BMW M3 Forum (E90 E92)
  TireRack
      08-09-2011, 12:55 PM   #45
808MGuy
808MGuy's Avatar
221
Drives: 2009 E90 M3
Car: 09 E90
Wheels w/ Offsets: HRE P40 - (F) 20x9 +28, (R) 20x10.5 +28
Spacers: None
Tires / Miles: Vredestein - (F) 255/30/20, (R) 285/30/20; New Tires
Suspension: Eibach
Alignment: (F) Factory spec (R) Factory spec
Fender Modifications: (F) None (R) None
Rubbing?: None
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
      08-09-2011, 07:00 PM   #46
m3keash
Drives: E93, JB/Bamboo, Adv.1 8.3 20s
Originally Posted by Brosef View Post
IND did the work. I've tried my best to find evidence that it was done, but they did such a good job you can't even notice it. it wasn't cheap, but it was much less expensive than ordering new wheels.
Brosef, how much was it to pull the fenders?
JB, Bamboo, every option, 20" Adv.1
      08-09-2011, 07:09 PM   #47
wwjd15
Drives: 11 E92 M3 MR
ar: 11 E92
Wheels w/ Offsets: Volks TE37SL - (F) (R) 18x10.5 et20
Spacers: None
Tires / Miles: Hankook RS3 - (F) (R) 285/35/18; New Tires
Suspension: Moton CS with camber plates
EDC Setting: none
Alignment: (F) -2 (R) -1.6 camber 1/16" toe
Rubbing?: none.
      08-17-2011, 06:01 PM   #48
slicer
slicer's Avatar
2747
Drives: 'E46 M3 Race Car, '23 X7
Originally Posted by fastrack View Post
Not true, mine don't rub.
2011 e92 M3
HRE P40 19X 9.5 +22 19X10.5 +22
265/30/19 295/30/19
H&R Springs
no other modifications, no rubbing at all
Are you on Yokohama AD08's?
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc.
INSTAGRAM - @Slicer_M
      08-17-2011, 07:29 PM   #49
fastrack
fastrack's Avatar
Drives: 11 MW e92 M3
2021 M2c  [0.00]
yes
Mineral White + HRE + Brembo + Eisenmann + Challenge = Perfection
      08-17-2011, 08:14 PM   #50
Merked M3
Merked M3's Avatar
Drives: E90 M3 6MT
Originally Posted by wwjd15 View Post
ar: 11 E92
Spacers: None
EDC Setting: none
Rubbing?: none.
Wow this is impressive fitment in the front, 18x10.5 ET20 with 285/35/18, and the front camber isn't even that extreme.
What do you guys think about a 18x10 ET25 front with 285/35/18 and -1.7 camber? If he fits shouldn't that setup fit as well?
2008 E90 M3 6-MT - Sold but not forgotten - amazing car
The next car, my Porsche Cayman S
      08-18-2011, 02:48 AM   #51
kitw
kitw's Avatar
471
Drives: F91 M8, 991.2 GT3
car: 11 E93
Wheels w/ Offsets: Volks TE37 - (F) 19x9.5 et22 (R) 19x10.5 et 20
Spacers: None
Tires / Miles: Toyo T1R - 265/30r19 285/30r19
Suspension: H&R coilover with Dinan fixed camber plates
EDC Setting: none
Alignment: (F) -2.4 (R) -2 camber
Rubbing?: None at all.
DSC_3369 by Kit W, on Flickr
      08-25-2011, 11:49 AM   #52
nchan50
Drives: 2009 JzB/FR e92 M3
Added mine to help out those considering A/S tires
'09 E92
Wheels w/ Offsets: Stock 220M
Spacers*: 12mm front, 5mm rear
Tires/Miles: Michelin Pilot Sport A/S Plus (F) 255/35/19 (R) 275/35/19; New Tires
Suspension: Stock
EDC Setting: none
Alignment: Stock
Rubbing?: none on this setup, previoulsy had 15/12 spacers and the front barely rubbed but the rear rubbed badly on bumps
      08-26-2011, 12:05 AM   #53
wwjd15
I'm not sure if you have enough clearance for the inner. I do have aftermarket suspension so it helps a little.
For camber, it's hard to say. You need to feel the suspension and steering feedback to adjust your camber setting though.
It depends on what tires you wanna run. I would recommend 285/30/18 for fronts and keep it close to stock over diameters.
      09-17-2011, 01:31 PM   #54
M5V10
M5V10's Avatar
Drives: M3
I currently have 255/30/20 in the fronts of my e92. does anyone know if i will rub if i change it to 255/35/20?
      09-17-2011, 01:46 PM   #55
Justin(OKC)
Justin(OKC)'s Avatar
Drives: 1988 M3, 1990 M3, 1998 M3/4
1998 BMW M3/4  [10.00]
2011 BMW M3 Sedan  [9.28]
1988 BMW M3  [9.40]
1990 BMW M3  [10.00]
2008 BMW 135i - sold  [0.00]
2003 BMW M3 - sold  [0.00]
You will rub for sure! There are a few that have issues running the 255/30/20 when lowered. You have to be really careful about increasing the overall diameter over stock on the front. There isn't much clearance with the fender liners.
1988 BMW M3 - Hennarot/Black
1990 BMW M3 racecar - Diamond Schwarz/Black
1998 BMW M3 - Alpine White/Mulberry
2011 BMW 328i racecar - LeMans Blue/Black
      10-16-2011, 07:20 PM   #56
VictorH
Drives: '09 M3
Car: 09 E90
Wheels w/ Offsets: RAC RG63 - (F) 19x9 +22, (R) 19x10 +22
Spacers: None
Tires / Miles: Bridgestone RE-11 - (F) 255/35/19, (R) 285/35/19; New (300 track miles)
Suspension: stock
Rubbing?: None
      10-17-2011, 09:40 AM   #57
a burrito
Drives: Urus, 958.2 TTS, 997 S
Update
Car: 11 E90
Wheels w/ Offsets: OEM ZCP + Spacers = 19x9 et24 / 19x10 et 25
Spacers: F 10 / R -
Tires / Miles: 255-35-19/295-30-19 Advan AD08's - New
Suspension: KWV3
EDC Setting: None
Alignment: Stock
Rubbing?: F - Have rubbing at from 1/2-3/4 wheel turned in either direction on the rear side of the fenders. The rubbing isn't severe but annoying. Strangely, I'm not rubbing on full lock. Nothing detrimental to the car.
R - Rubs on hard dips on the part where the bumper attaches to the car( same place as everyone else) Can't really hear it no more but it still rubs there. Nothing detrimental to the car.
Peanut Butter Chunky
      10-29-2011, 11:33 PM   #58
quads
Drives: bac mono
Has anyone been able to fit PSS 305/30/19's in the rear without fender mods?
If so, what wheel/offset and what alignment setting?
      10-31-2011, 01:16 PM   #59
Merked M3
Merked M3's Avatar
Drives: E90 M3 6MT
Although I am not running that setup, I am running something very similar.
Mine is 305/35/18, which have an overall height of 26.4 in and width of 12.01 in
Your proposed setup 305/30/19 would be 26.2 in high and 12.01 in wide
So your tires would not be as high as mine, so no risk of upper rubbing. Also PSS have a more rounded edge than my squarish/fatter RA-1s so I think you would be good there too. Wheels would be an 11 inch wide wheel w/ offset of 32 with max stock camber (I would like more, but no rubbing issues either way).
      11-03-2011, 11:47 AM   #60
SuitedPair
SuitedPair's Avatar
Drives: GMC 2500hd
E90 ZCP '11
TE37sl front 18 x 9.5 et22 rear 18 x 10.5 et25
NT05 265/35 285/35
pins pulled
camber LF -1.21 RF -1.28
toe .05 .05
camber LR -2.08 RR -1.51
toe .07 .07
the rears will rub over speed humps on that black plastic nub
      11-03-2011, 12:06 PM   #61
Jet335i
Jet335i's Avatar
187
Drives: '21 F96 X6MC, '11 E92 M3
Car: 11 E92 with ZCP
Spacers: F 18 / R -15
Tires / Miles: 255-35-19/275-35-19 Conti ExtremeContact DWS X
Suspension: Eibach springs
EDC Setting: Normal
Alignment: Stock
R - Rubs on medium-to-hard dips - very annoying.
Final comments: It's a pain in the ass that this set-up rubs since with the stock 245/265's, it had no rubbing at all with the aggressive spacers. I'm either going to remove the spacers altogether, or pick up some stock 18's and use those with winter tires and keep summer 245/265's with current spacers on for warmer months.
      01-01-2012, 06:44 PM   #62
dbyrd
DSC Off!
dbyrd's Avatar
307
Drives: 2012 E92 M3 6MT ZCP
Car: 2008 E90
Wheels: OEM gunmetal 18"
Spacers: 15mm front, 12.5mm rear
Tires / Miles: Michelin PSS - (F) 245/40/18, (R) 265/40/18; New Tires
Suspension: OEM
Rubbing?: Slight rubbing in rear at speed over large compressions. No rubbing in front.
Trade my new 12.5mm Turner Spacers for your 10mm spacers?
      01-20-2012, 07:51 PM   #63
duk
///M
Drives: 2011 AW/FR 6MT E92
Will this rub on stock suspension E92 M?
HRE P40s
Fr 19x9.5 255/35 et 22
Rr 19x10.5 295/30 et 25
Toyo tires
2011.5 AW/FR E92 M3 6MT
      02-12-2012, 07:52 PM   #64
iDRIFT
Drives: Fast!
Car: 11" E92 ZCP
Wheels w/ Offsets: ZCP 19" wheels
Spacers: Front : 12mm Rear 5mm
Tires / Miles: Michelin Pilote Super Sport - (F) 255/35/19, (R) 275/35/19; New Tires
Suspension: KW Sleeve over kit- Front : lowest setting Rear : 1 turn from lowest setting
EDC Setting: Normal/Sport
Alignment: standard setting
Rubbing?: NONE
Cheers!
      02-16-2012, 02:04 PM   #65
snowmants
snowmants's Avatar
Drives: '06S2K,'11EVO,'11Jeep,'13GL450
2008 BMW E90 M3  [10.00]
2008 E90 M3
Square set of 4 ZCP REAR wheels.
Front: 19X10 ET 25, 275/30/19 Vredestein Sesanta
Rear: 19X10 ET 25, 275/30/19 Vredestein Sesanta
Stock alignment and suspension.
No rubbing at all.
'06 Honda S2000 #555 TT5
'16 Porsche GT4
      02-16-2012, 02:20 PM   #66
m3heaven
m3heaven's Avatar
Drives: 2003.5 E46 M3
Car: 2011 E92 M3
Wheels w/ Offsets: APEX ARC8 - (F) 18x10 +13 (R) 18x10 +20
Spacers: 12mm Front, 5mm Rear
Tires / Miles: Hankook RS3 275/35/18 Square
Suspension: KW V3 + GC Camber Plates
EDC Setting: N/S
Alignment: (F) -2.5 (R) -2
Rubbing?: None
m3post
