      09-07-2020, 12:02 PM   #1
TENCHI
Drives: '19 G12, '17 E300
Engine Coolant warning...go to Dealer or fill myself?
2019 740ix and i got a low coolant warning. Called up the dealers and they said they would top it off. One advisor was pretty open about and said all they are going to do is add water. The dealers are a bit ways away as well. I am thinking just buying coolant and doing it myself. thoughts?
      09-07-2020, 01:38 PM   #2
JustinP
Drives: BMW X3M competition
I would insist the dealer pressurise the system to see if it’s leaking before they just top it up.
      09-07-2020, 02:20 PM   #3
Shantosh Seewooruttun
Drives: Sleek
Well, you can do it yourself, but if you get the warning on again in a short time, then maybe it is leaking like JustinP said or it is just a sensor problem. Also, check for anomalies like presence of oil residue.
Whatever you do, do take the necessary precautions as recommended in the manual (engine turned off and cold to avoid any spillage or accident but also to fill it to the required level as it is different when hot and cold).
      09-07-2020, 04:01 PM   #4
AlteBMW
AlteBMW's Avatar
Do both. Buy coolant. Add it (when cold only). If the light doesn't clear, you may have a sensor problem. Check again in a week. If the level is down, you may have a leak and should head for the dealer. Make sure to tell them you added fluid.
BMWCCA
Current: 23 760ix (Carbon Black/Tartufo) (after first one totaled) '23 X3; '23 MB E Wagon
Prior: BMWs (3,5,7 & 8 series (2x!)) X3, MB (C, E, and S), Alfa GTV, MGB, Audi (A4, A6), Saab, Volvo, Toyota, Lincoln, Chrysler, Oldsmobile, Chevy, Rambler.
      09-08-2020, 09:18 AM   #5
Cruzdog954
Drives: 2023 BMW X4M Competition
Go to the dealer and ask for a pressure test.
I was adding a bit of coolant - 1/2 quart every 5k miles on my 750.
Ended up being 2 turbo coolant lines leaking a little bit. You won't see anything in your garage floor as it leaks onto the engine and quickly evaporates.
      09-10-2020, 07:19 PM   #6
TENCHI
thanks guys. I wound up adding a little distilled water until my BMW coolant comes in. dealer wanted $180 to top off since I am not the original owner.
      09-20-2020, 07:33 AM   #7
jstewart
Drives: bmw 760i x-drive
Probably the intercooler coolant lines. On my 2016 I had this warning and the dealer covered replacing all the intercooler coolant lines under warranty. This is a known problem by BMW. The whole thing should be covered, labor, parts, coolant.
      09-24-2020, 01:06 PM   #8
Malu59RT
Malu59RT's Avatar
29
Drives: BMW 740i
There shouldn't be a loss of coolant as part of normal operation. I've had this happen 3 different times under warranty, and each time there was something the dealer had to fix.
2021 X7 40i - Tanzanite Blue
2016 BMW 740i - M Sport (Gone)
      10-01-2020, 06:52 PM   #9
jettie1767
Drives: '23 BMW i7 xdrive60
This happened to me last month, too. They replaced the 4 turbo coolant lines although only 1 was leaking. Covered by warranty.
'23 BMW i7 xdrive60 - Frozen Deep Grey
'22 BMW 228xi Gran Coupe - Phytonic Blue
      10-29-2020, 06:15 AM   #10
Erik1
Drives: 740d xDrive 2016
Going through the same issue, seems to be a known issue, sickness with the EGR according to my mechanic who worked for BMW. But so soon? Top it up first and see if it comes up again.
      10-31-2020, 06:34 PM   #11
TheManWithDa7
Drives: 750
I had the leaking turbo coolant lines. Bmw wanted 5500.
I threw a fit, then they said 3600 plus tax.
Then I called bmw of North America and got them involved.
Then the dealership came down to 2025 plus tax.
I still won't get it fixed by them. Would rather go to an Indy.
      11-10-2021, 07:24 PM   #12
TENCHI
October 2021......I got the low coolant warning again. I took it to a different dealer. they ran some simple tests. All within spec. No leaks. Just normal for coolant to be refilled.
but literally twice in a year?
      11-11-2021, 12:42 AM   #13
AP
AP's Avatar
2762
Drives: G30 M550
That's not normal
If you look on the 5 series forums, it is certainly not an unknown issue, had it myself
In my case the 2 reservoirs had very small leaks in them and was replaced under warranty
Look for coolant in the engine bay )use a torch as difficult to see)
You may find warning goes away when engine is warm but comes back from a cold start
      11-14-2021, 09:04 AM   #14
dc5525
Drives: 2018 BMW 740i Xdrive M Sport
Not normal....my 2018 740iX light came on this past summer with only 32,000 miles, since under warranty I took it in. Sure enough they replaced entire coolant system as they determined pressure test failed.
      11-14-2021, 01:10 PM   #15
750LiBeemer
Drives: Bmw 750i
32,000 miles? Nice. At least the 7 is becoming more and more reliable!
      11-15-2021, 04:02 PM   #16
dc5525
They also had to replace radiator blinds, whatever the hell those are. Since under warranty I really didn't inquire what may have caused issues at such low miles.
      11-17-2021, 01:57 PM   #17
OnlyGerman
OnlyGerman's Avatar
Drives: F15, F13, F10, E60
I would say normal but have dealer do it so it is documented for low coolant. These drink oil and coolant all day
      11-18-2021, 08:49 AM   #18
AlteBMW
AlteBMW's Avatar
In my experience, it is not normal to drink oil and coolant all day and if a car is behaving that way it needs dealer attention while in warranty. If the turbo lines were repaired (under the campaign they had), oil consumption should not be a problem, and in a closed cooling system, losses should be minimal if nonexistent. Reporting and documenting any nontrivial losses would be a very good idea especially if your mileage or age of car is getting you close to warranty expiration.
BMWCCA
      04-24-2023, 01:16 AM   #19
TENCHI
ok...update.
3 yrs later and I have filled up my coolant (no joke) for the 5th time last week. Dealer(s) (i took it to 3 different dealers) could not find a leak. I have no evidence of a leak at home either.
Oh well.
      04-24-2023, 07:45 AM   #20
edojac
Drives: BMW 2016 750i & 2018 M760i
Itīs a common problem though and likely a slow leak.
Just regularly check the return lines for the turbo.
Are they rubber?
(I had that fixed by BMW 3 months ago).
      04-25-2023, 06:33 PM   #21
TENCHI
Are they rubber?
not sure. I haven't been in the engine bay myself.
