| 11-18-2024, 07:53 AM | #45 |
equo non credere equitem
224
Rep 161
Drives: GT500 @ The Speed Limit
Gyeon Glass Coating
Just applied Gyeon's Q2 View. Without any other product with which to compare, I can only report that beading is (very) good, no haze, no streaking, and no neg impact on wiper function (might have helped that I added a little of the coating to the blades).
Took two 15-minute intervals to install--but very easy process. Not sure I'll repeat when this coat wears off...we'll see. |
| 11-18-2024, 07:55 PM | #46 | |
Rep 392
Results and performance are awesome.
mks223.50 |
| 11-19-2024, 03:00 AM | #47 | |
Rep 24
But it's raining so much here in the Netherlands... |
g80_overboost0.00 |
| 11-19-2024, 07:28 AM | #48 | |
![]() 180
Rep 154
Now to be fair, I always foam my cars with Griot’s Foaming Poly Gloss before the final rinse, so that does provide some hydrophobicity to my glass. It only lasts one wash, though, and I’ve never experienced any film buildup or wiper streaking. |
| 11-19-2024, 08:37 AM | #49 |
![]() 8048
Rep 1,311
Drives: 04 z4 3.0 Sport & 15 X5 35i XD
I have been a lifelong Rain-X man. I used the Cerakote headlight restorer this summer on my E85 and it worked AMAZING. I was shocked. So I tried their windshield ceramic coating. Not impressed. It works OK but for all the work, it works about like (if not less that) the Rain-X I slap on a few times a year and it works perfect. Live and learn.
2015 X5 XDrive 35i - 2004 Z4 3.0 Sport
| 11-21-2024, 07:53 PM | #50 |
![]() 163
Rep 113
Drives: Xm
Windshield care … myself I degrease the glass very I will even foam it with a degreaser or wash it with a degreaser or both .
Then I use nano wax …wipe it on let it sit for 5 minutes wipe it off with a few towels very easy . I was just in the rain and snow and for good 5 minutes didn’t even need to put my wipers on and the wax helps the wipers I feel . Good luck |
| 11-23-2024, 01:19 PM | #51 |
Rep 392
Honestly just depends a lot on the maintenance habits of the owner and what you are or are not willing to do. If you clean it pretty regularly, your spray wax choice or sealant choice is generally good enough for your windshield. If you don't, then a glass coating can do wonders for you. Have to choose the right product and apply correctly to avoid wiper skip and stutter. We use GYEON View and GYEON quickview. Quickview is definitely the more consumer or DIY friendly version. Super easy to put on and take off. And it depends how much weather your vehicle sees too.
There are just a lot of factors that go into it other than "this product is crap and didn't work the very first time I tried it."
| 11-25-2024, 12:22 AM | #52 | |
Rep 24
That being said, any kind of spray wax or sealant leaves a haze for a few seconds after the wiper wipes. Even on a squeky clean windshield. Glass coating (Glaco) does not have that issues, but I had terrible wiper judder develop after about a week or so. So I am getting the Gyeon Q2 View Evo later today and applying it. Let's see how it works. Last edited by kristof_x3; 11-25-2024 at 12:42 AM.. |
| 11-27-2024, 06:38 AM | #53 |
![]() 163
Rep 113
Drives: Xm
What I found works best
Macquires All purpose cleaner to remove grease grime … Then Invisble Glass … 91164 amonia free a glass shine polish type in a can yellow lid And if really want it protected use nano wax to keep the rain off |
| 02-03-2026, 05:39 AM | #54 |
![]() 4921
Rep 4,802
Just use Glaco Ultra. Dead easy to apply too.
tracer bullet5995.50 |
| 02-04-2026, 01:50 PM | #58 |
Rep 2,969
Drives: F33 430 and F39 M35i
I just use whatever ceramic detail spray I use to clean up the car after washing. It works great on glass.
| 02-04-2026, 01:58 PM | #59 |
![]() 4379
Rep 3,456
I had tried 3 out of 4 in the video infomercial above.
My biggest long-term dissapointment for ALL windshield rain coatings has been their limited longevity/durability that is well shorter than advertised. Many coatings work great right after you apply them. But then degrade within a few weeks or a couple of months of real-world use. More quickly on the cars parked outside. 1). Glaco has been the most fragile. It self destructed for me in under 6 weeks, especially in the area under wiper arms. And then it triggered hyper-aggresive wiper blade chatter. Never again. 2). RainX lasts longer than Glaco, and decays gradually. Easy to replenish by adding RainX to windshield washer fluid. Solid plan B! 3). Gyeon QuickView has been among the longer lasting coatings. Still doing something after ~6 months and this winter, but degraded. Potential plan A-. 4). Griot's Ceramic Glass Coating. Cheap, surprisingly effective, longer last than RainX. My current plan A. 5). Not to be confused with Griot's Ceramic Glass Cleaner - absolutely terrible to apply, terrible longevity, and terrible wiper chatter. Never again. 6). Adam's graphene Ceramic Glass Coating - great when applied, gone in under 4 weeks. Never again. YMMV, a
'15 F80 M3 (SO/SS)
'21 TM3P (Blue/White) '25 Lexus RZ (White/Blue) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's Last edited by afadeev; 02-04-2026 at 11:39 PM.. |
| 02-04-2026, 03:50 PM | #60 |
![]() 351
Rep 195
I see several references to using RainX washer fluid. Has anyone experienced issues with the silicones in the RainX fluid gumming up their washer system as noted in this post. https://bimmertips.com/pro-tip-dont-...d-in-your-bmw/
| 02-04-2026, 03:51 PM | #61 | |
![]() 4425
Rep 2,355
Drives: BMWs, duh
But yeah, the Ceramic Glass Cleaner sucks donkey balls. It was so bad that I actually ended up tossing the bottle in the garbage. |
afadeev4379.00 |
| 02-04-2026, 06:43 PM | #62 | |
![]() 4921
Rep 4,802
| 02-04-2026, 07:58 PM | #63 |
It could always be worse
751
Rep 1,136
A few years ago I stumbled into the Chris fix how to "super clean your windshield" video. I tried it the next day and found it to be quite good. I've not felt the need to change anything.
Outside - glass cleaner, clean towels, clay bar, more glass cleaner, and just whatever nice wax you use on your paint. It lasts for over a year. No issues with the wipers or anything. I also like to put some of the gummi pfledge rubber treatment on the wiper blades along with the door seals. Inside - same glass cleaner, isopropyl alcohol for the plastic vapors, and more glass cleaner |
| 02-04-2026, 08:05 PM | #64 | |
![]() 2114
Rep 2,776
| 02-04-2026, 11:48 PM | #65 | |
Racecar Driver
2136
Rep 2,890
Drives: BMW M4
Now I just use the BMW Concentrate with distilled water.
N1rve
2019 BMW ///M4 - Alpine White | Sakhir Orange/Black Leather | M-DCT | Executive Package | 19" Black 437M Wheels | Carbon Fiber Trim | Sunroof | Active Blind Spot | Heated Steering Wheel | Adaptive M Suspension |
Phillies80084425.00 |
| 02-05-2026, 12:07 AM | #66 | ||
![]() 4379
Rep 3,456
Been using it for 30+ years, and the bulk of my vehicle fleet over those years (used to be) were BMWs. These days, I just buy premixed RainX washer fluid appropriet for the season, but I also have some of the concentrated mixture that I add into the reservoir once in a while. Zero issues with washer fluid systems on any of the cars. Ever. Rain-X washer fluid is not sticky in any way, so the validity of the claim is rather suspect. Quote:
I've applied Gyeon QuickView on front windshield and side windows of one car and Griots on the rear, while the other car got Griots on the front and sides, and Geyon on the rear glass. Both cars are parked outdoors next to each other. ~6 months later, zero difference in water beading between the two. Griot's might be a bit stronger. Geyon was 4x more expensive than Griot's. Geyon was all used up in that one application, Griots bottle is still 3/4 full. a P.S.: Just remembered, I had also tried 7). Stoner Invisible Glass Ceramic Glass Coating. Worked great, but did not last as long as Griots or Gyeon QuickView. P.P.S.: A few times, when renting a car for a week on vaction with the family, I've been known to pull into the nearest WallMart and buy some RainX and paper towels to clean/treat the windshield. Somehow, rental car windshields are the worst inside and out, and fixing that improves my driving enjoyment (and safety) enormously.
'15 F80 M3 (SO/SS)
'21 TM3P (Blue/White) '25 Lexus RZ (White/Blue) ex-'17 I01 i3-BEV (PB/DD), ex-'15 I01 i3-REX, ex-E90, E46, E36's, E30's |
| Bookmarks |
