Go Back   7Post - 7 Series Forum > BIMMERPOST Universal Forums > Classic BMW (Pre-2005 Models)
      03-16-2023, 12:20 PM   #1
CSF Cooling
CSF Cooling's Avatar
Drives: F10 M5 - Imola Red
New CSF BMW S54 Swap Radiator & Oil Cooler – E36
CSF’s industry-leading reputation and deep knowledge of high-performance BMW cooling systems offered an edge when designing such a unique cooling system. Combining the experience from producing the best cooling systems for the E36 and E46, CSF was able to design and produce an innovative solution that covers the widest range of S54 swap customers possible.
See the full press release: https://csfrace.com/new-csf-bmw-s54-...il-cooler-e36/
Radiator – CSF #7211
At first glance the #7211 looks very similar to CSF’s E36 M3 Radiator (#3054). While the overall shape is very similar, there are several key features that make the new swap radiator special. Because the S54 requires a much more robust oil cooling system than the E36’s S52/S50, CSF made special provisions to fit two different race spec oil coolers. Please note, this radiator and oil cooler combination can be used for S50 & S52 Swaps as well. To do this, the height of the radiator was reduced slightly so the CSF race spec coolers can fit it in a factory style location. The radiator includes a custom designed oil cooler mounting bracket which has provisions to fit both oil coolers (CSF #8032 & #8240). In addition, a custom designed radiator cover plate allows for an optimized coolant overflow line placement which is concealed for an OEM+ appearance.
CSF also includes brackets for an electric fan conversion. These brackets are designed to fit a single 16 inch SPAL Fan (not included). While it is possible to retain a clutch type fan, it is much easier to convert to an electric fan on top of the performance benefits.
The 2-Row 42mm aluminum core offers the largest coolant capacity possible and incredible heat dissipation. CSF’s Exclusive B-Tube Technology increases the heat transfer by approximately 15% over regular oval welded tubes. In addition, the super-efficient multi-louvered fins maximize airflow through the core for the best possible performance. All mounting brackets are CNC Machined for precise fitment. The cooling inlet/outlet connections use E36 OEM style slip on connections.
Oil Coolers – CSF #8240 & CSF #8032
Any who has ever tracked an E46 M3 or even just driven one hard knows how quickly the oil temperatures can climb. For the E46 M3, CSF developed the Dual Pass Race Spec Oil Cooler (CSF #8032) with Rogue Engineering. This has been the go to solution for the E46 M3 community and will work on S54 Swaps when paired with this radiator. Why are there two oil coolers then you might ask? Because of the chassis differences, the CSF #8032 will not allow owners to retain air conditioning with their S54 Swap.
Enter the new CSF S54 Swap Race Spec Oil Cooler. This new oil cooler is shorter on the right hand side allowing owners to run the A/C lines in the OEM path. Even though the #8240 is slightly smaller than the #8032, you can expect similar performance levels as they both feature a dual pass design with 8 cooling rows and are the same turbulated heavy-duty bar/plate construction.
Both oil coolers utilize the S54 OEM oil line connections. However, CSF will be offering a fitting kit with -10 AN hookups for customers looking to run custom oil lines. This fitting kit should be available by the second quarter of 2023.
BMW S54 Swap High-Performance All Aluminum Radiator & Race Spec Oil Cooler Features (CSF #7211 & #8240)
#7211 – High-Performance All Aluminum Radiator
  • 2-Row – 42mm Ultra-High-Performance Core
  • CSF’s Exclusive B-Tube Technology
  • 6.5mm Tall Ultra Efficient Fins with a Multi-Louvered Design for Maximum Surface Area Contact
  • CNC Machined Mounting Brackets, Fittings, and OEM Style Inlet/Outlet
  • 100% All Aluminum TIG-Welded Construction
  • Smooth Satin Finish
  • All-Aluminum Race Style Drain Plug
  • Includes 2 top cover plates (black and satin) to cover the top of the radiator for a clean OEM+ look
  • Includes fan brackets for use of 16 inch SPAL Fan (SPAL #30100400 – not included)
  • Includes Oil Cooler Mounting Bracket for fitment of both the CSF #8240 (w/ A/C) & CSF #8032 (w/o A/C)
  • True Plug-and-Play “Drop-in Fit” Installation Requires Absolutely No Modifications
  • Also works for BMW S50 & S52 Swaps for E36 Chassis
  • Individually Leak and Pressure Tested
  • 2-Year Limited Warranty
  • Applications:
  • 1992-1999 BMW E36 3-Series (including M3)
  • S54 / S52 / S50 Swaps
  • 1999-2006 BMW E46 3-Series (excluding M3)
  • S54 Swaps
MSRP: $529.00 / MAP: $499.00 USD
#8240 – Oil Cooler
  • Unique Top/Bottom Dual-Pass Design for Maximum Surface Area and Flow
  • Fully TIG-Welded Extruded End Tank Design for Superior Reliability & Durability
  • Turbulated Heavy-Duty Bar/Plate Design for the Most Reliable & Durable Oil Cooler Available
  • 8 Rows of Maximum Cooling with a High Density Multi-Louvered Fin Pitch Design
  • Designed to Work with CSF’s S54 Swap All-Aluminum Radiator (CSF #7211)
  • Motorsport Silver Finish
  • Accepts Factory Oil-Line Connections
  • For S54 Swap Vehicles with Air Conditioning (A/C)
  • For S54 Swap Vehicles without Air Conditioning (A/C) see CSF #8032
      03-16-2023, 12:21 PM   #2
CSF Cooling
Recently Featured on StanceWorks and Mike's S54 Swapped E36 M3
