09-19-2021, 12:58 PM | #1 |
Rep 738
M826 wheels are pain in the butt to clean. Help.
See the picture.
Every time when I thought I was doing great cleaning the wheels, the end result was still bad. How to clean this properly? Thanks in advance.
09-19-2021, 01:01 PM | #2 |
Rep 780
Drives: G82 M4 Comp X-Drive Individual
Just like my outgoing F82 wheels. Never easy, take your time (buy wheel woolies brushes and use a sponge)
Always worth it if you put the time into them
E30 325i Sport: E36 318is: E36 328i Sport:
E46 330Ci Sport: E86 Z4 3.0i F82 M4: F82 M4 Comp Individual LCI G82 M4 Comp X-Drive Individual FDG |
nathanm4695.00 |
09-19-2021, 01:04 PM | #3 |
Rep 883
Drives: 2021 BSM G80 comp
This is after cleaning? What did you do. Need to use a sponge or glove and get in between each spoke. A wheel cleaner spray and rinse isn't going to do it.
2021 G80 Comp
nathanm4695.00 |
09-19-2021, 01:08 PM | #4 |
Rep 381
1. Wash car and wheels
2. Dry wheels then drive around the block and be heavy on brake to remove rust from rotor 3. dry car 4. touch up the wheel with detail spray and soft cloth
Current: 2018 ///M3 CS - Alpinweiss
Current: 2022 ///M3 Competition - Brooklyn Grey Previous: 2015 ///M3 - Alpinweiss - Euro Delivery Last edited by M3Fahrer; 09-19-2021 at 02:10 PM.. |
09-19-2021, 01:09 PM | #5 |
Rep 780
Ps/. Expect the wheels to take twice as long as the car.
nathanm4695.00 |
09-19-2021, 01:11 PM | #6 |
Rep 1,711
Spend some time watching Matt's videos here
https://www.obsessedgarage.com/ The process should be wheels first without getting the car wet, then top of car (roof > hood > trunk), then sides. Do the wheels 1x1 and you need some good ph balanced wheel cleaner and good brushes. |
M_Adaptive1777.50 floating.spirit1034.50 |
09-19-2021, 01:17 PM | #7 | |
Rep 586
IG: Adaptiive_M
E46 M3 (Sold) E92 M3 2022 G82 M4C Xdrive |
stevethegopher22.00 |
09-19-2021, 01:55 PM | #8 | |
Rep 1,711
Here is the channel https://www.youtube.com/c/MattMoreman |
nathanm4695.00 M_Adaptive1777.50 |
09-19-2021, 01:57 PM | #9 | |
Rep 780
Completely wash car and rinse but apply snow foam on wheels prior to this. Jet wash wheels to remove foam/surface dirt. Spray ironX or likewise on wheels in a mist like spray (remembering what you can't see still counts) Use wheels woolies large brush to do inner wheel face step by step. Use sponge to run round internal rim behind spokes (a bit awkward, go from spoke to spoke) Spray ironX lightly on sponge and clean each spoke blade inside and out methodically. Clean face of wheels/spokes. Clean wheel bolt recesses. Rinse with high pressure water on every surface. Drive car immediately for a minute or so and brake hard to a stop (while looking behind you 👍 Rinse wheels and rusty water away but keep clear of brake discs (I used to brake really hard to heat up discs, water evaporates if your quick and you can just rinse as normal) Use damp microfibre cloth and wipe dry wheel going from spoke to spoke inside and out. Last step. Open up a cold bottle of Peroni (bud if in the USA) and contemplate if having factory fresh wheels was worth it 😎
09-19-2021, 02:01 PM | #10 | |
Rep 738
09-19-2021, 02:08 PM | #11 | ||
Rep 780
09-19-2021, 02:27 PM | #12 |
Rep 262
Drives: 2022 M3 6MT
I haven't taken delivery of mine with the 826s on it yet, but currently have wheels with a ton of spokes that constantly get brembo dust caked on them. I've had success with Chemical Guys' citrus wheel cleaner spray, a nice wheel cleaning brush, and a pressure washer. It's the inner barrel of the wheels that I really hate to get in there and clean, not so much the spokes.
2022 M3 G80 6MT
Portimao Blue/Full Fiona Red Carbon Buckets Squad |
nathanm4695.00 |
09-19-2021, 02:47 PM | #13 |
Rep 6,613
I buy this every quarter.
Sonax (230505) Wheel Cleaner Plus - 169.1 fl. oz. https://www.amazon.com/dp/B00VSTMS6G...UTF8&psc=1 |
nathanm4695.00 |
09-19-2021, 02:48 PM | #14 | |
Rep 738
forza19763494.00 |
09-19-2021, 03:56 PM | #15 |
Rep 575
Drives: '19 GLA45AMG(his) / '21 X3M40i
Lots of patience, blue paper towel and WD40 once a week. The more weeks you skip, the harder it will be to clean it.
Currently: '19 GLA45AMG grey (his) & '21 X3M40i DGM (hers) w/ JB4@Map1
Previous cars: 2022 M4 xDrive in Mexico Blue with Silverstone/Black interior 2014 BE GTR FBO/e85 Last edited by GixY2K; 09-19-2021 at 04:18 PM.. |
nathanm4695.00 |
09-19-2021, 04:13 PM | #16 |
Rep 7,147
Drives: 2022 DG/BLk xDrive M4C Wk 34
The best thing against Brembo brake dust. And the second thing against Brembo Brake dust. https://www.amazon.com/PBMG-Meguiars...a-815255856170
2022 DravitGrau /Black Full Merino M4 Competition M xDrive / Production Week 34/ Delivered 10/19/21/ IG: dravit_m4_comp
YT: G Dubyou |
09-19-2021, 04:24 PM | #17 |
Rep 7,147
For me, the barrels are the worst part. The wheels arent even clean, to me, unless the barrels and tires are spotless. All of that browning on the tire, is all contamination, and fallout from the suns rays. The sun, and road chemicals, turn the tire brown. I take my wheels off, about once a month, to make sure I get them really good.
YT: G Dubyou |
nathanm4695.00 Custom Install2477.00 |
09-19-2021, 04:28 PM | #18 |
Rep 518
Drives: G82 M4, F15 X5, F30 328d, E30
Is this your first BMW? Lol. Welcome to brake dust nightmare!
2022///M4 Competition BSM / Fiona Red.
2023 X7 xDrive40i, BSM / Individual Ivory white/Atlas Gray over Piano Black MSport Pro and Prof. |
LuckyBrand1716.50 |
09-19-2021, 04:29 PM | #19 |
Rep 738
No… 5th… if I remember correctly.
09-19-2021, 04:37 PM | #20 | |
Rep 1,830
Drives: 2025 M8 GC, 2023 X3M, 2024 X5M. Sold 2022
Limegrntaln14080.00 |
09-19-2021, 04:40 PM | #21 |
Rep 7,147
How good is that for the wheel paint, though. Wheew.
YT: G Dubyou |
09-19-2021, 04:42 PM | #22 |
Rep 1,830
Good point. It's pretty gentle and I'm careful with the spray and rise and haven't had an issue on the last few cars
