12-26-2019, 12:40 PM | #1 |
Rep 216
Drives: 2017 BMW M2
Trickle Charger?
Can I use my old Deltran Battery Tender on the 2016 G11 or do I need something with newer tech?
2016 750i X-drive
2017 GMC Sierra Denali 1997 MB SL500, 19"AMG replicas Past BMWs: E30 323i, E36 325is, E36 M3, E46 M3, E39 M5, E46 325i, E90 335i, F80 M3, F87 M2 |
12-26-2019, 03:37 PM | #2 |
Rep 7,488
We dont' have enough info about your "old" Deltran battery Tender. Do yo have a model number etc? How old is it? Does it have alligator clips or do you have to plug it into a 12 volt socket?
I would look for the instructions that came with it or google the brand/model for an instruction or owners manual (PDF). Depending on how many and type of battery/batteries you have...it could depend. Does it have the capability to charge AGM & Lithium batteries? Again, depending on what or which type you have...and what is the tender's specs...1.5A or 4 amps? And does it have the capability to "float" (aka stop charging when the battery is fully charged)? Here's a link to the TIS website that has multiple links about various battery charging info you may need to know in regards to AGM and/or Lithium batteries: https://www.newtis.info/tisv2/a/en/g...older/1Lil7vLT
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. Last edited by Qsilver7; 12-26-2019 at 03:46 PM.. |
Lincoln30143.50 |
12-26-2019, 09:13 PM | #3 |
Rep 216
Drives: 2017 BMW M2
Thank you for the link.
I have the Deltran Battery Tender Plus that is the same model that BMW used to sell branded as a BMW part. While the current product using this name can charge AGM, I think mine is so old that it is not designed for AGM, so I will get a newer Deltran or CTEK device.
2016 750i X-drive
