Go Back   7Post - 7 Series Forum > BIMMERPOST Universal Forums > Classic BMW (Pre-2005 Models)
      05-16-2023, 08:42 AM   #353
Chihuahua
Chihuahua's Avatar
5394
Drives: E30 329iS, E65 Alpina B7
Originally Posted by Tommysalami View Post
You may want to consider resetting the EDC. In a scan tool under service/chassis/electronic damping control K, or in ISTA, select "Adjustment, shock absorber" and run it for both axles. The EDC system tracks the car's mileage and make the shocks stiffer over time to compensate for wear, making new shocks feel harsh after replacement. I installed the same B6 damptronics after 70k miles on the chassis and they were skipping and losing traction over small bumps. It was noticeably better after resetting.
From some technical documents on the E65 where I guess this system was introduced:
https://www.meeknet.co.uk/E64/09_E65...20Dynamics.pdf
From Page 20
Tolerance Adaptation
The damper force is diminished as part of the operating time function. Diminishing damper forces are compensated by current (amperage) reductions which are calculated by the tolerance control. This also individually compensates for mechanical damper wear on each axle.
And from page 23
Mechanical wear causes the dampers to weaken over the service life, therefore a running time memory adapts the damper curves towards a harder setting (over time). Faulty dampers must be replaced together (in pairs) on a single axle. After a replacement, the running time memory for the front or rear axle must be reset with the DISplus.
May also apply to your Alpina?
It shouldn't, the B7 doesn't have EDC. Alpina used Eibach lowering springs and the same Sachs dampers that BMW put on the E65/E66 sport models. There's only one damper option for the B7 unless you want to go with coilovers (blasphemy).
      05-16-2023, 06:32 PM   #354
toxik
toxik's Avatar
Drives: 2017 340i xDrive 6MT
anyone else curious about the e93 m3 vert that sreten mentioned in one of the recent episodes. did he buy a whole car just to take the motor for his e92? it didn’t even look crashed… but maybe i’m wrong.
      05-17-2023, 02:00 AM   #355
Tambohamilton
Drives: E91 330d
Sreten doesn't like sunroofs, so I can't see that he'd be too precious about a vert. Also useful to have a whole parts car
      05-17-2023, 02:06 AM   #356
Mani59
Moderator
United Kingdom
22064
Drives: F87 LCI M2 & G26 i4 35
The E93 M3 is indeed a parts car. A little more information on that in the next episode
Visit my (mostly) BMW Gallery here or my BMW Miniature Model Collection here
Almuliman566.50
      05-18-2023, 10:04 AM   #357
Mani59
Moderator
United Kingdom
22064
And here is Part 3 of Project Frankfurt (E92 M3).
      05-18-2023, 11:23 AM   #358
NikMN
NikMN's Avatar
Drives: BMW 550i
2015 BMW 550i   [9.25]
Sweet.
      05-18-2023, 11:31 AM   #359
WrathOTM
WrathOTM's Avatar
742
Drives: BMW 128i
hey just what I was asking for
Mods to date: The list grows...
      05-18-2023, 12:30 PM   #360
WrathOTM
WrathOTM's Avatar
742
Drives: BMW 128i
Also Sreten Next time you do a tear down, tap on each piston to see if you have a "disconnecting rod".
      05-19-2023, 09:21 AM   #361
Tambohamilton
Drives: E91 330d
Pretty clear what happened there: the first main bearing spun, because s65. Owner kept driving, as it deteriorated further and further... That bearing got so loose that the nose of the crank started to flex a lot. This probably caused a lot of wear on 1 and 5 rod bearings, and destroyed the front main seal...but the owner kept driving. Eventually the front main bearing got so loose that the flex was enough to break the crank. Only then did the driver take notice. I bet it was driven for hundreds of miles, eating the front main bearing, before the crank snapped. Heat doesn't really factor in the crank failure at all, though for sure there would have been a fair bit generated. Special.
F32Fleet4236.00
M3_Legend546.00
      06-09-2023, 09:34 AM   #362
Mani59
Moderator
United Kingdom
22064
The next episode of Project Rottweil (E39 530i Touring) is now available.
Plus a special guest appearance of the lovely E39 M5.
      06-09-2023, 11:41 AM   #363
Chihuahua
Chihuahua's Avatar
5394
Awesome, will check it out tonight.
Meant to ask earlier in this thread, going back to the B7 Sreten mentions some company in Czech Republic that does a lot of E65 stuff (it's Jarex or Yarex I think? not sure if I'm spelling that correctly). Does anyone have any info or a link to this place? I'd like to check them out (no pun intended
Also, does anyone happen to know what phone mount he's using in the E65?
M3_Legend546.00
      06-09-2023, 06:46 PM   #364
WrathOTM
WrathOTM's Avatar
742
Drives: BMW 128i
yay, something to watch over dinner!
      06-10-2023, 11:06 AM   #365
M3_Legend
M3_Legend's Avatar
Drives: BMW E90 & F31
2009 BMW 328i  [9.67]
2013 BMW X5  [0.00]
2009 BMW M3  [10.00]
I think this is the link it’s on http://www.falconfix.cz/?lang=en it’s on part 15 of project Chicago.
2009 E90 M3 DCT Space Grey current
2005 E53 X5 3.0 Alpine white sold
2008 E90 M3 6-speed Jerez Black sold
2008 E90 335I 6 Speed Black Sapphire M-sport sold
2006 E53 X5 Black Sapphire sold
2011 E91 Silver Automatic sold
2006 E91 Silver Automatic sold
2007 E91 Black sapphire 6 Speed Manuel current
Mani5922063.50
      06-10-2023, 12:07 PM   #366
NikMN
NikMN's Avatar
Drives: BMW 550i
That M5 is perfect.
      06-10-2023, 03:16 PM   #367
Chihuahua
Chihuahua's Avatar
5394
thank you!
      06-15-2023, 10:57 AM   #368
toxik
toxik's Avatar
New video, I'm sure all the Colourlock enthusiasts will enjoy this one:
Mani5922063.50
      06-15-2023, 12:07 PM   #369
Mani59
Moderator
United Kingdom
22064
I will absolutely be using a Colourlock specialist when I get round to restoring the leather in my E38.
      06-15-2023, 12:25 PM   #370
Chihuahua
Chihuahua's Avatar
5394
Woot! Will watch tonight. Looking forward to the Alpina factory tour and S65 content
      06-15-2023, 01:28 PM   #371
Jbrown7403
Jbrown7403's Avatar
Drives: 2016 BMW M4
Really interesting episode!
      06-16-2023, 11:59 AM   #372
swagon
swagon's Avatar
Drives: F80 6MT
I've got their stuff and they work a treat. I don't trust leather products from brands that sell anything from wheel cleaners to leather dyes
Mani5922063.50
      06-16-2023, 04:44 PM   #373
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
https://www.youtube.com/watch?v=t7b4mopGWGU
So Colourlock applied some sort of two-pqrt urethane coating? How will product get past the coating?
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      06-16-2023, 06:25 PM   #374
toxik
toxik's Avatar
maybe i misheard or misunderstood, but they said during the cleaning process to never spray the cleaning foam on the leather because leather shouldn’t get wet, you only spray it on the brush so you’re essentially cleaning to top layer of oils living on top layer of the leather. i don’t think the cleaner is supposed to penetrate the leather? i also know the leather protector and leather shield act like a wax or ceramic coat, where they don’t penetrate but just create a layer of protection against dye transfer or minor damage.
again i could be completely wrong but that’s how my brain understood it.
F32Fleet4236.00
