02-20-2023, 12:36 PM | #1 |
Rep 8
Windshield Washer Fluid Reservoir Low 2016 G11
Good Morning Everyone,
I tried searching but couldn’t find anything or maybe I wasn’t properly using the search function. Anyways I have a 2016 740i and I keep getting a notification on my cluster saying that my windshield washer fluid is low even if it’s filled to the top. It will appear after about 5 minutes of driving so it’s not on all the time but more often than not it turns on even though the reservoir is full. Could it be the sensor showing the level as low or possibly the sensor connection came loose. I see they don’t sell the fluid level sensor separately and comes together with the tank itself. I found part number 61-66-8-491-829. I don’t have the headlight washer system so this seems like the correct part. https://www.bmwpartsdirect.com/oem-p...w2LWdhcw%3D%3D Anyone have a course of action or maybe there’s something I can run through the tank to the clean the sensor. Maybe there’s some buildup causing it to give off a false positive? Thanks |
02-20-2023, 01:48 PM | #2 |
Rep 5
I have the same problem. You have to put only original BMW liquid. The sensor is based on the color of the liquid and its opacity. In Romania I found another liquid that is the same color as the original and I no longer have this problem.
This problems apears only in low temperature in winter. |
02-20-2023, 02:56 PM | #3 | ||
Rep 386
I would recommend running some good quality, ethanol based (winter) washer fluid through the system and if that doesn't help, change the tank. Quote:
davidp4230.00 |
02-21-2023, 01:03 PM | #5 | |
Rep 204
02-22-2023, 04:10 AM | #6 | |
Rep 20
02-23-2023, 05:23 AM | #8 |
Rep 204
