      08-27-2012, 01:30 PM   #1
gatordent2007
Drives: 2020 x7 M50i
2016 BMW 750xi  [0.00]
body kit and wheel suggestions
Hi Guys,
Picked my car up almost 2 months ago. After seeing some of the things some of you have done to your cars, i was wondering if anyone has suggestions as far as body kits and who you would trust to make sure it is installed properly. I generally like the way mine came stock, but some of the ones ive seen with either the msport package or alpina kits look really good too. Also, i know certain wheel sizes can have "rubbing" problems. Is it safe to say that 21" are the largest to go without having to worry about it? Thanks for any suggestions.
      08-27-2012, 01:38 PM   #2
Max7SD
Drives: 2012 BMW 750i
Central Florida? Are you near Orlando? I know a guy that can hook you up with all sorts of good parts and deals... I also know the best BMW master tech in the area to do all the install work. Let me know.
Max
      08-27-2012, 02:50 PM   #3
gatordent2007
About an hour and a half away, shoot me his contact info. Thanks
      08-27-2012, 03:36 PM   #4
Rob@StrasseWheels
Rob@StrasseWheels's Avatar
458
Drives: 2023 BMW G80 M3 Comp
You're not too far from us!
Give me a ring at (305)303-1190 and I can get you wheels, tires and even recommend you to the best body shop in town!
@Strasse_Robert | (786)701-3649 | Robert@StrasseWheels.com | www.StrasseWheels.com
      08-27-2012, 05:00 PM   #5
335ifanatic
335ifanatic's Avatar
51
Drives: Revuelto, Urus Performante, X5
You can look at the AC schnitzer kit or Hamann but both are expensive and imo don't really flow well with our cars (http://www.schmiedmann.com/7_series/..._-_outside.htm).
I currently have the Alpina front lip, it gives the car a nice, aggressive look.
      08-28-2012, 06:36 PM   #6
Tfk
Drives: Citrin Black M3
food for thought:
-m front and rear bumpers
-rd sport front lip spoiler
-ac schnitzer rear trunk lid spoiler
-BMW style 312 21" wheels in either silver, or ferric grey
p.s. i had the same 20" wheels on my 750 when i first bought it. i changed to OEM 21" and i kid you not; the difference - in comfort - was night and day (in the most negative sense possible.) in my opinion, the improvement in aesthetics doesn't balance the scale at all to be honest.
god knows what going up to 22's would be like!
and another thing you might want to consider is changing the chrome mouldings you have around your windows to the 'shadowline' ones.
good luck..
      08-28-2012, 09:12 PM   #7
gatordent2007
thanks for the suggestions. i was actually considering that style of wheel. Is that the one you went with that caused a rough ride? where is the best place to order the m sport parts?
      08-29-2012, 03:13 AM   #8
335ifanatic
51
You can get the full m package from the site sponsor;
http://www.trademotion.com/partlocat...egoryID=173161
You really can't go wrong with the m sport package, so clean and elegant and really makes the front end of the car pop.
One thing I might suggest is go for the front m sport bumper only, the rear is basically the same as the OEM one and because your car is black you won't be able to tell the difference between the m sport rear and OEM rear. I would only get the rear if I had a white 7er because the lower exhaust piece is black and it gives it a nice contrast.
      08-29-2012, 03:38 PM   #9
Ryan@IND
Ryan@IND's Avatar
Drives: ACR
Vorsteiner also has a very nice looking kit
IND DISTRIBUTION | 866-963-4520 • INSTAGRAMFACEBOOKFLICKR
      08-30-2012, 07:20 AM   #10
Tfk
i went with 21" style 238 - for the so called "classy look" - fail.
i've tried two other 21" oem wheels on friends' cars - same "rough ride" problem.
i've since upgraded to m sport bumpers, so now it's too late to go back to 20" wheels; just won't look right.
i'm told that it might be the oem 'run flat' pirelli tires that are the trigger, as opposed to the wheels.
next week, i'm changing to 21" style 312 wheels, only this time with non-oem, non-run flat Michelin tires. only way to go this route is to buy wider tires (10mm wider on front and rear).
      08-30-2012, 09:33 AM   #11
gatordent2007
let me know how it goes with the 312 wheels, i really like the look of those.
      08-30-2012, 08:23 PM   #12
Rob@StrasseWheels
458
Check this out:
http://www.7post.com/forums/showthre...strasse+forged
      09-03-2012, 09:58 AM   #13
NlckyBlack
NlckyBlack's Avatar
Greece
69
Drives: Too many cars
you also need some shadow line trim
15 E63s
15 991tt
17 GC SRT
      09-03-2012, 10:03 AM   #14
gatordent2007
Shadowline trim is not my thing, I like the contrast on the car. Also not really part of what this thread was about either.
      09-03-2012, 04:59 PM   #15
335ifanatic
51
Shadowline looks good for a white 7er but I wouldn't put it on a black 7er, it looks cheap.
Search this Thread:
Advanced Search
