05-20-2022, 08:46 PM | #441 | |
Rep 4,008
Drives: M235i, 420i, and now the M2 CS
Now, a dot appears on the bottom RHS of the screen and you have to hit it to see the entire post. It's similar to the feature where you have to tap an embedded link inside a post to see images
M2CS,
The second coming of ///M! |
apptest4584.50 |
05-20-2022, 08:48 PM | #442 | |
all I do is test!
4585
Rep 998
Drives: I lost count of how many
Test 23456rt
MadBimmeRad7134.50 |
05-20-2022, 08:52 PM | #443 | |
Rep 4,008
Now, a dot appears on the bottom RHS of the screen and you have to got it to see the entire post
M2CS,
05-20-2022, 08:53 PM | #444 | ||
Rep 4,008
Please check the post above. It seems like the posts are getting cut off at a certain point/length and I can't reply. Also, the screen doesn't scroll up so I'm typing blind - see image below
M2CS,
05-20-2022, 09:15 PM | #445 | |||
all I do is test!
4585
Rep 998
As for the second problem, a few people have reported the same exact problem. For some reason I can’t reproduce it. Are you able to drag the text area at all?
Test 23456rt
05-20-2022, 09:54 PM | #446 | ||
Rep 4,008
It seems when i reply, the quoted portion is limited to a certain number of characters and if that limit has been reached, it cuts off the rest of the quoted message and doesn't let me type anything in reply
M2CS,
05-20-2022, 09:58 PM | #447 | |||
all I do is test!
4585
Rep 998
Test 23456rt
05-20-2022, 11:37 PM | #448 | |
Rep 4,008
M2CS,
05-21-2022, 10:08 AM | #449 |
all I do is test!
4585
Rep 998
Ok I’ve released a new version 5.2.27 to try to solve this issue, its a bit of a shot in the dark, but I believe I’ve made progress on this, if not possibly solved it. So any feedback would be helpful, letting me know if its still broken or fixed
Thanks!!
Test 23456rt
05-21-2022, 10:20 AM | #450 |
Rep 4,008
I've only got v26
I'll report back when 27 loads up 😊
M2CS,
05-21-2022, 10:25 AM | #451 |
all I do is test!
4585
Rep 998
Should be any minute now
Test 23456rt
05-21-2022, 11:15 AM | #452 | |
Rep 4,008
Not yet
M2CS,
05-21-2022, 11:36 AM | #453 |
all I do is test!
4585
Rep 998
The last one went out within a minute and this one is taking it’s sweet time. Lol. So unpredictable. I still think it should be coming in the next 30 mins
Test 23456rt
05-21-2022, 11:56 AM | #454 | |
Rep 4,008
There is a new issue with v26
When I reply to a post with multiple quotes, my reply becomes a part of the most recent reply in the chain Quote:
M2CS,
05-21-2022, 04:46 PM | #455 | ||
all I do is test!
4585
Rep 998
EDIT: ugh, .27 still hasn’t been approved. What bad luck, a whole bunch of .26 is going out there
Test 23456rt
05-21-2022, 09:41 PM | #456 |
all I do is test!
4585
Rep 998
I’m already on .28 now, google is just way behind today. In any event, look out for .28 now
Test 23456rt
05-22-2022, 03:00 AM | #457 |
Rep 4,008
It's still only showing v26 BTW, see how your message isn't appearing as quoted text; if that's what you have fixed in v28 - excellent
M2CS,
05-22-2022, 08:47 AM | #458 | |
Rep 4,008
Reply send ok with this first attempt
M2CS,
apptest4584.50 |
05-22-2022, 09:12 AM | #459 |
all I do is test!
4585
Rep 998
The main reason for 26-28 was to fix the bug where you can’t see what you are typing or scroll the editor area. I did a blind shot gun approach to try to fix that, so certainly please let me know if that ever happens to you again. Thanks 🤞
Test 23456rt
05-22-2022, 09:19 AM | #460 | |
Rep 4,008
It did have to be tested longer term I'll let you know if it happens again 🙂
M2CS,
apptest4584.50 |
05-22-2022, 09:33 AM | #461 |
Rep 4,008
I think I know why it happens, and yes, it's still happening.
Sometimes, when I tap on the three dots on top RHS for drop down list (top of list it says edit this message etc), instead of normal font, the list font is red and double yellow underline When this happens, the message doesn't scroll when typing
M2CS,
apptest4584.50 |
05-22-2022, 10:27 AM | #462 | |
all I do is test!
4585
Rep 998
Test 23456rt
