09-03-2021, 01:00 PM | #1 |
Rep 42
Cigarette outlet fuse location?
Been looking everywhere in the web and inky result I can find is an owner who got it fixed through the dealer.
All outlets are not working and I have no idea where the fuse boxes are located in this car. 2016 750i |
09-03-2021, 02:44 PM | #2 |
Rep 1,608
Look in your manual. There are two fuseboxes, one in the trunk and one under the glovebox. There is a folded up 'map' in each fusebox showing symbols for and location of fuses. Look for the picture like this. The picture is there as an example. It may not be #42 on your car.
BMWCCA
09-04-2021, 10:06 AM | #4 |
Rep 7,522
Ditto AlteBMW…the owners manual usually gives info as to the location of the car’s fuse locations. Go to the index in the back and look for fuse.
Also, there should be an owners manual built into iDrive. You can manually go to it or use the voice command button and say “OWNERS MANUAL”…and it should come up on the iDrive screen. On my F chassis BMWs…both have a laminated fuse diagram/index sheet folded up and stored in a slot in the rear fuse box. See pics below for example…and if your 12 volt sockets have an icon printed on them…the same icon is usually used on the fuse index sheet. Rear fuse box and fuse index sheet from my F06…yours should be similar…btw, ignore the icon circled in red…this image is from my pic stash and the icon was highlighted to show the icon used for th sunroof switch:
09-04-2021, 10:10 AM | #5 | |
Rep 42
09-05-2021, 02:58 PM | #6 | |
Rep 7,522
If this is the case, you can google BMW 12 volt socket doesn’t work to see what owners have done in the past. This issue is common enough that a google search should bring up some past discussions on the topic. A: 12-volt cigarette lighter receptacle and plug sizes
B: 12-volt cigarette lighter receptacle and plug sizes
g12newb11.50 |
09-05-2021, 10:09 PM | #7 | |||
Rep 42
Solved a mystery for me!!! Thank you both for some very good information |
09-05-2021, 10:12 PM | #8 |
Rep 42
09-06-2021, 12:59 AM | #9 |
Rep 313
Wow!!, that’s expensive. I had one of those included from new by the dealer, so assumed it was standard.
09-06-2021, 09:21 AM | #10 |
Rep 1,608
My dealer also included one of those for at least one car I bought.
BMWCCA
09-06-2021, 11:06 AM | #11 |
Rep 7,522
Do a google search or try amazon.com or eBay. I have a shorty adapter like in the pic above that I have in both my f06 & f15…but I don’t remember paying that much for them.
If you use that 11 digit BMW part number…it can help in finding the correct size and hopefully for a little less coin.
