      11-24-2019, 11:47 AM   #265
jlin101
Drives: 2018 X3 M40i, 2016 750i
Originally Posted by M6BMWDriver View Post
You can just search in expert mode and it will show you where it is
LOL, I didn't realize that.
To enable automatic seat ventilation for cars so equipped, change
AKT AUTO SITZE FRONT/FOND value to heizung_kuehlung
      11-24-2019, 12:03 PM   #266
M6BMWDriver
M6BMWDriver's Avatar
Drives: F12 Singapore Gray M6 Conv
Yes so
heizung_kuehlung is heat and ventilation
Heizung is heat only
Kuehlung is ventilation only
      12-01-2019, 08:38 PM   #267
tastes jigga
tastes jigga's Avatar
Drives: '19 750i xDrive
Does anyone know if its possible to code Sport+ mode since it is standard on the Alpina B7? The 20mm drop would be nice.
      12-01-2019, 08:47 PM   #268
M6BMWDriver
You need to activate expert mode, in the BDC and Headunit
      12-02-2019, 12:46 AM   #269
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Yes.
No, on coding drop.
      12-02-2019, 09:48 AM   #270
jlin101
Details?
      12-02-2019, 09:49 AM   #271
M6BMWDriver
Details?
Depends on kind of a car you have and year.
But look in BDC_Body for
FesSportWorldMode1 change it to SportExpert
Also in HU_NBT or HeadUnit for
FES_Sport_Expert make it AKTIV
If you have any more questions let me know
LuckyW86.00
      12-02-2019, 03:08 PM   #272
jlin101
I have a '16 750, which has Sport and Sport Custom modes. Will this replace Sport Custom or is it an additional mode?
And is Sport Plus just Sport with traction turned off?
Thanks.
      12-02-2019, 03:38 PM   #273
M6BMWDriver
Thanks.
This will add to the menu SportPlus
The traction is not off on mine with SportPlus
      12-02-2019, 06:05 PM   #274
jlin101
Then what is the difference between Sport and SportPlus?
      12-02-2019, 06:23 PM   #275
M6BMWDriver
Have a look and thins link
https://www.bimmerfest.com/forums/sh.../topics/838460
When i turn my 750 into SportPlus DSC stays on.
      12-03-2019, 09:48 AM   #276
jlin101
Can you feel any difference going from Sport to SportPlus?
      12-03-2019, 09:49 AM   #277
M6BMWDriver
I sure do!! For both my 750 and my X7
      12-17-2019, 04:35 PM   #278
andriuszz
Drives: Bmw 730 G11
Hey guys,
I am getting many PM’s regarding hands off driving with steering assist coding. Please note you need driving assistance plus package to code this option. I would like to share my knowledge with others so this information is available to anyone.
CAF: SAS
C_STA_ALC_handsoffgestchwausschaltgrenzeKmh
C_STA_ALC_handsoffgestchwausschaltgrenzeMph
C_STA_ALC_handsoffgestchweinsschaltgrenzeKmh
C_STA_ALC_handsoffgestchweinsschaltgrenzeMPh
Change werte value to desired speed (use hex converter) when hands is required on the wheel. Please be aware steering assist occasionally disengages without any warning. Use this coding on your own risk !
      12-17-2019, 04:47 PM   #279
Zodiac
Drives: G11 750i, M5 E60, M6 F12
Hi, do you maybe know in which section of Bimmercode or in which particular device I can find if my G11 is in 'transport mode'? I have 2 problems that would point to it being on (first is the BMW Touch Command not popping pressing EJECT and EJECT seems to be blocked mechanically, second is that the perfume setting is resetting every time I start the car) and I would like to check that myself before visiting my service advisor.
      12-21-2019, 10:20 AM   #280
sd_dracula
Drives: 2020 G20 330e
Originally Posted by andriuszz View Post
Hey guys,
CAF: SAS
I have a G20 with the correct package but I do not have an SAS module, I do have SAS2 however I was not able to find the entries above in that module.
Any ideas? The car has iD7
      12-21-2019, 10:35 AM   #281
andriuszz
Drives: Bmw 730 G11
I believe cars with ID7 uses camera to track your eyes, it don’t have touch sensor in the steering wheel, correct me if I am wrong
      12-21-2019, 11:42 AM   #282
sd_dracula
It does, as after some seconds yellow lights flash on the steering wheel and on the display to put your hands on it so I think it has both.
      12-21-2019, 11:51 AM   #283
andriuszz
Drives: Bmw 730 G11
Try to type handsoff in esys search bar, maybe it will find under different name.
      12-21-2019, 12:13 PM   #284
sd_dracula
Yeah already tried it but no luck, the SAS2 module has very few options. For id7 might just be in another location.
There is thing called extended traffic jam assistant which allows the hands off the wheel for an extended period of time so if I can enable that or find where it is, it might do the trick.
      12-21-2019, 12:26 PM   #285
andriuszz
Drives: Bmw 730 G11
Did you try this one: C_HOO_ * I believe this one should enable eTJA
      12-21-2019, 12:30 PM   #286
andriuszz
Drives: Bmw 730 G11
Hello,
Maybe someone has G30 SAS2 cafd file with driving assistant plus package (5AT) to share, as I am trying to find sollution to increase ACC resume time to 30s on my G11.
