11-21-2023, 11:24 PM | #1 |
Rep 3
740Li F02 - Kafas or FLA
Hi there,
first of all this is a Thailand assembled car (KB45), which I'm considering to buy. I'm a bit confused because based on mdecoder VIN analysis this 2009 F02 has: 524 Adaptive Headlights (pre-LCI, so Xenon) 5AH Decoding Dynamic Brake Light 8S1 Daytime Running Lights Decoding 8S4 Decoding Variable Light Distribution 8TD Decodierung Speed Limit Info So can I conclude it should have the KAFAS camera, but they disabled by decoding SLI and adaptive headlights (8S4)? pdf in below link seems to suggest 7 series F01 comes standard with KAFAS? https://f15.bimmerpost.com/forums/at...mentid=1235072 On bimmercat I can find the KAFAS camera, but then again, it also shows the ACC radar, which my car should not have since it does not have ACC... https://bimmercat.com/bmw/en/search/...Li/THA/66_0171 If it has KAFAS, I can code to enable VLD and SLI? will I need to purchase a FSC code? (if so, any clue how to get it?) Probably will also try to get LDW coded. The car gives Adaptive Headlight failure alarm, tomorrow will use Bimmerlink to scan all error codes... Most likely will install aftermarket Adaptive LED headlights from aeroformthailand, hopefully that will fix that. Big thanks for any advice, Cheers, M |
