F07 / F11 / F12 / F13 M12 Renew screws
Jointing torque 100 Nm
11AZ
Trailing link to compression strut, rear axle
F07 / F11 / F12 M8 19 Nm
12AZ
Trailing link to cross reinforcement (rear end support)
F07 / F11 / F12 M12 Renew screws
13AZ
Cross reinforcement (support, rear end) to rear end
F07 / F11 / F12 M10x22 38 Nm
14AZ
Cross reinforcement (support, rear end) to cross-member
F07 / F11 / F12 M10 38 Nm
15AZ
Torsion struts/stiffening plate to front axle support
F01 / F02 / F03 / F12 M10 Renew screws
16AZ
Rear trailing link
F10 / F12 M10x40 Renew screws
Angle of rotation 105 °
17AZ
Rear trailing link
F10 / F12 M8x35 Renew screws
Jointing torque 28 Nm
      03-10-2019, 11:05 AM   #5
beach48
https://www.newtis.info/tisv2/a/en/f...lines/1LoYYDX1
THE ENGINE IN PIC IS NOT A 760 ITS v8
      03-11-2019, 12:11 AM   #6
cowboy750
cowboy750's Avatar
Thank you very much!!!!!!
