      02-09-2012, 04:50 PM   #1
eddiedent
Drives: 2013 BMW M5
sprint booster installed
I just installed sprint booster in my 2011 BMW 750 xi M/sport. I am amazed with the response in sport mode. It was an easy install and well worth the investment. After positive results in my M.B. E63 and S55, I decided to purchase it for my BMW once it was made available.
      02-10-2012, 02:38 PM   #2
Djvolume
Djvolume's Avatar
Drives: 2016-X5M 2018-M4 Comp 2024-X5
More info please I'm very much interested as well
www.mgruppe.org
      02-11-2012, 12:11 AM   #3
eddiedent
Drives: 2013 BMW M5
what info would you like?
      02-11-2012, 10:37 AM   #4
Djvolume
Djvolume's Avatar
Well after some reading I actually ordered one as well, do you really feel the difference? Does the unit for our cars comes with the light indicator? Any other info you can provide is much appreciated (instal, setup and such....)
www.mgruppe.org
      02-14-2012, 10:42 AM   #5
BMWrules7
How much?
How hard to install?
Will it void the warranty?
      02-14-2012, 03:22 PM   #6
eddiedent
Drives: 2013 BMW M5
You will definitely feel the difference. I always loved the way my car accelerated in an effortless manor. With sprint booster there's no delay, just a push of the accelerator pedal and the car is gone. I have only tried it in sport mode, not race mode, which is more than enough for me. The cost is $329.00 from sprint booster's web site direct. It comes with a lighted wire that changes color dependent on the mode. You can set the mode and disconnect the wire if you chose. I hid the wire in the lower center dash compartment. As far as warranty is concerned, you can set sprint booster to stock mode if you need to visit the dealer. I installed the unit in less than 15 minutes hiding the unit behind the carpet where the factory wire is attached to the accelerator pedal.
      06-07-2012, 03:11 AM   #7
mbworldz
Drives: 2011 535i
I used to have the sprint booster installed on my 2008 E63 AMG, Since I got the 2011 BMW 740i, I thought when using the Sport + settings, it revs higher and response quicker.
So when you installed the sprint booster to the 750, it won't affect the sport + mode?
It will make it more responsive ?
      06-07-2012, 08:13 PM   #8
X5MC_LI
Drives: 2021 X5MC
Best $300 ever spent. Comes with the light indicator and 3 settings.
Stock, semi aggressive and aggressive. Highly recommended.
Amazing difference
      06-08-2012, 05:41 PM   #9
mbworldz
Drives: 2011 535i
What if you select comfort mode and have the sprint booster set to RED most aggressive settings? Comfort mode starts with 2nd gear, will that sprint booster help ?
Amazing difference
      06-08-2012, 09:43 PM   #10
X5MC_LI
Drives: 2021 X5MC
Absolutely. It helps with every gear and as described by someone else above gives u an instantaneous throttle response each and every time. I have a chip and the sprint booster installed and it does a burnout from 1300 rpm which is when the turbo kicks in. Amazing.
      06-11-2012, 12:12 PM   #11
Needsdecaf
Needsdecaf's Avatar
6509
Drives: 2024 G80 Comp xDrive
Selling my Sprint Booster here: $275 shipped.
http://f10.5post.com/forums/showthread.php?t=703986
Search this Thread:
Advanced Search
