07-28-2021, 05:50 AM | #1 |
158
Rep 595
BMW F44 220i M Sport Genuine BMW M Performance brake kit, front grille retrofit
2021 BMW F44 220i M Sport Package retrofitted with Genuine BMW M Performance Front 4 piston Rear 1 piston brake kit.
Brake kit comes with 360x30MM front, 330x20MM rear slotted discs. This set of brake kit included everything you will need to for retrofitting the brakes, rotors, calipers, protection plates, bolts, brake pads....etc. A special point of this brake kit is it comes with new brake servo unit, brake master cylinder and expansion tank with warning switch which you have to replace them too. New set of brakes was much more responsive comparing with stock ones, braking distance was also less than before. You can easily tell the performance difference after upgrading this set of brakes. Front grille was also replaced with M Performance Shadow-line Gloss black front grille, gotta get rid of the chrome bit... Here are some photos during and after the installation: |
07-28-2021, 08:12 AM | #2 |
Rep 41
Drives: 2021 BMW 228i xDrive GC
Congratulations ! Great modification.
Can you give us the price for the brake kit ? I will pick up my new 228i xDrive M sport on Thursday and would be interested with such a modification in the future. Thanks in advance
2021 228i xDrive GC (F44) | Alpine White / Black SensaTec | M Sport | M Sport Steering | Convenience Pkg | Lighting Pkg | Shift Paddles | Illuminated Boston Trim| Extended Shadowline Trim| Panoramic moonroof
10-20-2021, 12:07 PM | #3 | |
Rep 6
04-20-2023, 09:01 AM | #6 | |
Rep 3
iCARMIX158.00 |
Tags |
218i, 220i, brake kit, f44, hong kong, icarmix, m performance, m235i, retrofit, upgrade |
