      05-23-2018, 10:39 AM   #23
tuco44
tuco44's Avatar
Drives: 2018 340i xDrive M Perf Edtn
I use the slider all the time in winter. Not so much in the summer as it is permanently on cold max. Works well, and is a simple concept.
Not sure why so many don't like it...???
2018 340i xDrive M Perf Edtn Sunset Orange
Previous BMWs - 19 others since 1971.
      05-23-2018, 10:59 AM   #24
BEM-S4
BEM-S4's Avatar
Drives: Dinan M235, Dinan Sport Wagon
Try going back to an E70 I love my winter beater but instead of a wheel in the center of the dash you have to navigate down a few levels in the climate system and adjust for each zone.
I'd kill for a wheel.
2022 Macan S
2016 F31 328i xDrive Sport Wagon
2006 E46 330ci ZHP Convertible
      05-23-2018, 11:21 AM   #25
afadeev
afadeev's Avatar
1186
Drives: F80 M3
Originally Posted by TheSpungos View Post
Per my BMW Genius appt last week: it changes the temp of the air blowing from that vent by +/- 5 degrees. So it you have your climate control set to 70 and you turn it all the way blue, the air from that vent will be approx 65 degrees. All the way red and it will be approx 75 degrees.
It has definitely been more than +/- 5 degree change on all my bimmers, once you turn the face blower temp wheel.
In the winter, turning into max "blue/cold" range give you a blast of freezing outside air in your face, regardless of HVAC temp setting.
Basically, the dial is a simplified version of multi-level/multi-zone temperature controls you will find in a Rolls. But way simpler, and covers 99% of the needs.
Very helpful.
Most people like it, once the understand how it works (well described in the manual, that few read).
Few people don't understand how it works, so we share our experience on this forum. Then they get it.
And then there is an obligatory guy who just loves to hate stuff.
Pick a feature, wash-rinse-repeat.
a
'19 TM3P (BK/BK)
'15 F80 M3 (SO/SS)
      05-23-2018, 11:27 AM   #26
rackjuediger
rackjuediger's Avatar
Drives: 2013 328i 6mt
2013 BMW 328i  [0.00]
I find it most useful when my temperature is set at 70-75 degrees. If its cold out, I slide it to red, when its warm, I slide it to blue.
F30 328i 6mt
Injen, ER, BM3, Solowerks, IND, BMS, BBS
E46 M3 smg2
Bimmerworld, H
      06-04-2018, 01:04 PM   #27
zuckuss07
Drives: F30 328i M 6-Speed
I use the slider all the time. I keep my temp set to 70* usually. I use the slider to blend in some heat or some cool air at night. It takes a second. I think it's a great feature.
      05-24-2024, 06:37 PM   #28
Bluehardtail
Drives: BMW X3X5650750
Originally Posted by AlpineWhite_F80 View Post
Its more to fine tune your A/C.
I have never used mine, it is always in the blue side. Like the previous post said some love it and some find it it useless, i find it useless .
Sandro
I reason for this is to blow cold air on your face to keep you alert. Nobody on here gets it. The 21 bmw have this feature buried under five different menus. I adjust this everytime I drive. It’s a pain in the neck to do while driving. You can’t even set a shortcut for it. So stupid of bmw.
      05-24-2024, 06:39 PM   #29
Bluehardtail
Originally Posted by RickFLM4 View Post
As indicated in the manual, it changes the temp of air blowing out. For me it is useless and always on blue unless someone touches it when they aren't supposed to touch it. You will get some responses from people who love it but to me it is completely unnecessary.
How about in the winter. Do you like cold air coming out when you are cold?
      05-24-2024, 06:40 PM   #30
Bluehardtail
Try that driving in a 21 bmw. 5 menus to change it in idrive 7! Lousy design.
      05-24-2024, 06:45 PM   #31
ADHD
ADHD's Avatar
Drives: F30 328i
21 M540i  [0.00]
07 e90 335  [0.00]
U do relize your commenting on a 6yr old post ya??
RickFLM411521.50
      05-25-2024, 05:48 AM   #32
CSBM5
CSBM5's Avatar
2846
Drives: 2019 M2 Comp, 2011 M3, etc
If you have iDrive 8/8.5 (2023+ car with only screens), you can create a shortcut to it, but not in the way you'd expect. Go to the main climate screen and press and hold the "settings" icon. Now it shows the option to make it a short cut. If you go into the actual settings screen that shows the blue/red slider, you can't get it to make a shortcut there (which is odd).
Current Stable:
2024 G20 M340i Melbourne Red/Cognac
2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg
2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8
      05-25-2024, 05:49 AM   #33
RickFLM4
RickFLM4's Avatar
Drives: M4
Yes since I live in Florida. If I didn’t I would have the heat on, which should normally switch to warm air without the need for a wheel. I still think it is a useless function but thanks for asking all these years later.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82
