05-03-2011, 07:29 PM | #67 |
Rep 268
They dont really have a taste on their own. They can be slimy but I've found that if you run them under hot water and drain them most of the slime comes off. Pasta sauce doesnt stick very well to them so I tend to throw them together with some celery, carrots, sliced chicken breast, garlic, ginger, green onions and stir fry them with a bit of soy sauce or oyster sauce. Most of the recipes you find online that are Asian influenced tend to taste better than the ones that are westernized.
05-03-2011, 09:02 PM | #68 | |
Rep 612
Drives: On a good day, AW 1M coupe
** Your body needs good sleep my friend. ** And cut way down on the sodas if you drink them currently. ** Avoid supplements, avoid caffeine, avoid alcohol. Just keep it simple. |
05-04-2011, 04:50 PM | #69 | |
Rep 3,879
Ive been doing this, im down 12lbs so far - no soda, and im not a big drinker normally. |
05-08-2011, 05:13 PM | #70 |
Rep 612
05-10-2011, 06:56 PM | #71 | |
Rep 38
This is spot on! if he had a BF% he could give exact numbers... its all in the Macros. I would recommend 14-15 incline on treadmill @ around 1.8-2.3 speed depending on heart rate for about an hr in the a.m. on an empty stomach. it works! |
05-19-2011, 12:37 PM | #72 |
Rep 1,883
Drives: 2011 E92 M3
Calories in minus calories out....
If you eat more than you burn daily you'll gain weight. If you eat less than your burn daily you will lose. Everything else is just an excuse.
'11 BMW E92 ///M3 - ZCP and DCT
'15 Ford F-250 - Lariat, 6.7 Powerstroke Turbo-diesel |
05-23-2011, 10:10 PM | #73 |
The Fat Stig
11
Rep 274
Gavin - Just wanted to encourage you to keep it up. I'm currently almost identical to you.
In my late 20's I weighed 263 (5'9) and lost 100 pounds by doing crazy cardio every day, along with a diet of no more than 1000 calories (Subway for lunch, every day, then very small breakfast and dinner). Man 163 felt great. Went from 44 waist to a 32 waist and XXL to M shirt size. Then some personal crap happened in my life and over the years I put it all back on, and more. I weighed 293 (Size 50 waist) on 1/18 of this year. I know people on here are going to flame me for it, but I got the lap-band on 1/18. After seeing my grandpa die of 2 strokes and a heart attack, and seeing my dad have a stroke in his early 50's (He just had a quintuple heart bypass surgery last week) I decided that enough is enough. Obviously my personal problem is not loosing the weight -- it's keeping it off. (Statistics show this is exceptionally common for dieters) Thankfully, I only have some slipped discs in my lower back, and nothing worse. (The above sounds like I'm advocating you get the lap band, but I'm not, my advice is below...) As of today, I'm at 255. I've had a fairly difficult time loosing weight, but you gotta keep at it every day. The best advice I can give is what worked for me: - Realize you're human and when you screw up and eat bad stuff, try not to get down on yourself. Just resume correct eating at the next meal. - Realize that day to day variations in your weight due to water are more than what you can subtract due to good eating and excersizing alone...so...if you weigh yourself every day (They say its best if you don't, but I do, to hold myself accountable) remember if the scale says you weigh more today, try not to get upset. - Heard this tip from a weight loss class I had to take before my surgery. Very simple advice, yet very good advice: Do something! Sometimes I feel like crap and I don't want to exercise because I can't make it through my normal full set. It takes a lot, but try to get up and do something. If you normally do 30 minutes, and you feel lousy, just try 15 minutes.... - Advice from my Doctor last week: If you're like me, when you work out, you try to do too much. I have a tendency to keep my heart rate in the high 80% range. Doing that makes me feel like I'm going to pass out after I get off the machine. It also makes my body feel like I've been ran over by a X5 (pulling my 135 ) Just yesterday I gave it a whirl about keeping my heart rate at about 65-70% While I definitely burned less calories during the same alotted time, I felt so much better when I finished. I really could have went longer and made up the calories with time. I won't give you any advice on the eating other than what others have already said. Fat lost = daily food intake - basal metabolic rate - excersized energy. Getting more of your calories from protein is generally better than refined carbs or fats, but many protein sources contain cholesterol which isn't good. I think when I get down to my goal weight I'm going to reward myself with a used Elise or something like that (which will require me to stay thin to drive the darn thing) Keep up the good work man!
05-23-2011, 10:44 PM | #74 |
Rep 955
For everyone on this huge cardio kick, just remember that too much cardio will slow down weight loss.
20-30 min sessions should be the most you do if you are trying to lose weight. Do more than that and you're body starts to store fat to burn off on subsequent cardio sessions Turbolader, I do agree about weighing in on a daily basis. Its essential to make those adjustments needed to lose weight. Weighing yourself once a week is not a good idea since there can be too much weight fluctuation in one week I don't agree about the lap band though. Especially for someone like yourself who did it the right way once before. |
05-23-2011, 11:12 PM | #75 | |
The Fat Stig
11
Rep 274
OP - Sorry to get off topic
05-24-2011, 01:42 AM | #76 | |
Rep 676
I've dropped 40lbs after changing my diet and doing moderate cardio (jogging 3-4 miles every other day). I started in the last week of January. So, about 4 months. I've gone from 259lbs to 219lbs. My goal is to get to 210lbs by Sept 1st and then TRY to get to 199lbs by Jan 1st 2012. Honestly, I feel like the diet has changed my life. It's really not a diet- it's a different way of thinking about food.
The down sides:
135i // M-Sports Package // RR Oil Catch Can // Black Kidneys // iCarbon Hood // Alum Pedals // KW v2 Coilovers // Vorshlag Camber Plates // Hotchkis Sway Bar // Wheel Studs. Best mod ever? Tires. 255's in front, 275's in back.
05-24-2011, 01:56 AM | #77 |
Rep 676
Side note: this is the Paleo book that got me started.
A couple warnings:
05-24-2011, 02:00 AM | #78 |
Rep 676
Few more links can be found here:
http://hivelogic.com/articles/the-pa...a-link-primer/ (A couple links are outdated)
05-24-2011, 10:42 AM | #79 | |
Rep 955
Keeping the weight off is all mental, its just based on decisions. Personally I have lost almost 80lbs since end of Sept and it is staying off forever. The greatest fluctuation I will allow is 5lbs , and thats normally if I go on vacation. If I ever need a reason to stay the course I just pull up some old pics that show me fat and bloated, gets the job done everytime |
05-27-2011, 01:25 AM | #81 |
Rep 676
05-27-2011, 04:31 PM | #82 | |
Rep 489
This awful subforum u fukin paleotard
05-27-2011, 06:04 PM | #83 |
Rep 955
I love this from the Caveman Power Diet page
"This diet does not promote the regimented eating style found in most modern diets. Those diets nearly always fail because they require an absurd amount of willpower, which is very unnatural" I suppose its completely natural to during stage 2 eat nothing at all between morning and evening |
05-27-2011, 07:08 PM | #84 | |
Rep 2,200
E9X Picture Game: 8 points: (High visibility jacket; Strip Club; Pizzeria; Sobriety Test; E9x dressed for Halloween, Billiards, Oil Change, Orange Cone)
05-27-2011, 07:11 PM | #85 | |
Rep 2,200
05-27-2011, 07:13 PM | #86 | |
Rep 955
The idea is to evenly distribute calories to your body during the day. So that you feel about the same throughout the day. |
05-27-2011, 07:15 PM | #87 |
Rep 2,200
Whatever , I wish I was heavy, Id be all muscle
05-27-2011, 08:02 PM | #88 | |
Rep 1,432
Just thought I would follow this up and say that you are absolutely correct. No recent studies indicate that timing of your meal (or amount of calories ingested in one sitting) have any bearing on weight gain or weight loss. There's also no such thing as, "if I eat too much, I won't absorb protein, and I'll just absorb all the carbs". Proteins, fats, and carbohydrates are broken down and absorbed by intestines independently of one another. To OP - not to discourage you, but it is a difficult path that you tread on. What you refer to "heavy body build" is actually the fact that our bodies have inherent weight set-points, kind of like the thermostat for your AC. Our bodies will always gravitate towards that set-point, and will do so by secreting all sorts of hormones and growth factors when we are too far above or below that set-point weight. It is controlled and tightly regulated in the hypothalamus of your brain. You can read about Leptin, peptide YY, etc if you are curious. What does that all mean? You need to be vigilant not only to lose weight, but with the most difficult part, which is maintaining the weight loss. Either way, we're all glad to see you're giving it a go, and we hope you accomplish your goal! |
