M2 Technical Topics > Wheels / Tires -- Sponsored by The Tire Rack > M4 CS Wheels on M2C
      04-28-2020, 01:16 AM   #23
Jack yang
China
20
Drives: 2020 M2C
Originally Posted by Got f1? View Post
Running what was OEM; MPSS. I bought them with 2200 miles so it came with tires and TPMS.
Hey one more question
Can you reuse the stock TPS? And do you use spacers on 763M? Since they have a different offset with the stock 788m
      04-28-2020, 02:27 AM   #24
Bee Pee
Bee Pee's Avatar
United Kingdom
1788
Drives: AW M2 DCT
763m have same width/offsets F&R as 788m/437m
Fettled M135i EB AT then AW M2 DCT - both gone but not forgotten:
Current '22 X3M LCI..
      04-28-2020, 04:43 AM   #25
Jack yang
China
20
Drives: 2020 M2C
Thanks for replying me
I thought 788m has Front 19*9.5 ET25 Rear 19*10 ET35
I know 763m has Front 19*9 ET29 Rear 20*10 ET40
      04-28-2020, 04:49 AM   #26
Bee Pee
Bee Pee's Avatar
United Kingdom
1788
Drives: AW M2 DCT
No - 788m are same as 763m width/offset specs you wrote above
      04-28-2020, 05:33 AM   #27
Jack yang
China
20
Drives: 2020 M2C
Huge thanks
      04-28-2020, 02:18 PM   #28
Got f1?
Got f1?'s Avatar
Drives: 06 E46 ZHP, 20 X3M, M2CS
Same offsets and I did not use spacers and reused TPMS after pairing to car by resetting them via iDrive and then driving around for a couple miles.
      04-28-2020, 04:56 PM   #29
Jack yang
China
20
Drives: 2020 M2C
Thanks for sharing!
      05-03-2020, 10:03 AM   #30
Rick4345
Rick4345's Avatar
473
Drives: 2022 WRX World Rally Blue
This is a bit clearer but still not as good as in person.
Personally I like the BMWCCA grille badge!!
Rick
Got f1?684.50
      06-30-2020, 12:55 PM   #31
RARZED4
Drives: MerlinTiCx
CS Wheels on M2C with MP coilovers
I bought mine through the M3/M4 marketplace on here. Keep in mind that while the CS wheels are the same for M3 and M4, the stock tire sizes are not. M3 has 265/35 19 front and 295/30 20 rear. M4 is one width size smaller at 255 & 285. I have the latter so fits just fine.
You can go to 295/30 in the rear but 265/35 will likely rub in front.
Any known issues with running this setup, CS wheels in 255 & 285, with MP coilovers?
      06-30-2020, 05:57 PM   #32
Got f1?
Got f1?'s Avatar
To my knowledge, no issue with running MP.
      07-18-2020, 05:56 PM   #33
jase2addict
Drives: 2021 M2Comp
I think the 20 in the rear looks more aggressive. Love that look. If I got the m4cs wheel I would lower the car using something something other than M performance will I rub? Those who have these wheels, did the car handle any different with these rims. This will be my first Mcar and I don't want ruin the magic of the driving experience just for looks. Please give me your thoughts and opinions. Thank you.
      07-19-2020, 12:01 PM   #34
Got f1?
Got f1?'s Avatar
I am lowered to same recommended specs for M Performance on these wheels. No rubbing now or before the coilovers. There are benefits to the reduced weight from the stock OE 788M wheels. I believe around 3-4lbs per corner. No regrets here.
      08-07-2020, 10:59 AM   #35
RARZED4
Drives: MerlinTiCx
I'm concerned about the clearance with the M Performance Coilovers; I've heard the front springs are/maybe a little larger than other options. Just wondering if the 265/30/19 on OEM rims will clear the springs.
      08-07-2020, 08:27 PM   #36
Got f1?
Got f1?'s Avatar
I assume you are thinking 265 on fronts? I haven't personally done that but I don't see an issue. My setup is 255/35 in front on Ohlins dampers with TC Kline springs.
m2
