11-12-2023, 06:27 PM | #45 |
Commander-In-Chief
2196
Rep 8,944
RGS mesh
Website show two zip ties each strut. Fairly discrete. Side radiators need the same protection, though.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
M2-Bob245.00 |
11-21-2023, 08:43 AM | #46 |
Rep 77
Ordered a full set of Zunsport screens (including the underside protector). Took a little while to get them, because the underside screen was still being developed. But I was told this, given an approximate time, and they arrived as promised. All-in-all excellent customer service.
Installation was "fiddly", but just required a bit of patience and going slow to get it done. You have to be very careful not to scratch the shiny black plastic with the clips that hold the screens in, and the clips require a little bending, test fitting and re-bending to get securely into place. I was also a little concerned with two tiny screws that are used to hold the underside mesh in place. There are *a lot* of hoses and radiators down there! But, I had to trust that I had followed the instructions and the designers of the screen had put the holes for the screws in the correct location. So far, so good! I managed to get through the process with one tiny scratch at the very back of one of the side openings, due to having to press *hard* on the screen to get it to clip. The first couple of attempts produced a small scratch near where the clip seats. Overall, better than I expected. Interestingly, none of these solutions seem to take into account an opening between the middle opening and the sides. You have to dig around there to see the opening, it doesn't show up in most common picture angles. But, it is an indirect path, and would be difficult to screen. Most of the likely rock/road debris paths are covered. My biggest concern is getting these things *off* if I want to clean behind them or gain access. Once they are on, they are on tight. Good for protection, but maybe a pain for "servicing", we'll see. Very satisfied with the result. I didn't add pictures, because there are plenty on the thread already. Mine looks just like the others. I'm kind of okay with the grill being in front of the braces. At most angles, the braces "disappear", giving the grill a smooth visual look, simplifying the busy front end. But either is fine, I just didn't kike all that exposed radiator area. I put a much simpler and more flimsy version in the small opening at the bottom of my Miata, and it has probably saved a puncture a time or two (and has the scars to prove it!). |
11-21-2023, 10:06 AM | #47 | ||
Commander-In-Chief
2196
Rep 8,944
Opening protection
11-21-2023, 01:05 PM | #48 | |
Rep 77
In the first attachment, the yellow ball points to the opening, which is in front of the center grille. In the second attachment, you can see when I stick the chrome rod (carefully) through the opening it ends up behind the right hand opening screen (red arrow) Yeah, I went from being impressed, because it looked like the cover would unsnap and hinge, to finding out that there didn't appear to be an easy way to get it off. |
11-21-2023, 02:24 PM | #49 | |
Commander-In-Chief
2196
Rep 8,944
11-22-2023, 12:21 PM | #50 |
Rep 77
Yeah, I think they look good, and if they stop one holed radiator/cooler/etc., they will pay for themselves. Something is better than nothing (or very little) particularly on the underside and middle/end openings in the front.
12-27-2023, 02:45 AM | #51 |
Rep 53
12-27-2023, 10:21 AM | #52 |
Professor
2354
Rep 1,871
Drives: '23 M2 & '22 X3 M Competition
ZunSport says no issues, and other members report no issues. I haven't tested it out on mine yet, but I also rarely use ACC (not a fan).
Her's: '22 X3 M Competition, Marina Bay Blue, Tartufo interior, 21" 892M wheels, executive pkg, carbon fiber trim.
His: '23 M2, Toronto Red Metallic, M highlight interior, carbon fiber interior trim, shadowline, lighting pkg, auto cruise, live cockpit pro. |
12-31-2023, 03:28 AM | #55 |
Rep 53
12-31-2023, 08:18 AM | #56 | |
Rep 263
The grill size was starting at 57 cm x 15 cm. Then trim it down so that you can slide the grill in. I used Honeycomb hole 11x30mm Hex grids pattern ABS grill sheet from Amazon. Last edited by 1stM; 12-31-2023 at 08:24 AM.. Reason: adding photo |
01-02-2024, 01:35 PM | #57 | |
Rep 619
Current: 2024 G87 M2 (ZF8)
Past: 2022 330i RWD 2020 M2 Competition DCT |
01-02-2024, 06:30 PM | #59 | |
Rep 263
turnsignalslol276.50 |
01-03-2024, 11:02 AM | #61 |
Rep 619
Would you say that it provides enough protection? The gaps seem a little big in my opinion but if it works it works
01-04-2024, 02:06 PM | #62 | |
Rep 45
Drives: 2024 M2, 2024 GR Corolla
I decided to give it a try and ordered the part. Haven't got it yet it's said to be shipped from Germany. |
baron951736.50 |
01-04-2024, 08:27 PM | #63 | |
Rep 898
G87 M2 BSM On Order
01-04-2024, 09:41 PM | #64 |
Rep 45
baron951736.50 turnsignalslol276.50 |
01-07-2024, 03:46 PM | #65 | |
Rep 619
01-07-2024, 03:51 PM | #66 |
Rep 263
