      10-27-2017, 01:47 AM   #1
dzvero
Drives: 2015 M$4 F82
Question Marble tiles in the bathroom floor, shower any regrets?
Im planning to remodel bathroom and I like marble and its look. Planning to use marble on the floor but hesitant to use in the bathtub/shower. Any one have marble in the bathroom? Any regrets? Maintenance? Maybe some marble looking porcelain is better?
      10-27-2017, 05:17 AM   #2
wrickem
Big Beaver Smile
wrickem's Avatar
2101
Drives: What he wants to
3years ago we decided to go full marble in our master bathroom. Full sheets on the wall and pattern on the floor. It's holding up very well and easy to clean, no regrets at all.
______________________________________________
Current- '21 430 , '19 911, 07 M6 ,'17 Jeep Wrangler, "23 Bronco OBXluxsquatch
Lups11827.50
Mirko182.00
      10-27-2017, 06:10 AM   #3
RickFLM4
RickFLM4's Avatar
Drives: M4
It looks great - really hard to beat marble from that perspective. However, I'd imagine it will need to be polished and sealed annually and you should also think about wet feet traction if putting on the floor (as you would with any material).
We are doing our master bathroom early next year but planning to use tile for shower and floors and quartz for counter surfaces. Just a matter of personal preference, amount of surface to cover and budget.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82
      10-27-2017, 07:26 AM   #4
radiofrequency
Field Marshall
radiofrequency's Avatar
307
Drives: 2018 M4 ZCP, 2021 M2 Comp
Having remodeled several homes, my advice to you would be to visit one of the larger tile stores such as Arizona Tile: https://www.arizonatile.com
Visit when you have a few hours to work with one of their consultants. I have found them to have a pretty unique selection, and the folks I have worked with there are thoughtful and considerate when assembling a solution for me. You just might be blown away by how great you can make a bathroom look when you step back for a moment and consider several options. Bathrooms and kitchens sell homes, as important as the latter, is that women love their bathrooms. If you are married, it's probably a great idea to have your wife accompany you to Arizona Tile. It's just a fact of life that women have a different lens through which they view this (and other) types of choices. They tend to spend a lot more time in the bathroom, so they seek ambience, amongst other factors when making choices of this nature. It's really a force multiplier having your SO along with you when seeking ideas. It's an important decision as you're going to be looking at that bathroom for a long time.
You may pay a little more going this route, but you will certainly get the wow factor going, and it's actually a lot of fun when you take the time to consider several choices. You might, in your case, actually pay somewhat less, as incorporation of tile into your project while you are still using marble, may reduce costs. I also find a lot of inspiration looking at Houzz.com - their photographs are incredible, you can set up albums on their website and save the images of bathrooms you like. Good luck!
Lups11827.50
      10-27-2017, 07:28 AM   #5
The Choosey begger
Libertarian
The Choosey begger's Avatar
Drives: M4
I can't do marble or chrome wheels on my car.
Lups11827.50
smoosh2211.50
      10-27-2017, 07:33 AM   #6
Lups
Lups's Avatar
11828
Drives: I don't own a car.
There are a million materials but marble will never be used by me.
Originally Posted by Joekerr View Post
You're still a little new here, so I'll let you in on a little secret. Whenever Lups types gibberish, this is an opportunity for you to imagine it to be whatever you'd like it to be.
Originally Posted by Delta0311 View Post
How would you know this? Did mommy catch you jerking off to some Big Foot porn ?
      10-27-2017, 07:49 AM   #7
P1
P1's Avatar
11572
Drives: 2004 3/4 ton Duramax
Our apartment has a lot of marble and it needs a lot of TLC. You put a drink down and have to careful the sweat from the glass doesn't leave a ring on the marble.
nyalpine907433.00
      10-27-2017, 07:50 AM   #8
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
We used Carrara marble for our countertops and tub surround when we built our home about 14 years ago. It has been fine. Marble is porous, so if you do spill things on it, it needs to be wiped up reasonably quickly. You can bleach it if it does get a stain (don't ask me how I know). Sealing it is a good idea. You do need to be mindful of cleaning products. Keep all products containing acids away from it, or it will dissolve. We paired white subway tile with the Carrara marble, and I think it makes a classic look that ages well, but the trend now is more toward muted grays, often large pieces of tile, and decidedly more modern looking. The current trend is also away from built-in tubs and toward what wrickem shows in the photo -- standalone, self-contained tubs in various shapes.
Good luck with your bathroom project.
Salty
2006 BMW Z4M Interlagos Blue/Black
Aux Port|LED Interior|LED Strip Trunk|Underseat First Aid Box|Stubby Antenna|Intravee II|BMW Oil Change Kit|Top Down Side Panels|Vibra Technics Engine Mounts|Rogue Trans Mounts|Engine Mount Bolts Upgrade|RS Windblocker|Euro Front Plate|M5 Illum Shift Knob|Supersprint Powerloop Exhaust|Gruppe-M Intake|RPI Scoop|Black Grills|19x8.5 ET35 F 19x9.5 ET22 R Sportline 8s PSS| Besian Vanos|CDV Delete
wrickem2101.00
      10-27-2017, 08:19 AM   #9
Archie Bunker
Drives: M2
It must be early because my immediate thought was, "they don't make marble wheels."
Lups11827.50
      10-27-2017, 09:39 AM   #10
wrickem
Big Beaver Smile
wrickem's Avatar
2101
I think that depends on what look you're going for. If you go into an old butcher shop, their marble is usually worn, has cuts in it and to me it looks beautiful, where another person might see it as old and dirty.
After 3 + years, ours shows no sign of wear, water marks or stains and I wish it would (curse you good water with no rust!). The marble in old baths that you see in Italy is what I really want, some rust stains and wear and stuff. I prefer things that are broken in but look well taken care of and clean (I think leather looks better with some wrinkles and wear in it, hate it when it's new, should have just gotten vinyl). I love some "history" showing in natural materials
      10-27-2017, 09:57 AM   #11
Naz24
Naz24's Avatar
Drives: W205 AMG C63 / E70 X5M
You can buy granite products that resemble marble, Countertops are granite in my parent's house, but you'd swear it was carrera marble...
2017 C63
2012 X5M
SOLD: 2015 M3; 2007 X3 M Sport; 2014 X3 M Sport 35i; 2004 X5 4.4i; 1994 325i
      10-27-2017, 10:49 AM   #12
Alfisti
Drives: 2008 Saab 9-3 Combi
Not a fan, looks old school and is a bit of a PITA.
      10-27-2017, 10:59 AM   #13
RickFLM4
RickFLM4's Avatar
Drives: M4
Most people try to avoid that because if they ever want to sell their home, buyers are likely to favor new-looking over rust stains. So if you want the worn out look, great. But if OP is trying to avoid that and wants non-stained, non-cracked, glossy-looking surfaces, it will require some proper maintenance and care.
      10-27-2017, 11:33 AM   #14
wrickem
Big Beaver Smile
wrickem's Avatar
2101
Different strokes for different folks in different areas, I'm sure not a lot of people in your area would want an1863 stone/stucco house but in my area that's what is desired OP is in CA, so he's probably better taking advice from more contemporary areas of the country than mine.
What may not have been obvious in my post or pictures though is that in 3+ years with virtually zero maintenance other than the cleaning woman every week (I think she uses Fabuloso and a scrub brush - that's what it smells like after she leaves), the sheets of marble on the shower walls and the marble floors are holding up and looking as good as the day they went in, and I wish they wouldn't.
      10-27-2017, 11:44 AM   #15
KingOfJericho
KingOfJericho's Avatar
Drives: Yes
2010 135i Coupe  [5.26]
We are remodeling two bathrooms right now (master and kids). We are using marble for the master shower because it's stand up and the white gives it a more spacious feel. The tile was literally delivered today so I can opine better in a few weeks. We wanted light but hated fake pattern tiles and I think the subway tile look is fading in popularity. Marble is classic.
The views and opinions expressed in this post are those of the author and do not necessarily reflect the official policy or position of Bimmerpost.
2018 Jeep Grand Cherokee High Altitude Hemi | 2010 S4 Sold | 2010 BMW 135i Retired | 2006 Lotus Exige Sold
wrickem2101.00
      10-27-2017, 12:23 PM   #16
bd307
Chef
bd307's Avatar
927
Drives: Things with wheels or no wheel
Sounds like you are talking about cougars
wrickem2101.00
      10-27-2017, 01:03 PM   #17
Mr Tonka
is probably out riding.
Mr Tonka's Avatar
Drives: Something Italian
I'd go with tumbled marble for shower floor. I have a mix of tumbled marble and glass mosaic on my shower floor. No problems with grip.
Not happy with the performance of our Dark Emperador marble counter top in the master bath. Needs to be polished.
We have french cut, chiseled edge marble throughout the main part of the house. Love it. Has held up really well and never looks dirty. Score!
"There is no greater tyranny than that which is perpetrated under the shield of the law and in the name of justice. -Charles de Secondat"
http://www.m3post.com/forums/signaturepics/sigpic59612_1.gif
wrickem2101.00
      10-27-2017, 05:43 PM   #18
dzvero
Really looks great !
wrickem2101.00
      10-27-2017, 05:51 PM   #19
dzvero
Yes, I looked ant porcelain fake marble and it just dont grow on me. Its not near the real thing . Im also going with light colors, some considerations are allen roth's cream beige , carrara marble , Creama Marfil ...
      10-27-2017, 07:16 PM   #20
dzvero
Its a bathtub with shower 2 in 1 so no floor to worry in the shower . For the vanity I probably will use something else
Mr Tonka6058.00
      10-27-2017, 07:18 PM   #21
dzvero
If you are 20 you might like plastic but Im old school and I like marble !
      10-27-2017, 07:22 PM   #22
dzvero
Salty
And this is not the master bedroom bath so I cant do what he did. It likely will be in the master bath which is next.... but wait, its not build yet Its next project after the kitchen is done to have new master bedroom + bath . Next year likely
