BMW Garage | BMW Meets | Register | Today's Posts | Search |
BMW 3-Series (E90 E92) Forum
Break-in period
06-10-2005, 11:37 PM | #1 |
Rep 279
Break-in period
My sales rep told me to take it easy and keep it under 4500 rpm for the first 1200 miles. Now occasionally I have had to rev her up to 4 - 4.5 k in traffic to make lane changes etc. Otherwise I've kept it to 2-3.5 k rpm.
Do you baby your E90 during break in? Have I done any damage? Are BMW E90 engines nickasil coated like higher end sports and luxury cars? Thanks. |
06-11-2005, 02:00 AM | #2 |
330i Jet Black/Beige Interior with Sports, Premium, Cold Weather, Steptronics, Active Steering, Navigation, Comfort Access
Rep 39
No - you have not done any harm if you dont rev it up for constant period of time. Good break break in requires the engine to go thru a spectrum of RPM. So it a good idea to break in the car in the city with varing RPMs versus taking it on a trip and keeping it at a constant RPM.
06-11-2005, 06:27 AM | #3 |
Addict
203
Rep 2,074
I've read so many posts on break in. I don't think it really matters TOO much. Just don't punish your car while it's new, drive normally and sedately, if you need to rev to 7000 to get out of a sticky situation, I would do it. As long as you are not always redlining for the first few km's...it should all be fine.
Just remeber, you do the most damage to your engine when it is cold, so take it easy for the first 10-15 mins of driving all the time. Ps. The water temp gauge isn't there, but it was useless anyways. |
06-11-2005, 07:03 AM | #4 |
Rep 374
Guys, i've already revved up the engine to 7000 RPM and still haven't redlined it. Like someone else said, just don't do it constantly, although i find that i often can't really help myself.
Nathan
[ US 2010 X5 3.0 | Space Gray | Black Nevada Leather | Dark Bamboo Wood Trim | Premium Package | Sport Activity Package | Premium Sound Package | Technology Package | Heated Front Seats | Multi-Contour Seats | Smartphone Integration | Space Saver | iPhone 3GS ]
06-11-2005, 08:00 AM | #5 | |
Rep 20
06-11-2005, 08:36 AM | #6 | |
S0THPAW
8739
Rep 7,847
Why not?(I asked this question before on a E87 board but I didn't get an answer) |
06-11-2005, 09:13 AM | #7 | |
Rep 33
06-11-2005, 05:24 PM | #9 | |
Addict
203
Rep 2,074
06-11-2005, 10:55 PM | #10 | |
Rep 663
E90 330i delivered 6/29/2005, ZSP/ZPP/ZCW/Step, Arctic/Gray/Walnut
06-12-2005, 12:44 AM | #11 | |
Rep 436
06-12-2005, 01:28 PM | #13 |
Rep 722
I am just under 1,000 miles now. Can't wait until 1,200. I have had my car up to about 6,500 RPM a few times, mostly by mistake because it revs so freely. My wife actually did 2 of the 3 revs to 6,500 or so because she got carried away! I looked over and was like: "ok you can shift now!"
She's a little speed demon |
08-10-2005, 04:02 AM | #16 | |
Rep 38
Running-in / Breaking-in
I met a BMW Asia Area Service Manager (a German) recently and I took the opportunity to ask him about the Run-in / Break-in question. His replied was that as long as the engine has warmed up, it is ok to even go beyond the 4500rpm mark. It will not do any harm to the engine, just that you will not get the full rated power as yet until the engine has surpassed the 2000 km mark. Also, in any case, one should not rev up the engine to the red line when the engine has not warmed up. You will do harm to the engine in this manner. I hope that helps. Anyway, I rarely have a chance to go to the red line unless I floored the accelerator as mine is a auto-transmission. It will change to a lower gear even before it reaches 4500 rpm. Cheers. |
08-10-2005, 08:08 AM | #17 |
Rep 35
oil temp vs water temp
The car should have both water and oil tempature guages. The water
in your car will heat up around 2 miles or so depending on the outside tempature. The engin/oil take around 10 miles to heat up. When the outside temp is very cold the bigger the difference. Also, back in the 1970s I added a bigger carb, cam and headers to my 1971 383 charger. Fortunatly I installed an oil, water and volt guage. I noticed when beat the hell out of her the the water temp was always good but the oil would go the red. I installed an oil cooler to resolve the problem saving my engin. I am sure BMW has this covered as most people's oil heats up durring high speed driving. After going X speed for 20 minutes the oil will stablize. Just my two cents. |
08-10-2005, 09:13 AM | #18 |
Rep 58
My car has close to 2000 miles on it... Lot of it highway, and I've stuck to the recomended break in per the manual. I see myself pushing the car a lil more each day, and the response has exponentially gotten better.
08-10-2005, 09:28 AM | #19 |
Rep 6,158
the old water temp gauge on E46...............................
wasn't really even a gauge, it was a 3 postion item. if the temp is in the normal range the needle shows right in the middle, and never moves even as water temp changed, unless you got dangerously hot. the gauge had lost it's usefullness do to people freaking out when the temp started climbing on hot days in traffic, we lost that gauge as a usefull feature a long time ago |
08-11-2005, 05:16 AM | #20 |
Rep 7
The car came with fully synthetic oil, which to me means the engine was broken in @ the factory. It's the accessories, belts, brakes, suspension, tires etc that needs to be babied for an initial period.
My 325i Auto has about 2000 km on the clock. It's seen 100mph before the 1200km mark. 2 days ago I floored it for the first few times, took it to 125mph and found the soundtrack addictive. The main thing during break in is to vary the RPMs and not to stomp on it all the way to redline while driving off the dealer's lot. |
08-11-2005, 06:31 AM | #21 |
Rep 1,832
Drives: bmw e90 320d
the ideal thing on how to do the break in period is to drive in a normal manner and not to abuse the system.
e90 320d,arktis,lumber support, hifi speaker, alarm, dakota beige, 162 18", xenon with washer spray,window chrome trimmings, professional radio, 6 cd changer wood trimmings
6 speed manual. |
