03-12-2020, 06:08 AM | #134 |
Moderator
29599
Rep 13,130
Wait a sec, are you criticizing the new BMW design language (coffin kidneys, mega muffler aka cow udder, new logo) ?
///M is art ↔ Artemis
03-12-2020, 09:39 AM | #136 |
Rep 2,232
03-12-2020, 01:42 PM | #137 | |
Luxury at the redline :)
9105
Rep 7,563
I could live with that.. |
03-12-2020, 02:02 PM | #138 |
Rep 4,210
03-12-2020, 02:23 PM | #139 |
Moderator
7517
Rep 19,368
It is best to ignore that rumor at this stage in the game. Autocar made the claim that the G42 will follow the styling of the F44. But it's an utterly baseless conclusion. The two are not likely to be any similar than any of today's BMW passenger cars are to one another. The G42 is a distinct model and it will be given its own identity. SCOTT has mentioned the 3.0 CSL Homage in the past as a possible hint of what to expect for the G42/G87. While that leaves a lot of room for interpretation, its likely to be a better first step at guessing what the G42 might look like than arbitrarily trying to bend the styling of the FWD FAAR based F44 onto the RWD CLAR platform. I mean that just makes absolutely no sense whatsoever. Sure, the grill might look like that, but it might look like a hundred other grills too. Certainly the rest of the car will not be proportioned anything like the F44, so why copy the grill? It's not a logical place to start the guesswork, and I believe in time you'll see Autocar renege on their prediction.
Poochie9104.50 |
03-12-2020, 02:48 PM | #140 |
Moderator
29599
Rep 13,130
What about "M Purr-formance Parts Mega Muffler Technology" ?
03-12-2020, 04:27 PM | #141 |
Rep 2,362
Drives: G87 M2; E92M3 MT&DCT; M3 euro
M-DCT is not your average VW/JP transmission. It is the same transmission used in F458/F488. You need to shift manually to fully appreciate the mechanical excellence of this sport transmission.
Pass me if you can.
FrozenGT1116.50 |
03-12-2020, 06:18 PM | #142 |
Rep 2,232
Good to know I have a Ferrari used component in my 135i. Too bad I'm having temperature sensor issue that'll probably cost me a couple grand to replace.
03-12-2020, 08:35 PM | #144 |
Rep 2,956
The reality is the average buyer will prefer the smoother operation of the ZF8. I haven't seen a single Supra review where anyone lamented it wasn't a DCT, in fact it's received a lot of praise. I have owned several DCT's going back to last decade and the ZF8 is considerably smoother than any of them and in sport+ mode isn't far off their performance. It's the smoothest automatic transmission I've ever driven which everyone will appreciate on those days where life gets in the way of race day. I was a bit of a ZF8 naysayer until I got the X3M and TBH after using this transmission I'm a believer in the hype as it's really good.
Poochie9104.50 |
03-12-2020, 10:59 PM | #145 | |
9105
Rep 7,563
However, is it just me or did the ZF8 used to, by design, bang gears, where there would be a surge and jolt, at every gear change, in Sport and Sport+ but now they seem to eliminate that jarring sensation. Seems kind of counter-productive for the latest ZF8s, if their ultimate goal is to make it appear sporty and feel more manual-like. I guess my question is, does your X3M bang gears, in Sport+, during rapid gear changes like it use to? |
03-13-2020, 09:17 AM | #146 | |
Rep 2,362
Go to Realoem (a long standing website shared by BMW's interal parts system), choose F82 M4 and see which transmission options pop up. It is internally labeled as "Dual Clutch Transmission", not as "Automatic transmission" of F90 M5. DCT, with its two operating clutches respectively for even and odd # gears, is mechanically much closer to a manual transmission. It is essentially a slightly less reliable sequential manual transmission used in race cars.
Pass me if you can.
03-13-2020, 12:13 PM | #147 | |
Moderator
29599
Rep 13,130
Of course it would make sense to have 'the pedal count' as criterion (2 = automatic | 3 = manual) or the type of gear shifting (digital/electronic = automatic | mechanical = manual) or, simply, the possibility of automatic gear shifting (present = automatic | absent = manual). But for BMW, the torque convertor is the criterion (present = automatic | absent = manual). M-DCT (code 2MK/S2MK/S2MKA in VIN specs | "M twin-clutch transm. with Drivelogic" | "M Doppelkupplungsgetriebe mit Drivelogic") = no torque convertor = manual transmission in BMW's book. Therefore, "MANUAL"/"HECK" (instead of "AUT") is indicated in VIN specs of any F87 M2. See also for example here. See what is said from 01:12 onwards: See also here from 01:55 onwards:
03-13-2020, 12:29 PM | #148 | |
9105
Rep 7,563
I've been reading since 2006 when the SMG 2 was a big deal that it would "replace the manual within the next five years" because it was soooo good and comparable, yet that day never arrived because deep down, BMW knows there is simple no replacement for that clutch pedal. Driving both back to back, they're almost like two different vehicles and anyone who say otherwise is practicing self-deception. I know this is a touchy subject and sparks a lot of debate when mention, so I try to be as delicate as possible but I'm sorry, I just can't accept a transmission being classified as a true manual, where the gear change is operated by paddles and you can't balance the motion of the vehicle and gear change with the clutch pedal. |
03-13-2020, 12:58 PM | #149 | |
Moderator
29599
Rep 13,130
03-13-2020, 01:08 PM | #150 | ||
9105
Rep 7,563
I'm aware the SMG was "clunky" and had major issues with the SMG solenoid pump, however, it was described as "a manual gearbox that instead of having the clutch foot operated, has the clutch electrohydaulically operated via a pump and wired to computers" which sounds like tomayto, tomahto to a DCT in modus operandi. The DCT has its charms and if I could of swing having two cars, one would certainly be a automated-manual, so no beef but since I could only have one, I'll stick to the third pedal option. |
03-13-2020, 02:15 PM | #152 | |
9105
Rep 7,563
Trust me, I've seen people get much more rawer deals, just by simply being victims of the circumstance... But I digress.. The DCT is pretty cool, the lighten fast shifting is impressive, it shifts before you could even finish a though but when I drive a DCT or ZF8, it just temps me to play with the paddles, step on the gas pedal and blast off. I could better pace myself in speed, when you're allowed to modulate a shifter and clutch pedal. DCT 0 to 100mph, real quick would get me in a lot of trouble. It's fun but addictive. It's cool BMW still gives you that option of a manual, which I sure they did begrudgingly but couldn't deny the numbers, in a 2023 model year.. It shows they understand their market demand and one of their saving grace, in a niche but competitive market. |
03-13-2020, 02:29 PM | #153 | |
Moderator
29599
Rep 13,130
Quite likely you will recognize the message that I tried to get across of breathing some 'soul' into the whole experience by working the gearshift lever: a joy for the senses, including both hands and feet dancing around. The driver's seat as a workplace, rather than as your couch behind a switchboard. Push and pull, twist and shove, rather than 'click'. That visceral experience of more mechanics than electronics at play + you're in control.
Poochie9104.50 |
03-13-2020, 02:55 PM | #154 |
Rep 147
Why do you guys care *so* much about the lack of dct? I mean, you could just buy another car with it, instead of the new m2. You could also consider for a brief moment that the zf8 will be upgraded for m2 duty, instead of criticising before it’s even out. There is no reason the torque converter couldn’t approach dct shift speeds to the point that it makes no difference, it already has in fact. The trend today is back to torque converters for torquey applications. Besides, every shitbox today has a dct anyway
