FORUMS
- 5
| 12-07-2010, 04:21 PM | #1 |
BMW Alpina Enthusiast
Dinan tune Alpina B7 to 573 horsepower !
http://www.dinancars.com/shop/D900-4...ve.aspx#page=1
D900-44TB The top of the line just moved up a notch. This item is worth 2 point(s) towards your Dinan Badge. Price: $3,499.00 Special Product Notes Not applicable for xDrive. See required products. Product Description Propelling it up that notch is the Dinan Stage 1 Performance Engine Software. As always, Dinan matches the new car warranty coverage for up to 4 years or 50,000 miles, including the possibility of consequential damages. No one offers better performance or backs it up with such comprehensive warranty coverage. The Dinan Performance Engine Software safely increases turbo-boost pressure from the stock 14.0 to 18.0 psi, along with properly retuned fuel mixtures, ignition timing and full map rescaling. In fact, over 2000 lines of code have been addressed, producing substantial increases in power output while maintaining the civility and reliability expected of a Dinan performance product. Top Speed Governor Removed. With Dinan’s software, the B7 will be capable of achieving its natural top speed as the governor has been removed. The results of Dinan’s tuning are nothing short of breathtaking, with the added boost and related recalibration producing maximum output of 573 horsepower at 5500 rpm and 644 lb-ft torque at 3500 rpm. Note: When programmed, the pressure sensors in both intercoolers must be replaced with 2x BMW #13 62 7 585 494. Refer to TIS procedures 1362591 and 1362592. These sensors are not included with the software, and must be purchased separately from your BMW dealer. Specifications Labor Hours 1.5 Emission Status This product is in compliance with U.S. EPA Memorandum 1A, or this product has not been found, nor is believed to be, unlawful for use under the provisions of the Clean Air Act. Currently: This product is legal in California only for racing vehicles, which may never be used upon a highway. Max HP Gain 573 hp @ 5500 rpm Max Torque Gain 644 lb/ft @ 3500 rpm Peak HP 68 hp @ 6500 rpm Peak Torque 100 lb-ft @ 3500 rpm Required Products Note: When the car is programmed, the pressure sensors in both intercoolers must be replaced with 2x BMW #13 62 7 585 494. Refer to TIS procedures 1362591 and 1362592. These sensors are not included with the software, and must be purchased separately from your BMW dealer. |
| 12-08-2010, 04:45 AM | #3 |
| Bookmarks |
| Tags |
| alpina b7, boost, chip, dinan, ecu |
| Thread Tools | Search this Thread |
