01-05-2018, 12:33 AM | #23 |
Rep 907
Hmm this sounds good, The I3 needs improved traction ASAP.
Was driving around with my fathers I3 he has one of those first models that came out, and this car got some serious torque when it comes down to flooring it, but the grip is just awful obviously its not a sports car in that terms but it is a very quick car none the less when it comes to acceleration, but right now during winter times here in Sweden it just dons't have any grip at all, you really have to be careful when driving away or it will spin you out even though it has DSTC on and such stuff. So this sounds like good news for those who are planning och buying an I3 later on for a commuter car. |
DeeKay556.00 |
01-05-2018, 04:09 AM | #25 |
Rep 986
Better and newer tech is always welcome. Why this is seen as negative is beyond me...
3 series: E30: 89 325i, E36: 92 325iC, 94 320iC, 96 320i Convertible, 94 320iaC, E46: 99 320ia, E90: 06 318i Le mans, E91: 07 318dt
5 series: E39: 97 520ia, 01 530Dat, E61: 09 520Dat X series: E83 05 X3 2.0d, E84 10' X1 2.0 X-drive DA, F25 13' 2.0da X-drive. |
01-05-2018, 05:41 AM | #26 | |
Rep 9,134
01-05-2018, 06:44 AM | #27 | |
Retired BMW Genius
2932
Rep 3,404
01-05-2018, 08:25 AM | #28 |
873
Rep 3,992
Seemed to go through the wet water pad pretty composed!
M3 Adjuster7909.00 clbmw641.50 |
01-05-2018, 09:48 AM | #30 |
Rep 11,785
01-05-2018, 11:05 AM | #31 |
Retired BMW Genius
2932
Rep 3,404
How do you know?
01-05-2018, 11:19 AM | #32 |
Rep 9,134
01-05-2018, 11:22 AM | #33 |
I /// M FAN
435
Rep 427
There is a lot of confusion between Traction and Grip. Having a four wheel drive doesn't mean that you will have more grip, more traction yes...at the end all car have 4 little grip surface between the rubber and the road...so tire's quality, road surface and center of gravity are the only factors are really influence the grip...and if you have more grip you have more traction...the reverse is not true.
01-05-2018, 12:27 PM | #34 |
Retired BMW Genius
2932
Rep 3,404
That's what I thought.
01-05-2018, 03:19 PM | #35 | |
Rep 533
In a vehicle with an open differential (i.e. any bmw that isn't a proper M), the wheel with the least traction will get majority of the torque. If you have one wheel on ice and the other on pavement, the wheel on ice will be the path of least resistance and will be the only wheel that will get power. The car will not move forward because the wheel with traction has no power. Traction control works by applying the brake to the wheel which has the least traction in order to re-direct power to the wheel that has more. It is slower to react than a limited slip differential, and eats the rear brakes. A limited slip differential limits the amount of slip a single wheel can experience ensuring that the wheel with traction has at least some grip. That's why having an LSD to react instantaneously coupled with traction control to fine tune the ratio is the best solution. You know, kind of like how the M cars work. Last edited by wknddrivr; 01-05-2018 at 03:41 PM.. |
Roch M4435.00 MalibuBimmer964.50 |
01-06-2018, 02:16 AM | #37 | ||
Rep 9,134
This programable technology is beyond the common LSD or a M-LSD.
It's extremely fast acting and can be enhanced to act like a performance differential. Quote:
01-06-2018, 07:31 AM | #39 |
Rep 159
What my friend is trying to say is that it is a simple case of the more grip you have the less traction "control" you need.
My R34gtr v-spec has electronic centre diff and electronic rear diff and no "traction control" By moving the power to the right place in the drivetrain at all times using information from steering angle, yaw rate, and g-force sensors it makes split second calculations and the end product is a shit load of grip and virtually no slip in virtually all weather. Note: i am not suggesting that performance bmws should be 4wd. I am simply saying that grip is everything. |
01-06-2018, 10:28 AM | #40 |
Rep 3,458
Drives: Harrop E90 M3
01-06-2018, 10:30 AM | #41 |
Rep 3,458
01-06-2018, 11:30 AM | #42 |
Rep 1,615
It might actually be beneficial to some; especially for folks in the north that tend to get lots of snow. I damn near got stuck in my driveway yesterday with the OEM runcraps and XDrive so anything extra could've helped haha
Originally Posted by jmg
That seat was meant to be used, are you going to deny it's purpose in life? |
01-06-2018, 12:02 PM | #44 |
Rep 1,615
Haha haven't heard that one before I'm allowed to like one nanny but not another... especially the sexy ones Had RWD, been there done that and in the NE, I prefer to play with xDrive
sygazelle12419.00 |
