02-06-2015, 10:05 AM | #23 |
Fitness Gene
1119
Rep 2,417
Drives: 2018 M4
Garage List 2006 bmw m5 [10.00]
2016 bmw z4 35is [8.33] 2000 bmw m5 [10.00] 2018 BMW M4 [10.00] 1987 BMW 325 Conver ... [10.00] |
awesome document! thanks!
Effective 11 Min Home Workouts????? No equipment????? 20 years of experience Spartan Race winner PROtrainer! Click the link?? https://www.youtube.com/c/FitnessGene |
02-06-2015, 10:21 AM | #24 | |
Joint Chiefs of Staff
4927
Rep 116,037
The JB4 also has a second mechanism for setting fuel targets in the form of an o2 sensor signal bias. Although this isn't used yet on the S55 as it hasn't been needed. It's there ready to go if/when it is though. Mike |
02-06-2015, 10:24 AM | #25 |
4927
Rep 116,037
It looks to me this worksheet is going off the rails a bit. I'd suggest removing any vendor provided marketing information and focusing on the technical aspects of the various units. And to really do that you need someone with a technical mind to edit and verify the worksheet. Certain elements of the sheet don't make technical sense as is.
Just a couple notes off the top of my head: 1) If you're going to post dyno information then that would need to be measured using standardized 3rd party dynojet results. Like, dynos done at EAS whch is a 3rd party dynojet. 2) Throttle control isn't a technical connection or plug. The JB4 can do unique things with the throttle other non-CANbus tunes can't but that is beyond the scope of my post. It should be removed from the sheet I think. 3) The JB4 & Stage1 both offer "valet mode" (e.g. being able to disable the tune by changing to map 0). 4) ESS does not have logging software nor would there be much to log without CANbus. 5) Adding certain features makes sense. For example: Ability to read/delete hidden tuner detection codes. Ability to reduce torque in 1st and 2nd gear to assist with traction. Ability to change maps from the drivers seat. Ability to update firmware at home. Just to list a few off the top of my head. Mike |
02-10-2015, 01:55 AM | #27 |
Rep 2,379
The ESS will is able to support a bigger turbo like the Pure upgrade for the N55 according this short Q&A. Maybe that is something to add to the list too..?
http://f20.1addicts.com/forums/showt...light=e-tronic
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
02-10-2015, 02:42 AM | #28 |
Sunburnt Member
158
Rep 525
Can we please add a "Boost (PSI)" Row to this spreadsheet?
I think that's one of the most important comparison factors here, as the higher claimed products could simply be running the turbos harder.
2019 Deep Blue Tesla Model 3 Performance | 2015 Mineral White F82 M4 | 2010 Burnt Orange Lotus Exige S2
Past: 2009 Ibis White S5 (APR Supercharged V8) Past: 2004 Imola Red M3 Convertible |
02-10-2015, 10:23 PM | #29 |
Rep 105
Updated, added, deleted, organized.
Not sure how to add boost PSI as the boost varies through RPM considerably, and also with various maps. |
02-11-2015, 12:54 PM | #30 | |
BimmerPost Supporting Vendor
24477
Rep 191,448
I recommend not adding Booost psi on each tune, since you can just adjust it on most of these tunes and get more power. Also by adding claimed power you are guarantying that this topic will get derailed and turn into a tuner war. I recommend just sticking with technical details and how each tune is different than the other. Also, i see that you have all the tune not street legal except Dinan. Not sure how correct that statement is. All the tunes on that list will pass emission no problem.
02-11-2015, 07:18 PM | #31 |
Rep 3,396
Maybe just add it as a max figure for each tune listed. Be nice to know how hard the turbos are being pushed past factory.
02-11-2015, 08:34 PM | #32 | |
Sunburnt Member
158
Rep 525
Which is exactly why boost levels and AFR are so important when comparing these options.
Past: 2009 Ibis White S5 (APR Supercharged V8) Past: 2004 Imola Red M3 Convertible Last edited by Merli; 02-11-2015 at 08:46 PM.. |
02-11-2015, 08:37 PM | #33 | |
Sunburnt Member
158
Rep 525
I may very well be gravely mistaken, but I doubt many of these piggy backs alter the boost ramp rate (partial wastegate actuation), and just alter peak boost targets, and let the ECU figure out how to get there fastest as per factory tuning. I've only read of one piggyback that has altered the boost curve to lower boost at lower RPM.
Past: 2009 Ibis White S5 (APR Supercharged V8) Past: 2004 Imola Red M3 Convertible Last edited by Merli; 02-11-2015 at 08:47 PM.. |
02-11-2015, 08:37 PM | #34 | |
24477
Rep 191,448
Example JB4 boost can be adjusted to whatever target you wish. Not just by using the already available maps, but you can also create your own map.
02-11-2015, 08:39 PM | #35 | |
24477
Rep 191,448
Some of tunes in that list control boost per 500 rpm
02-11-2015, 08:47 PM | #37 |
Rep 105
02-11-2015, 08:53 PM | #38 | |
Sunburnt Member
158
Rep 525
To me, boost and AFR are absolutely key pieces of information. One company claims +50whp, and another claims +65 whp? HOW? By running an extra 1psi? Oh okay then... But +15hp while running the SAME boost? Well then I want to see the AFR and ignition timing maps. Are those extra 15hp "safe hp", or are they toeing the line a little too closely for my liking?
02-11-2015, 08:57 PM | #39 |
Sunburnt Member
158
Rep 525
Very cool... Thanks for the clarification!
02-11-2015, 09:05 PM | #40 |
Rep 105
Take everything I say with a grain of salt, but I think that only 3 of these make an attempt at correcting the AFR as opposed to letting the native ECU adjust it for the added boost:
1) JB4 through CANbus 2) ESS through MAF 3) Dinan through any way they want since they can potentially access every ECU input. Last edited by pigwet; 02-11-2015 at 11:02 PM.. |
02-11-2015, 09:12 PM | #41 | |
4927
Rep 116,037
The JB4 is able to tune from stock up to 36psi, the limit of the TMAP sensor. So talk of peak HP, peak boost, etc, is sort of irrelevant. Mike |
02-11-2015, 09:59 PM | #42 | |
Sunburnt Member
158
Rep 525
From the information readily available on this site, it is evident that the JB4 is the most capable and scalable of piggybacks currently available. That's great. It's also evident that you're a retailer/site sponsor, who's flagship product on your website is indeed the JB4. If your point is that the JB4 can run custom maps, and can support up to 36psi boost, and because of that we shouldn't compile peak boost data as a comparison point, I'm afraid that your JB4-biased presence in this thread is limiting it's effectiveness, in delivering relevant comparable data to the consumers.
02-11-2015, 10:49 PM | #43 |
Rep 105
Can you perhaps discuss why ESS would be using MAF without also using fuel mass? AFR is a ratio. If you want to alter it, you can alter the numerator, the denominator, or both. No?
02-12-2015, 05:51 AM | #44 | |
4927
Rep 116,037
To use a more specific example, one could run the JB4 on map 3, which will produce less peak boost and HP than the BMS Stage1 tuner does. On the other hand, the JB4 with its extra control is capable of safely tuning up to the TMAP sensor limit while the Stage1 with its MAP sensor only inputs should only be run up to +4psi over stock. Although, one could crank it up to 8psi over stock for a dyno run, and maybe produce a big number, with increased risk. This talk of peak boost and peak HP only becomes relevant when discussing flash maps or tunes that are not adjustable, IMHO. Mike |
